Jeep shuts off while driving - JeepForum.com
post #1 of 3 Old 05-15-2012, 06:41 AM Thread Starter
Rollin
2000 Jeep Cherokee with 4.0, Auto. Will be driving, and truck just shuts off. No CEL, no sputtering, no warning. After about 15 seconds, it will restart with the key and drive fine the rest of the trip. New battery, alternator etc.
I am thinking coil pack as the Jeep has 176k on it now.
The radio also shuts off when I open the drivers side door. Dont know if this is part of the problem or not.
1998 Jeep Cherokee Classic: Bull Bar, TracLock Chrysler 8.25"
Rollin is offline
post #2 of 3 Old 05-15-2012, 07:55 AM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
A faulty Crankshaft Position Sensor would be the first thing to suspect. Test the CPS. It may test good until it gets hot and fails, and then it will test good again when cooled off. Buy a genuine Jeep replacement.
Wiring issues in the drivers door are common and easily fixed.
The most likely cause of it cranks and cranks but won't start up is the Crankshaft Position Sensor (CPS) located on the transmission bell housing. Often this part is also referred to as the CranKshaft Position Sensor (CKP) CPS/CKP failure is very common. The CPS/CKP can stop working with no warning or symptoms and the engine will not run or the engine may randomly stall for no apparent reason.
Typical Symptoms –
- Starter cranks and cranks but engine won't start up and run.
- Fuel gauge and voltage gauge may not work or display properly.
- You sometimes will have No Bus on the odometer after 30-60 seconds.
- A failed CPS/CKP may or may not throw a CEL trouble code.
- No spark at the spark plugs.
- Fuel pump should run and prime for 3-5 seconds.
Crank Position Sensors can have intermittent “thermal failure”. This means that the CPS/CKP fails when the engine gets hot, but works again (and will test as “good”) when it cools back down.
Begin with basic trouble shooting of the start and charge systems. Remove, clean, and firmly reconnect all the wires and cables to the battery, starter, and alternator. Look for corroded or damaged cables or connectors and replace as needed. Do the same for the grounding wires from the starter to engine block, and from the battery and engine to the Jeep's frame/body. You must remove, scrape, and clean until shiny, the cable/wire ends, and whatever they bolt to. Jeeps do not tolerate low voltage, bad connections, or poor grounds and the ECM/ECU may behave oddly until you remedy this.
Exchange the fuel pump relay and the ASD relay with one of the other similar ones in the PDC to eliminate the relays as the cause of the no-start. Check the ASD relay fuse.
Confirm that the fuel pump to runs for 3-5 seconds when you turn the ignition key to ON.
Eliminate the NSS as a cause of no start. Wiggle the shift lever at the same time you try to start. Put the transmission in Neutral and do the same. Do the reverse lights come on when the shifter is in Reverse?
Inspect the wires and wire connectors at the O2 sensors on the exhausts pipe. A short circuit from melted insulation or from broken O2 sensor wires can blow a fuse and the ECU/ECM will loose communication. Don’t get tunnel vision and assume the sensor is bad (unless it tests bad with a meter). Damaged wiring or a dirty connector can inhibit the signal from making it to the computer. Inspect/test/clean/repair wiring or connectors as necessary.
If the CPS/CKP is failed sometimes the OBD-II trouble code reader cannot make a connection to the ECU/computer or cannot read Check Engine Light/MIL codes because the CPS/CKP has failed. Disconnect the code reader, disconnect the CPS/CKP wire connector, and reconnect the code reader. If the code reader establishes contact with the ECU and scans, your CPS/CKP is failed and needs to be replaced.
Diagnostic steps to confirm the CPS is the cause of your no-start
1) You should be able to verify a bad cps, by unplugging it, and turning the ignition key to on. If the voltage gauge and/or the fuel gauge now display correctly and/or the No-Bus is gone, replace the CPS.
2) If the CEL does not come on when the key is turned to the RUN position... then the CPS/CKP is bad.
3) Unplugging and reconnecting the CPS sensor where it connect to the main harness near the back of the intake manifold usually resets the ECU and if the jeep fires right up after doing this you can bet that the CPS is faulty and needs to be replaced.
The 2000 and 2001 will have the CPS in the same location on the bell housing, but the wire connector is near the Transfer Case, not as shown in the diagram below. Simply follow the wire from the sensor to the connector.
CPS Testing
Crankshaft Position Sensor Connector (CPS/CKP)
TESTING PROCEDURE 1991 – 2001 4.0L H.O. engines
1. Near the rear of intake manifold, disconnect sensor pigtail harness connector from main wiring harness.
2. Place an ohmmeter across terminals B and C (See Image). Ohmmeter should be set to 1K-to-1OK scale for this test.
3. The meter reading should be open (infinite resistance). Replace sensor if a low resistance is indicated.
TESTING PROCECURE for 1987 – 1990 4.0 L engines
Test # 1 - Get a volt/ohm meter and set it to read 0 - 500 ohms. Unplug the CPS and measure across the CPS connector's A & B leads. Your meter should show a CPS resistance of between 125 – 275 Ohms. . If the CPS is out of that range by much, replace it.
Test # 2 - You'll need a helper for this one. Set the volt/ohm meter to read 0 - 5 AC volts or the closest AC Volts scale your meter has to this range. Measure across the CPS leads for voltage generated as your helper cranks the engine. (The engine can't fire up without the CPS connected but watch for moving parts just the same!) The meter should show .5 - .8 VAC when cranking. (That's between 1/2 and 1 volt AC.) If it's below .5vac, replace it.
CJ7-Tim is offline
post #3 of 3 Old 05-15-2012, 11:15 AM Thread Starter
Rollin
Thank you for the information.
Rollin is offline
uh oh... jeep shuts off while driving... edolivett XJ Cherokee Technical Forum 18 02-24-2015 07:59 PM
XJ Shuts off While Driving MillerXJ XJ Cherokee Technical Forum 5 01-24-2010 06:31 AM
Jeep shuts off when driving only HELP! JeepinXJstyle XJ Cherokee Technical Forum 11 12-01-2009 05:59 AM
Shuts off while driving? Cornfedrides XJ Cherokee Technical Forum 4 12-24-2008 04:53 PM
jeep just shuts off while driving nc_firefighter5 XJ Cherokee Technical Forum 4 10-09-2008 04:56 PM
