#76 | |
Yeah, I agree. Or, better yet, replace them with some NICE offroad lights, hehehe!!
My Jeep: 1996 Cherokee Country 4.0L A/T 4WD (Check under my name for anything else!)
My Bike: Suzuki Bandit 1200s (fox rear shock, hotshot stage 1 header, black duct tape * 100!) |
#77 |
Hose gasket looks awesome...
2000 Jeep Cherokee Classic 1992 M101 CDN2 1/4 Ton Off-road Trailer. 90% Daily Driver 100% Fun! ____=__= l l ,[_____], l---- L -[]lllllll[]- ()_) ()_)--o-)_) |
#78 |
Youngin'
i vote you keep the running lights. just grab a generic set from JC Whitney or something and toss them on
http://www.jcwhitney.com/Running-Lights/GP_2003371_N_111+200729928+600002879_10101.jcw
2001 Dodge Ram 2500 SLT 4x4 5.9L Cummins Turbo Diesel "The Tow Rig" 1988 Jeep Comanche 2.5L 4cyl - 4 speed manual 2001 Jeep Cherokee Sport
4.6L Golen Engine Stroker 6.5" TnT Customs Longarm Kitl Ford 8.8" w/ disc brakes l 6.5" Rock Krawler Coils l TnT Customs HD Trac Barl Omix Ada HD SYE l 1" UBEsl CV Driveshaft l 35" Maxxis Bighorns l 15 x 8 Cragar Black Soft 8s (4" BS) l High Clearance Shock Mounts l 4 - BAJA off road lights l TnT Customs D30 Truss l Hidden Hitch l ARB Front Diff Cover l AJs Custom Front Bumper l SONY Xplod stereo l Alpine Speakers l TnT Frame StiffenerZ l 22" RE SS Brake Lines l 1.5" TnT Customs Boomerang Shackles l HP D30 l JKS Mini Skids and Sway Bar Brackets l TnT Customs OTK Steering |
#79 |
forum supporter
If you are near a truck stop, you can pick up replacement lights there that are identical to the ones on it.
#80 |
i think if you are going to have any lights at all on it, they should be off road lights. otherwise, leave them off. it would just look cleaner that way in my opinion.
96 XJ SE 4 door Moss Green Green Jeep Club Member 333 |
#81 |
Cool bulid Iam interested in seeing how it turns out.
1989 XJ, 5spd, np231 with bjconversion SYE , re3.5, 33x12.5r15 BFgoodrich ATS, D30 F, Dana 44 from 87 with 4.56s, Custom front bumper. 94 yj: stock everything and 4 angry squarrels under the hood. |
#82 |
interesting...
98 xj 4.0 3 inch lift 31' bfg mts no rear swaybar/jks upfront powertrax no slip in rear [url]http://www.youtube.com/watch?v=daMEytgMy-Q[/url] |
#83 |
Under Construction
Are you done yet!? I really want to see this thing when it's done!
#84 |
Yes Man!
put some offroad lights up front and leave the red marker lights in the rear.
#85 |
millhouse has the right idea!
thats actually what im hoping to do. I like the red lights in back, but the orange in front just yells out 18 wheeler/big o' camper/wth is that?? lol Plus both sets of lights are smashed, and the plastic was so old, it crumbled when I touched them. I would have to purchase all new lights... but I would definitly consider putting the 5 red back in the rear. I also have four KC Daylighters... I use to have two on the rack and two on the bumper. VVVV ![]() But I want to be able to put the two back on top, I just have no clue how yet. Im thinking I might have to build something that attaches to the westfalia roof, cause that has to move forward and up when it opens, and theres no room for the lights seperate from that, unless the lights where to move with it. Anyway, Im uploading some pics as I speak.
The Pop Top Camper Thread CLOTHIER TRANSMISSION & TRACTION PRODUCTS Tire Chains for 31" up to 49" tires Transmission Adapter Kit, GM/Chevy "4 bolt main" to SAE #2 |
#86 |
Ok, so I woke up early this morning and had a fresh start on the project. The reason its taking so long is due to the fact of sanding, waiting for the silicone dry, and waiting for the paint dry. Its all trial and error so far with fitting and trimming the roof, and the rest is just waiting for things to dry up enough so I can continue working. Everything says 24 hour dry time... and thats in good warm conditions... Its about 10 degrees here... so its hard enough keeping the garage atleast at 60...
![]() Ripped out the lining and excess canvas... ![]() ![]() Found some more broken pieces! yay!!! haha... ( it looks like who ever owned it also had some issues with the roof :X ) ![]() Cover the vent hole. Going to install a new vent later on.... ![]() ![]() Had to build some supports for the brackets that the roof will be piviting on. Reason for this is due to the issue that my top rails on the cherokee are actually in the direct spot where the brackets were located. And since im keeping the rails on the cherokee for sealing reasons.. Ill have to move the brackets in towards the center about an 1 1/2 to 2 inches... ( I think this will also be a little stronger) ![]() ![]() ![]() Silicone
#87 |
![]() Sanding, Washing... ![]() ![]() Wet paint. will dry satin black....
#88 |
Infowars.com
Very, very cool idea.
What is it about Ron Paul?
#89 |
Yes Man!
looks alot better now with the paint.
#90 |
I wonder if you would have been better off to rivet the aluminum strip on the inside and lay some epoxy gel coat over the outside seam? Perhaps on future versions. Looking great!
Also, any way you can create a mounting system that will bolt directly to the existing threaded receives in the factory roof rails? It would be totally trick if you could build this whole thing and make it compatible with factory mounting points! You have a 98, so I believe your factory rails runs the full length. I'm getting so excited to see how this things turns out. Also, if it were me, I'd redo all that wood inside with oak or maple. Teak would probably be overkill.... |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
