Jeep popping noise (video inside) - JeepForum.com
post #1 of 9 Old 05-16-2012, 08:08 PM Thread Starter
jdest001
I need help diagnosing this popping noise. It only seems to happen when in 4lo and when climbing a steep incline. All u-joints and suspension components seem ok. The Jeep is a 1998 cherokee with a Rusty's 6.5" long arm lift and 33" tires. See video.
-White 1998 XJ
jdest001 is offline
post #2 of 9 Old 05-16-2012, 10:19 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Exactly where is the noise coming from ? If it is coming from the center of the Jeep, you probably need a new Transfer Case chain. If you watch, you will see the T-Case jump when the noise happens. You probably can feel it by holding the T-Case shift lever.
If the noise is coming from the front axle, your coil springs are probably binding on the bump stop cups.
CJ7-Tim is offline
post #3 of 9 Old 05-16-2012, 10:23 PM
Savanna
Mine does the same thing... I always thought I needed to extend my bumpstops
Savanna is offline
post #4 of 9 Old 05-17-2012, 05:31 AM Thread Starter
jdest001
Its hard to tell where it is coming from mainly because i cant duplicate the noise regularly, but it does seem to be coming from somewhere in the front.
-White 1998 XJ
jdest001 is offline
post #5 of 9 Old 05-17-2012, 10:02 AM
kg4kzv
1995 XJ Cherokee
Put it in 4lo and give it some gas with you foot hard on the brake and see if it pops then. Be careful doing this and make sure nothing is in front of you because the brakes won't hold you back in 4lo if you hit the gas a little too hard!!!
Chris
95 Cherokee SE 4.0, 5-Spd, 8.25;
6.5" Rusty's Lift, Atlas II Rims, 35x12.5x15 Wild Country,Rusty's Tube Bumper, Wilderness Rack
Rock Sliders, K&N Panel Air filter, PSC steering box,
I-ROK reinforcement kit, ORO U-TURN steering kit,Conversion Headlights/Silverstars And too much $$$
kg4kzv is offline
post #6 of 9 Old 05-17-2012, 11:13 AM
Elexwiz
1987 XJ Cherokee
Try going over the same hill in the video in 2wd.
1987 XJ 4.0 I6, Peugeot tranny, NP231, AA SYE, 8.25" 29 spline, Dana 30 (HP), Rusty’s 4.5 inch coils, BDS 5500 4.5" shocks, 5" junkyard bastard pack, Rusty’s Adj LCAs, RC Quick Discos, JKS BPEs (front and rear), Aussie Lockers (front and rear), Durango steering box, and Removable Doors!
Elexwiz is offline
post #7 of 9 Old 05-18-2012, 09:11 PM
Savanna
I really want to know what this is now...
Savanna is offline
post #8 of 9 Old 05-18-2012, 09:27 PM Thread Starter
jdest001
Me too haha. I dont get the noise in 4 low and holding the brake so i don't think it is the transfer case. The more i watch the video it seems to be suspension related, but what in the suspension could make that noise? I can fully flex the suspension without issue, but when it is put under load (when climbing a uneven steep hill) i get the popping.
-White 1998 XJ
jdest001 is offline
post #9 of 9 Old 05-18-2012, 09:50 PM
CJ7-Tim
CJ7-Tim's Avatar
CJ7-Tim is offline
bang , noise , pop , popping , suspension
Anyone else have a light knock at idle? Video inside ZJeepMI XJ/MJ Cherokee Non-Technical Forum 22 11-07-2012 04:47 PM
Can someone tell me if this is normal (video inside) Peace XJ Cherokee Technical Forum 8 01-13-2012 12:50 AM
Popping Noise 350zmarty XJ Cherokee Technical Forum 1 09-04-2011 12:58 AM
VOTE FOR NICK! cool video inside... check it out koolaid5 XJ/MJ Cherokee Non-Technical Forum 4 03-04-2011 11:04 AM
finally got the v8 into the XJ-- pics and video inside JMG2 XJ Cherokee Technical Forum 64 01-17-2011 01:37 PM
