Quantcast Jeep-a-gon Build Thread - Page 2 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > Jeep-a-gon Build Thread
GR8TOPS Introduces the Exogate HD Tire CarrierTruck-Lite's New LED Headlamp SeriesRUBICON EXPRESS Lift Kits and Accessories Available at Bas
Old 01-05-2009, 07:36 PM   #16
jmundale
1981 J-Series Truck
looks really good - hope you never need to park in a garage though
those bumper brackets are seriously Beefy
[SIZE="3"]live free or die[/SIZE]
[SIZE="1"]98xxx, 33's, 4.10's, and plenty of flaky red stuff[/SIZE]
jmundale is offline   Reply With Quote
Old 01-05-2009, 08:48 PM   #17
ReconMill
Yes Man!
ReconMill's Avatar
2005
Originally Posted by FitchVA View Post
i literally said "holy mother of god" when i scrolled down to see these
x2 holy crap i didnt see those. Those things probably weigh as much as my bumper. They are awesome though, overkill, but awesome.
Kyle - I mod stuff®
SOLD!!! - 1999 XJ Build Thread
ReconMill is offline   Reply With Quote
Old 01-05-2009, 09:15 PM   #18
Pumbaa
Junior Member
2008 WK
Don't worry, its a Jeep. This looks like a crazy amazing idea. Just wait until you go on your next wheeling outing and people say "WTF?" You just smile and climb into your (hopefully) weatherproof sleeping cabin.
The light bar roof protection sounds good. I agree with you on waiting until the roof is on so you can fab it up to check the look.
Keep it up, this looks like a
Pumbaa is offline   Reply With Quote
Old 01-05-2009, 09:43 PM   #19
Sir_Ken
2010 JK Wrangler
I like the concept, nice job so far.
2010 Jeep Wrangler Sport
Automatic/Hardtop/2-Door
Cherokee Roof Rack
Kenco Roof Basket
Sir_Ken is offline   Reply With Quote
Old 01-05-2009, 11:45 PM   #20
EricsXJ
The Post man
EricsXJ's Avatar
Nice idea. Its pretty cool to see something that hasn't been done (to my knowledge) before! A lot of guys like the roof-top tents, and others have cut the top of the Cherokee off before but I have yet to see this done.
Keep going with it and I look forward to seeing pics of the progress!
Eric
2000 XJ "PROJECT RUBICON" lifted, locked, shafted, running 35's, 4.56 gears, pair of ARB's, and stock AM/FM cassette
My website - EricsXJ.com
EricsXJ is offline   Reply With Quote
Old 01-06-2009, 12:05 AM   #21
Mr_Random
1986 XJ Cherokee
Originally Posted by Arbslikewhoa View Post
I am also currently building a winch bumper for the truck... ( i like to keep myself busy :P)
I designed some bumper brackets and had tarco steel cut them out of 1/2" steel on their plasma cutter. I picked them up yesturday.
Ha, if it's as well engineered as those things I'm sure everything will work out for you!
can't wait to see you start tearing it apart! good luck!
Originally Posted by ceb0217;
I live with in an hour of the coast so getting sea foam is easy, but isnt the salt bad for the fuel system??? and how about the people that live farther away can you just foam up water and sea salt ??? if so what kind of mix do I use ??? 1table spoon to a gal of water??? and then how do I "foam it up" mabe a little soap????
Jeepus buildicus:
http://www.jeepforum.com/forum/f22/86-xj-w-mpi-budget-re-build-757079/
Originally Posted by jgorm View Post
Using pure N2 is a total waste of money considering you can get 78% nitrogen for free.
Mr_Random is offline   Reply With Quote
Old 01-06-2009, 10:31 AM   #22
RussoGuitar
1989 XJ Cherokee
For the steering box bolts, make sure to soak the bolts with some pb from the steering box end, you can see them sticking through.. you can try some heat to but make sure you isolate it to the area the bolt goes through. If they break then pull the box and continue treating the bolts, then get some vice grips on there and you should be able to turn them out. Your going to want new bolts anyway since you're using half inch thick bumper brackets.
RussoGuitar is offline   Reply With Quote
Old 01-06-2009, 11:34 AM   #23
Vassago
The Bike Guru
Vassago's Avatar
awesome awesome idea! as for being able to put a rack on it and support the weight, you could reinforce the pop top itself and run linear actuators to raise and lower it. i down you'd be able to lift the rack loaded but i'm assumign your camping gear woulf be down and in use at that point.
"He almost broke the land speed record in 1977, popular opinion amongst his team was that his beard caused to much wind resistance. He would have shaved it… No, no he wouldn’t have."
MY BUILD THREAD: http://www.jeepforum.com/forum/f22/build-thread-year-later-01-xj-643365/
My Photography Paul Lehr's Flickr
Vassago is offline   Reply With Quote
Old 01-06-2009, 02:20 PM   #24
Arbslikewhoa
ok, Sadly, my alarm didnt go off, i must have set it wrong or something.... so i woke up around one this evening and just returned from yanking the other section of the roof. This section was anchored to the roof and was used as a storage rack... but since the front piece only has the front side that folds down (the back is cut straight across) im going to have to mend the back of the second section to the pop top so it fits all around.
The Pop Top Camper Thread
CLOTHIER TRANSMISSION & TRACTION PRODUCTS
Tire Chains for 31" up to 49" tires
Transmission Adapter Kit, GM/Chevy "4 bolt main" to SAE #2
Arbslikewhoa is offline   Reply With Quote
Old 01-06-2009, 02:28 PM   #25
Arbslikewhoa
to eric:
I looked all over the interenet and couldnt find anything like this. They make them for f/s land cruisers in europe for like 6 grand???? and even thats hard to locate and find. Plus their kits arnt just a pop top, but an entire kit that cuts off the top and rear and kinda just puts a large box in side of the truck that extends the top and rear about 4 - 6 more feet.
So, im hoping I can complete the project where it can be done cheaply, be fully functional, and look like it was made for the truck as well. That way maybe other folks can do the same type of thing.
Old 01-06-2009, 03:37 PM   #26
Whsperz
I am looking forward to see how this progresses. Great idea!
2000 TJ, 1998 Grand Cherokee ZJ, 1983 CJ8 Scrambler (DJ Alaskan Postal Jeep) (FOR SALE!)
www.militaryjeepers.com
University of Louisville
Whsperz is offline   Reply With Quote
Old 01-06-2009, 05:07 PM   #27
TJQ
This looks cool. Subscribing to watch it progress.
TJQ is offline   Reply With Quote
Old 01-06-2009, 06:15 PM   #28
scoot08
i cant wait to see this done... it seems like a great idea
scoot08 is offline   Reply With Quote
Old 01-06-2009, 07:42 PM   #29
Owanin
This seems like an awesome project!
I can't wait to see how the finished product turns out
Subscribed and Crawled!
Red Jeep Club Member #409
Originally Posted by dogbluedrummer
4 hi and hammer down!
Originally Posted by Big_Fisch View Post
POT??!! Calling passenger POT?? Is there a POT here?? How about KETTLE?? Passenger KETTLE??
Oh well, they're both black.
Owanin is offline   Reply With Quote
Old 01-06-2009, 07:58 PM   #30
Brandon314159
Interesting, you chose a 1-year only Westfalia top! That is from a 1972 bus...sweet score!
Looking forward to seeing this, tops that are not white blend right into the car's body. I think you've got it.
Nice thing is, if it rolls, just replace the fiberglass
-Brandon
1965 Unimog
Brandon314159 is offline   Reply With Quote
Glock Forum
