jeep shuts off randomly??? - JeepForum.com
post #1 of 7 Old 11-04-2011, 12:02 PM Thread Starter
theRokee-88
My 88 4.0 cherokee keeps shuting off on me when most of the electronics are on in the car (esp. the heater). the other night I drove for about 10 mins with the lights heater and radio on. I tried to roll my electric window down and it instantly shut off. However it turned right back on after I shut everything off. turned the lights back on, car shut off. car turned right back on. got down the street aways put my blinker on car shuts off. turns right back on.
It had happened before so it took it to a shop they couldn't get it to shutoff so they fixed what they thought the problem was. but of course that wasn't it.
I am at a loss. no idea what it is. Need help.
Thanks very much,
Alex
theRokee-88 is offline
post #2 of 7 Old 11-04-2011, 12:15 PM
chriskeenan
Bad grounds, its a fairly common issue, the grounds to the battery coming loose and failing or becoming severely corroded and failing.
Clean/refresh the grounds to the battery, check the chassis ground and engine ground cables and report back.
chriskeenan is offline
post #3 of 7 Old 11-04-2011, 01:39 PM
Brg0012
1983 CJ7
x2
Brg0012 is offline
post #4 of 7 Old 11-04-2011, 05:25 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
The ground strap from the back of the head to the firewall: Remove it from the firewall and clean the paint off the firewall and bolt it back on. Be sure it is tight at teh back of the head.
Follow your negative battery from the battery to where it bolts on to the block. Make sure it's a clean and tight connection.
cruiser54 is offline
post #5 of 7 Old 11-04-2011, 07:30 PM Thread Starter
theRokee-88
Thanks very much I'll try that this weekend and post back the results.
Thanks again,
Alex
post #6 of 7 Old 11-04-2011, 07:31 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Wouldn't hurt to add a cable from the firewall bolt to a bolt on the intake manifold. The grounds on these Jeeps were underengineered to say the least.
post #7 of 7 Old 11-05-2011, 06:38 AM
tjwalker
It's the crank sensor!
tjwalker's Avatar
Agree with cruiser. You must start by FRESHENING grounds. RENIX Cherokees (87-90) are extremely susceptible to ground issues. More below:
Grounds can be the root cause of many electrical gremlins. Refreshing grounds is NEVER a bad idea, and the investment of your time in this procedure is always well worth it!
You can't tell much of anything by looking at ground connections!! You must remove, scrape, clean until shiny the cable/wire ends and whatever they bolt to. Be sure to remove all paint from any ground connections.
Start with the one on the back corner of the head, and where it attaches to the firewall, as it deteriorates over time and is an area that makes it susceptible to damage. Best to replace that woven cable with a #4 or #2 gauge cable. You can attach the one end to the intake manifold if you would like.
Next go over to the engine dipstick tube stud. Remove the nut and clean the wire ends and scrape the block until shiny at the stud. Reattach tightly.
If you are so inclined, add at least a #6 cable from the negative terminal of your battery to one of the bolts on your radiator support.
99 Cherokee, 4.0 AW4, NP242
Past Jeeps: 49 Willys, 81 Scrambler, 88 Comanche
Without "data", all you have is an opinion!
tjwalker is offline
Engine shuts off randomly!!!! pjavan XJ Cherokee Technical Forum 5 10-10-2011 08:44 PM
Air shuts off randomly bwoo90 XJ Cherokee Technical Forum 1 03-23-2011 06:37 PM
My Jeep Shuts Off Mearcliff XJ Cherokee Technical Forum 3 06-15-2009 11:05 AM
jeep just shuts off jnkyrdg04 XJ Cherokee Technical Forum 7 08-28-2007 03:34 PM
Jeep Shuts Off? tayoh XJ Cherokee Technical Forum 2 08-09-2005 01:19 AM
