Jeep grand cherokee Seats Bolt on? - JeepForum.com
post #1 of 14 Old 03-16-2013, 09:25 PM Thread Starter
rosco219
if I find a set of leather seats for my XJ 2000 will they bolt right in?
rosco219 is offline
post #2 of 14 Old 03-16-2013, 09:48 PM
TJSE1997
Zj and wj will. The seats will bolt on to the xj seat frames
TJSE1997 is offline
post #3 of 14 Old 03-16-2013, 09:51 PM
Motorcharge
95+ XJs, WJ and ZJ seats will bolt directly to seat bases.
|SOLD|
| June 2015 COTM |
Motorcharge is offline
post #4 of 14 Old 03-16-2013, 11:30 PM
cory4um
I will add..
Only the front seats will bolt in.
The rear however will need slight modification, drilling.
cory4um is offline
post #5 of 14 Old 03-17-2013, 12:04 AM
Nubster
Drilling of what? The seats or the Jeep?
"When I Die, Bury me in my Jeep. 'Cause it's never been in a hole it couldn't get out of!"
White Jeep Club #132
Nubster is offline
post #6 of 14 Old 03-17-2013, 06:37 PM
ECL
There are some threads out there on this. The XJ rear seat back is hinged on the sides of the backrest; the ZJ (w/ the 60/40 split seatback) has hinges that bolt to the floor board. The seat base likewise isn't a direct drop in and apparently also needs to be taken apart and some foam removed to allow the doors to close.
I didn't change the seats but did scavenge the rear seat headrests off a ZJ and installed them on mine. Threads out there on this as well.
ECL is offline
post #7 of 14 Old 03-17-2013, 07:04 PM
cory4um
Both.
As said above. You will be drilling holes for the new mounts.
I also drilled plastic on the rear seat (where your but goes) as you have to pop the fabric off, trim some foam and drill holes for the fabric to reattach to.
Its not to difficult.
cory4um is offline
post #8 of 14 Old 03-18-2013, 09:25 AM
Nubster
Cool. Thanks. I knew about the bolt in fronts but didn't realize the G.Cherokee rear seat would fit as well. Once I get rid of my WJ and get back into an XJ, I'm definitely replacing the seats. Not that the XJ fronts are bad, but the ZJ/WJ are better. The rear seat on the other hand...that's a different story.
Nubster is offline
post #9 of 14 Old 03-18-2013, 09:38 AM
JeepRide
JeepRide's Avatar
wj zj seats also sit about 1 inch higher than xj seats.
98 xj 4.0L 231 / aw4 /8.25/3.55
31x10.50 a/t 3 inch bastard lift
JeepRide is offline
post #10 of 14 Old 03-18-2013, 09:46 AM
Nubster
hmmm...that might not be such a good thing then for me since I'm 6'2" and usually like to set a little lower in the vehicle. I'll still definitely give it a try though.
Nubster is offline
post #11 of 14 Old 03-18-2013, 10:11 AM
cory4um
Yeah, I wouldn't do it thn.
I'm 5'10 and just have enough room.
My taller friends on the other hand......
cory4um is offline
post #12 of 14 Old 08-30-2013, 05:58 PM Thread Starter
rosco219
96+ zjs what year did they stop with the zj model?
rosco219 is offline
post #13 of 14 Old 08-31-2013, 02:53 PM Thread Starter
rosco219
96+ to what year will fit is what i am asking..
rosco219 is offline
post #14 of 14 Old 09-02-2013, 07:26 PM
chris87xj
JF Admin
chris87xj's Avatar
1987 XJ Cherokee
Grand Cherokees, ZJ (1993 - 1998), WJ (1999-2004).
***Chris***
chris87xj is offline
