Jeep Rattle - JeepForum.com
post #1 of 8 Old 01-15-2011, 03:03 PM Thread Starter
dmlacrosse42
Jeep Rattle
Sometimes my jeep (2000 cherokee limited, 4.0L, bone stock) will rattle when stopped and in drive, it sounds like its coming from the rear of the jeep kind below the trunk? Sometimes its loud as hell, sometimes it wont rattle. Sometimes If i pop it into neutral it stops, sometimes it goes away to the point where you have to be real quiet to hear it. What could this be? And ive gotten under her while running, while i can hear the rattle in the interior, and i cant hear a thing from outside. helpppppppppp
dmlacrosse42 is offline
post #2 of 8 Old 01-15-2011, 03:07 PM
altrocker1
could be a loose exhaust hanger...
altrocker1 is offline
post #3 of 8 Old 01-15-2011, 03:17 PM
Holder350
1995 XJ Cherokee
Could be the transfer case linkage....its a known issue...
But that wouldn't explain it if it were coming from the rear
95' XJ Country - Stock Skids - D30/D35 Limited Slip - 3" Lift - 31x10.50R15 - 4.0 HO - AX15 - NP231
98' XJ Classic - D30/C8.25 - 4.5" RC Lift - 33x12.50R15 - 4.0 HO - AW4 - NP231
Originally Posted by Azzy View Post
You can tell the character of a person in how they treat someone who can do nothing for them.
Holder350 is offline
post #4 of 8 Old 01-15-2011, 03:19 PM Thread Starter
dmlacrosse42
transfer case i fixed already, ahahha thats one of the many odd noises i fixed, and in terms of an exhaust hanger, it looks fine, at least the one i can see, the weld is in tact and the little rubber bootie is still rubbery, its not too cracked and corroded
post #5 of 8 Old 01-15-2011, 03:24 PM
Holder350
1995 XJ Cherokee
Jump under it when its cool and start shaking the exhaust see if it makes the noise.
post #6 of 8 Old 01-18-2011, 09:57 PM
Oversteer
It's the exhaust hanger above the rear wheel. I had the exact same issue and fixed it this evening. The rubber gets worn and the hole ovals out...and allows the metal hanger to vibrate in the mount. It sounded like it was under the cargo floor and mostly did it when the car was cold. Solved!
Oversteer is offline
post #7 of 8 Old 01-19-2011, 03:25 AM
mecompco
www.midcoastjeep.com
mecompco's Avatar
1994 XJ Cherokee
If the catalyst in yor CAT is broken up, you can sometimes hear an intermittent "rattle". Once you get going, the exhaust noise can mask it. Whack it with a deadblow and see what you hear.
Michael
'94 Cherokee Country
Engine: 4.0 HO, Sealed canister filter, 3 core CSF steel radiator, CatCo cat, Dynomax Turbo Flow muffler.
Electronics: Remote start/locks, Pioneer DEH-P7800MP w/XM, Polk Audio speakers, Garmin Nuvi 660 GPS, Cobra 148 GTL P&T w/Wilson 1000.
Suspension: Old Man Emu 3" lift+OME AAL, JKS adjustable trackbar, QDs, LCAs UCAs, A.C.O.S., DPG Offroad adjustable bumpstop plate, Daystar poly bumpstops.
Steering: Currie HD steering, C-ROK steering box reinforcement, OME stabilizer.
Armor/Recovery: T&T Custom belly skid, Mopar gas tank skid, JKS LCA mini skids, Rock Lizard Super Skink Sliders, Mopar 2" receiver, ARB Bull Bar/Ramsey REP 8.5 winch.
Drive train: D30 front axle w/Superior Chromo D30 axles & outter seals, D/S 4.56 R&P, ARB locker, Ruff Stuff cover. Ford 8.8 rear axle w/Superior Super 88 kit, Ford Motor Sports 4.56 R&P, ARB locker, SOLID cover, Russell stainless lines. Front and rear Tom Woods HD drive shafts, 242 x-fer case w/Tom Woods SYE.
Tires/Wheels: 33x10.5x15 BFG Mud Terrains on Alcoas.
Misc: Garvin Wilderness rack, Safari Snorkel, Redline Tuning hood lifts.
Awaiting installation: Autometer A pillar gauge pod, oil, water, & tranny temp guages, PIAA driving lights, Goferit tie-rod flip bushing, '95 Brake booster and M/C, M.O.R.E. Motor mounts, TnT Custom 1.5" Shackle.
Stroker Project: HO Block, '99 intake manifold, bored TB, 1" TB spacer, Dynomax Blackjack Header, Permacool electric fan.
mecompco is offline
post #8 of 8 Old 01-19-2011, 09:44 AM
jeepkid03
Winning
jeepkid03's Avatar
its probably the tailgate. If you open the tailgate you will see these rubber stoppers on both sides that the tailgate is meant to close on next to the tail lights. Mine were all cracked and nasty. This caused the tailgate to rattle at stoplights. I got new ones, adjusted them (they twist out) so the tailgate closes tightly against them, and haven't had the issue since.
-Josh
My 0331 Head Swap How-To Thread:
Build Thread:
jeepkid03 is offline
cherokee , exhaust , rattle
Why is my jeep starting to rattle? tv09 XJ Cherokee Technical Forum 7 01-07-2010 04:13 PM
The Jeep Anti-squeek/rattle Thread TwistedcaB- XJ/MJ Cherokee Non-Technical Forum 27 11-24-2008 08:48 PM
Rattle Rattle Rattle Rattletrap TreddyoXJ XJ Cherokee Technical Forum 5 04-16-2007 08:22 PM
Rattle/Thumping in back of jeep hunter3838 XJ Cherokee Technical Forum 14 11-08-2006 06:00 PM
Rear sound bar rattle? (Rattle bar?) Fix suggestions! Alexia XJ Cherokee Technical Forum 9 11-16-2004 09:07 AM
