Quantcast Jeep-a-gon Build Thread - Page 11 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > Jeep-a-gon Build Thread
Truck-Lite's New LED Headlamp Series4.25" 97-06 Jeep TJ Wrangler Lift Kit - NO SYE NeededRuffstuff Axle Simple Swap Kit!
Old 01-14-2009, 02:54 AM   #151
Arbslikewhoa
actually, I was thinking about it... Maybe I can make some kind of bracket coming from the a pillars that the light can connect to that would push the light far enough in so the snorkel wouldnt be an issue... But i just dont really care to see my lights in front of my window. Ill see what I can do. I might start that tomorrow as well.
The Pop Top Camper Thread
CLOTHIER TRANSMISSION & TRACTION PRODUCTS
Tire Chains for 31" up to 49" tires
Transmission Adapter Kit, GM/Chevy "4 bolt main" to SAE #2
Arbslikewhoa is offline   Reply With Quote
Old 01-14-2009, 03:48 AM   #152
1995sport
1995 XJ Cherokee
you may also be able to find decently priced weatherstripping at an RV repair / supply company.
1995sport is offline   Reply With Quote
Old 01-14-2009, 03:49 AM   #153
Donerstude
Donerstude's Avatar
1989 XJ Cherokee
For fabric to line the top ,I used some ordinary felt my wife got me from a joanns fabric store to cover the inside of a camper I had on my last truck. with some super 90 spray glue it stuck very well. the felt went around corners and bends easily and came out looking very good.
I love this idea i have owned several old popup camper buses and can relate to your desire. Keep up the good work.
Donerstude is offline   Reply With Quote
Old 01-14-2009, 09:26 PM   #154
HowIRoll
Great idea man. And I second the idea of having a lip that come up on the inside of the top to keep the water out.
I will be following this thread! You have a lot ingenuity and some balls to cut that roof. Mad props go out to you!
Consider it CRAWLED.
Check out my build thread: http://www.jeepforum.com/forum/showthread.php?t=503112
http://longhornfabshop.com/
HowIRoll is offline   Reply With Quote
Old 01-14-2009, 09:41 PM   #155
Arbslikewhoa
Old 01-14-2009, 09:54 PM   #156
raypla
I'll keep an eye out for ya, definately unique
99 XJ 4.0 D30 29sp 8.25, K&N, Kellys WIP main 5 wires 1AWG http://www.kelleyswip.com/price.html, Banks header, Stainless Magnaflow catback, cat, 2" OME lift JC1B Leafs, JKS quicker discos, 30X9.5X15 Cooper STT's, 62mmTB http://www.thefastman.com/Throttlebodies40.asp, Cibie E-codes with 55/60 Osram bulbs, Alpine 7563 Deck, Infinity Perfect 10" Cubby, JBL GTI 180.2 400wX1 rms, 6.5 Perfect components rear bar, front: Boston Acoustic Pro series 5.5 Infinity reference amp 111wX4 rms, Optima Yellow
raypla is offline   Reply With Quote
Old 01-14-2009, 09:54 PM   #157
MattyO
doesnt look like its sealed to tight in the back,or is it just me??
MattyO is offline   Reply With Quote
Old 01-14-2009, 10:24 PM   #158
Mr_Random
1986 XJ Cherokee
Yeah, looks like it, but he's trying to sort out all those different minor things I'm sure.
I can think of a couple major steps left;
Interior cage/structure (already got part of that done with that roll bar?)
Tent folding
Some kind of insulation and a cloth cover
Inside lip/seal
Still need to fix that crack?
Hammock
Those are just pertaining to the project itself, past that you want to build some kind of protection and somewhere to mount your hella's, right?
I don't think this would work on a rig built any less than yours, I mean it's not like you're starting from a basic cherokee, you've already got a VERY nice foundation, therefore this mod doesn't seem out of place at all (despite being incredibly unique, experimental, and innovative)!
Originally Posted by ceb0217;
I live with in an hour of the coast so getting sea foam is easy, but isnt the salt bad for the fuel system??? and how about the people that live farther away can you just foam up water and sea salt ??? if so what kind of mix do I use ??? 1table spoon to a gal of water??? and then how do I "foam it up" mabe a little soap????
Jeepus buildicus:
http://www.jeepforum.com/forum/f22/86-xj-w-mpi-budget-re-build-757079/
Originally Posted by jgorm View Post
Using pure N2 is a total waste of money considering you can get 78% nitrogen for free.
Mr_Random is offline   Reply With Quote
Old 01-14-2009, 10:25 PM   #159
WyoZJ
1994 ZJ
Wow. Great work. That thing is so sweet. Want to make one for my zj?
WyoZJ is offline   Reply With Quote
Old 01-14-2009, 11:08 PM   #160
srmitchell
Awesome work.
If it fails, or you don't like it, you can always install a skyslider canvas setup in it's place.
Great idea.
I have an xj and it is blue
srmitchell is offline   Reply With Quote
Old 01-15-2009, 12:53 AM   #161
Arbslikewhoa
That was in the tractor supply parking lot. I was picking up some bolts for the rear roll bar which I just finished installing. Pretty simple obviously.. its nice having something that was already built. I wanted to take the pictures to show what the roof will look like on a normal basis.
P.S. When I took the picture.. it was 10 degrees out side with a wind chill of -8? or something like that. I drove it down the highway at about 55 mph and had no troubles staying warm. Tonight I also drove it through a small snow storm. No leaks (not of snow anyway) and all the snow has melted off, still with no leaks.
I went and looked at some more fabrics.. I also found a replacement vanagon canvas for this exact pop top for $135.
Pros...
Made for the roof, has the zip down windows (like a tent), Will save tremdous time, same color on both sides
Cons... A lighter grey (I think it might be too light).. I really wanted to use black, about 50 - 70 bucks more (if I do my calculations right), Takes a week or so to be shipped here, Not as water proof as the materal i found and not as thick.
And the back has a gap on each side because the back of the cherokee actually comes in just a tid bit more then the front, where the fiberglass is perfectly square. But the rails on the side keep the water out, and after I add my additional seal and water proof canvas, im not too worried about it.
Old 01-15-2009, 12:55 AM   #162
1995sport
1995 XJ Cherokee
Should be able to dye the canvas, and then re-water proof it.
Old 01-15-2009, 01:27 AM   #163
Mr_Random
1986 XJ Cherokee
does the canvas just fold up on the inside of the roof? I mean, if so; it wont be visible most of the time, and it may look good as a two/off-tone scheme.
Did you solve the cracked/cut top problem then? You say it isn't leaking, so I'm presuming you did fix it...
Jeepus buildicus:
http://www.jeepforum.com/forum/showthread.php?t=757079
Old 01-15-2009, 01:45 AM   #164
Arbslikewhoa
I caulked it for now. I still want to do the vent but figured I could get it out on the road and fix the other issues before class starts. Plus, im getting pretty tired and slowing down a bit...
Old 01-15-2009, 05:01 AM   #165
chris87xj
Jeepaholic
chris87xj's Avatar
1987 XJ Cherokee
Slick project Arbs. Check this link, it'll get you fired up again. I'm thinking you could beat the heck out of their price and give em a run for the money in the market.
http://www.earthroamer.com/tab_xpedition_vehicles/xvjp1_overview.html
***Chris***
JeepForum.com/IndyORV@Redbird-SRA
2009 COTY
Originally Posted by wgirvine View Post
You want my opinion? Ok… Shut the hell up... That’s my opinion.
chris87xj is offline   Reply With Quote
Glock Forum
