Jeep not starting - JeepForum.com
post #1 of 6 Old 08-03-2013, 05:02 PM Thread Starter
jhamric2
1988 XJ Cherokee
Jeep not starting
I'm having an issue with my 88 Cherokee 4.0. 9 times out of 10, it starts. 4 times out of the 9, it starts at 2500 rpm then drops to normal. The other 5 no problem. But 10 percent of the time, it starts normal and runs up in rpm up to 2500 and wont go down. Then I shut it off and it wont start at all. Other times I would just let it sit for 30 minutes and it would start up normal. But today after starting it this morning and having the increasing rpm issue, I shut it off and tried restarting with no results. Its been 6 hours now.
jhamric2 is offline
post #2 of 6 Old 08-03-2013, 05:13 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Your TPS is taking a dive on you most likely.
But, before replacing and adjusting it, click on the link in my signature and do the procedures outlined in posts 1,2,and 3.
Post 8 explains how to adjust the TPS.
If you own a Renix Jeep, you'll want to check this out.
An index to over 30 write-ups can be found in the link below
My Jeep Technical Photos
cruiser54 is online now
post #3 of 6 Old 08-03-2013, 09:10 PM
carnuck
1984 J-Series Truck
Above the brake booster is a C101 connector on '87 and '88 XJs and MJs. When the Renix connections corrode (per usual) it acts that way. It could also be the fuel pump relay (mine did that before I swapped relays)
"Usually found in a Jeep near Reiter, WA"
FOR SALE STUFF
'81 Eagle wagon with upgrades $2500
'87 Comanche shortbox 4.0/AW4/NP242 on 33" tires $3500
carnuck is offline
post #4 of 6 Old 08-04-2013, 08:42 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
#2 post in the link in my signature.
post #5 of 6 Old 08-09-2013, 07:52 PM Thread Starter
jhamric2
1988 XJ Cherokee
Wasn't the TPS. Bought one, installed it, no difference. It started, but it started before I installed it. Went and spent $150 on a new Idle Stepper Motor. Haven't installed it yet, truck still starting. Hit and miss situation. Have the stepper and torx bit in truck just in case.
jhamric2 is offline
post #6 of 6 Old 08-09-2013, 08:35 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
So, rather than do the cheap and easy proven stuff, you decided to replace parts?
hard start , high idle , no start
