Quantcast Jeep running poorly, need sensor help. - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > Jeep running poorly, need sensor help.
Front and rear Drive shafts @ free shippingPoison Spyder February Special: FREE Rubber Liners when yoSlappin' on 61,510 Rigid Industries Lumens for Big Red
Old 08-25-2008, 02:00 AM   #1
Gsmyth75
1992 XJ Cherokee
My jeep tends to idle up to about 1,100rpm then back down to about 500rpm and start sputtering every once in a while then it will act normal for a while. It's especially annoying at lights when I start idleing into the person in front of me until i notice and luckely I haven't ran into anyone.
It also has a problem at wot around 3000-4000rpm where it tends to hang at that rpm speed for a second before increasing and it sputters while doing that too. So far I've replaced
Tps
Cap and Rotor
Spark Plugs and wires
Fuel Filter
Cleaned the Iac sensor like crazy
Seafoamed it
and I've replaced the map and Iac sensors with junkyard ones just to see if it made a difference.
For a while it ran fine, and didn't have any issues, but now this problem is back and I'm at a loss for what it could be, I've tried searching, and talked to a couple mechanics.
So far my guess is it's got to be one of these:
Cps
Fuel Pump
Coil
or bad map/ iac and I just got unlucky and pulled a bad one.
Any Help will be greatly appreciated.
1992 Cherokee Laredo 4.0 L6, Aw4, Dana 30/35, Np242, 201k
Crower p/n 44243 Camshaft, Camsaver High Oiler Lifters, He Pistons .030 Over, Decked Block and MIlled Cylinder Head. Melling High Volume Oil Pump
Flowmaster Super 40/ Cat and Tailpipe Delete, Apn Header, Homebrew Bored Throttle Body, Rustys Cold Air Intake with Spacer
Gsmyth75 is offline   Reply With Quote
Old 08-25-2008, 02:04 AM   #2
yoda13
Force Wheeler
yoda13's Avatar
My XJ that is also my father's, we took on our trip to Colorado and has the same issues after I dunked it in the river. We had to replace the MAP, TPS, and O2 sensor before it would run right....it acted just exactly like you say yours is...just my experiences...thought it might help you...
2007 White Jeep Wrangler X-auto, black freedom top, 15x8 Pro Comp Rock Crawlers, 33x12.5x15 BFG KM2s, Superchips Flashpaq, 2" OME Spring Lift, Rancho RS5000 shocks, Rusty's Adjustable front and rear trac-bar, JKS Quicker Disconnects, Rusty's adjustable lower control arms (front and rear), PolyPerformance adjustable upper control arms (front and rear), OEM Rubicon Rock Rails, Finishlinewest Stonehenge Series rear bumper, Smittybuilt winch, Body Armor Front High Clearance Bumper w/ KC Highlights mounted, Roadmaster towbar, Valley 2" receiver hitch, Skid Row Engine Transmission skid, sPod switching system, KC Highlights windshield mounted lights, and Bestop saddlebags-Member of the United Four Wheel Drive Association and Blue Ribbon Coalition, John 3:16
If you want to help the sport of off-roading, and protect your right to do so, please visit the Envirobeat
forum...
yoda13 is offline   Reply With Quote
Old 08-25-2008, 02:21 AM   #3
Gsmyth75
1992 XJ Cherokee
Thank you, and wow quick response time. I think I'll try replacing o2 and see what that does. It probably couldn't hurt...
Old 08-25-2008, 09:49 PM   #4
BrunoS
please .... sounds like bad IAC
Newly Painted! Emerald Green '96 XJ 4x4 4.0 HO 5-spd
3" Lift + 31" Tires / D35 TracLok / NP231
Drilled out Stock Airbox / Gauge Cluster Upgrade
Magnaflow Muffler / High-flo Cat / MSD Coil
BrunoS is offline   Reply With Quote
Old 08-25-2008, 10:30 PM   #5
firefighter1c57
SPACE FOR RENT
firefighter1c57's Avatar
IAC wouldn't effect it at 3000 RPM. I'd say TPS. Yea, yea, I know, you've already replaced it. I replaced about 3 in 4 months. Sensors are funny things, sometimes they are even bad from the factory. Just my 2 pennies.
piks
I bring NOTHING to the table.
firefighter1c57 is offline   Reply With Quote
Old 08-26-2008, 01:38 AM   #6
Gsmyth75
1992 XJ Cherokee
I've heard it's common to get bad sensors that are "new". But when I take off the tps at idle it quits/ barely keeps running, so i would think it does something. Is there any way to test if it works ? I have a multimeter but im not sure what all the other modes for it do other than dc volts? What setting would i use to test sensors? Also I cleaned a lot of gunk out of the iac sensor connector and it doesn't run as crappy at idle but it still does the 3k thing.
Old 08-26-2008, 03:13 AM   #7
edolivett
2011 JK Wrangler
you can prob rule out cps... cause they typically go bad pretty fast, and it usually wont even allow the car to start... my bet is on tps or coil.
edolivett is offline   Reply With Quote
Old 08-26-2008, 01:50 PM   #8
mickc9129
I think that '92 was the last year you can adjust your timing. Might see how thats doing.
mickc9129 is offline   Reply With Quote
Old 08-26-2008, 11:17 PM   #9
BrunoS
ok, here's the key:
when you disconnect the TPS, the idle dies. on my xj, if i disconnect the tps, two things happen: check engine light turns on and idle stays exact same.
in your case, dying after disconnecting the tps means the IAC is overextended. they do die after many years of service, regardless of how much you clean it...there is a motor inside that gets wear spots and jumps around. at higher rpm, a stuck IAC allows more air or less air to go in the throttle body which then plays hell with the fuel injector pulse width ("on time") and the oxy sensors go nuts trying to correct the whole mess with erratic airflow due to a jumpy IAC.
here's my test: SIMPLY get the motor warmed up, get a decent idle, and disconnect the IAC motor. drive around. should be a nice ride, plenty of power, and smooth idle. if it's the case....you have a worn out IAC.
as for the TPS....disconnect it, borrow a analag (needle) volt-ohmeter, connect it to ohms...and run the throttle around and watch for a smooth needle movement...if it's jumpy, then a worn spot in the TPS. new tps these days are decent qualiity.
1) don't spend any more money on parts before
2) trying my warmed up idle, then disconnect the IAC motor connector and go for a full test drive.
Old 08-28-2008, 01:04 AM   #10
Gsmyth75
1992 XJ Cherokee
ok, here's the key:
I warmed it up and drove it without the iac and it drove the same as when it was connected. I'm going to go get a new iac, install it and see what happens next. Thanks for taking the time to write out a iac test.
Old 08-28-2008, 07:27 PM   #11
BrunoS
by saying idle didn't change after you disconnected the IAC after all was warmed up....you mean it drove fine, revved up fine, and then idled fine...
or that you have still the beserk jumpy idle....couldn't figure your response.
if after my test it idles smooth, (disconnected IAC connector) and (smooth as a 4.0 does, anyways) at the same rpm, around 750 or so...then you IAC is worn out. Replug it in, and drive around...beserk idle and driving after the reconnect would really indicate again the IAC problem
before spending $80+ on new IAC, take two torx srews (T-15?) that hold it into the TB and remove the IAC, pull it straight out, and inspect it...you may be surprised at the carbon and goo on it. try cleaning it with a toothrbrush and reinstalling it and driving it around again. sometimes this works...sometimes it's time for a IAC replacement.
Glock Forum
