The Jeep Jeep's Build Thread - JeepForum.com
post #1 of 19 Old 04-20-2008, 10:41 PM Thread Starter
bigern26
1993 XJ Cherokee
Going commando build thread
Ok, i decided to finally start a build thread for my Jeep Jeep.
here is what i started out with
Bone stock 1993 Jeep Cherokee, 4.0HO, 4x4, 231 t-case,dana 30, chrys 8.25
when I first got it I put on some old steel rims I had laying around, different rear view mirror, header panel from a older xj, different lights up front, and pulled a dent.
Before:
After some work.
Today it was almost 70* here so I decided to do some work
white face guages, '98 mirrors, '98 headliner with built in speakers, '98 overhead console, Removed factory roof rack and fender flares.
'93 Cherokee Sport 2Door, 4.0HO, AX-15, NP-231, Dana 30, Chrysler 8.25
'98 mirrors and headliner with overhead console and built in speakers.
Set of old steel rims(not sure of model)
bigern26 is offline
post #2 of 19 Old 04-20-2008, 10:44 PM Thread Starter
bigern26
1993 XJ Cherokee
After taking off the flares i found alot of rust behind the passenger rear so when I get the lift and tires i will have to cut out more than planned and i am also going to weld in new rockers made from some tubing.
I am collecting lift part so I will be adding 4.5'' in a few weeks.
bigern26 is offline
post #3 of 19 Old 04-20-2008, 10:48 PM
ReconMill
Flat-4 Turbo
ReconMill's Avatar
2005
Get some paint for those wheels! As for the rockers, check out what EricsXJ did in his build thread if you havent already. Kick.... ***...
Kyle - I mod stuff®
2005 Subaru Legacy GT
ReconMill is offline
post #4 of 19 Old 04-20-2008, 10:52 PM
tdogg55555
tdogg55555's Avatar
Doing a good job man, Im diggin the guages, whered you get them, the 9 grand on the tach looks mighty tempting . Seriously though, them guages are pretty sweet.
96 Country...Weekend warrior
tdogg55555 is offline
post #5 of 19 Old 04-20-2008, 11:02 PM Thread Starter
bigern26
1993 XJ Cherokee
yeah i am going to get new lug nuts then im going to take the rims off and paint them.
The guages I got from gojeep for $10. just printed them out on photopaper
then glued them over, Really easy.
here is a link to the site where I got them
http://www.go.jeep-xj.info/Whitebground.htm
bigern26 is offline
post #6 of 19 Old 04-21-2008, 12:13 PM Thread Starter
bigern26
1993 XJ Cherokee
as for the rockers i am going to do something similar to what eric did to his.
bigern26 is offline
post #7 of 19 Old 04-29-2008, 06:56 PM Thread Starter
bigern26
1993 XJ Cherokee
Here are some pics of what i have so far. I will be doing a 4.5 inch lift and running 33's. I am doing a snorkel, maybe tj flares, a roof rack and rock sliders, and a military theme.
bigern26 is offline
post #8 of 19 Old 04-29-2008, 07:05 PM
eflores
1989 XJ Cherokee
adjustable trac bar any one
AEKDB
Leaky sunroofed XJ member #1
The United States of America July 4, 1776 - November 4, 2008 RIP
eflores is offline
post #9 of 19 Old 04-29-2008, 07:30 PM Thread Starter
bigern26
1993 XJ Cherokee
id have to say alignment since everything is stock so far.
bigern26 is offline
post #10 of 19 Old 05-14-2008, 10:34 PM Thread Starter
bigern26
1993 XJ Cherokee
Update........................
I got me some clear corners and put on a bumper I built today...
bigern26 is offline
post #11 of 19 Old 05-15-2008, 10:32 AM Thread Starter
bigern26
1993 XJ Cherokee
here is a pic of the mounting plate and where the clevis mount and face are welded up
bigern26 is offline
post #12 of 19 Old 05-22-2008, 10:52 PM Thread Starter
bigern26
1993 XJ Cherokee
Thanks for all the praises. Here are some more pics. I got a set of pro comp all terrains 33's from a friend. just had to put them on. I had to do a little cutting, they should clear really good when i get the lift in.
bigern26 is offline
post #13 of 19 Old 05-22-2008, 11:00 PM
jeeper01
Sweet Jeep. I like the way it looks also very nice build on the bumper, I recently put mine on they are sweet.
1998 Cherokee Classic... 2" BB on Moabs
1988 Cherokee Limited... 4.5" RC lift, RK longarms, on 31's. Several homemade skids.
jeeper01 is offline
post #14 of 19 Old 05-22-2008, 11:17 PM Thread Starter
bigern26
1993 XJ Cherokee
Thanks, It has been a slow process but its strting to come along.
bigern26 is offline
post #15 of 19 Old 05-23-2008, 06:59 PM
eflores
1989 XJ Cherokee
dude did you cut your pinch weld out in your back wells
AEKDB
eflores is offline
Jeep-a-gon Build Thread Arbslikewhoa XJ Cherokee Technical Forum 644 05-07-2012 09:10 PM
My build thread. My attempt on a SAFE build on a budget. xyimmyx XJ Cherokee Technical Forum 46 06-09-2011 02:50 PM
my 89' cheep jeep build thread... KentuckyXJ XJ Cherokee Technical Forum 8 05-24-2009 10:37 PM
Jeep build- up thread (pics) Timo_90xj XJ Cherokee Technical Forum 42 07-06-2006 12:57 PM
Something wrong with Jeep's record of my vehicle - wrong build sheet prior2 XJ Cherokee Technical Forum 16 12-21-2005 05:47 AM
