Jeep fire after swap, Rough Idle Help - Page 2 - JeepForum.com
post #16 of 18 Old 03-26-2013, 05:54 PM
ComancheKid45
1988 MJ Comanche
The MAP sensor hooks up to the throttle body.
96 XJ Country
ComancheKid45 is offline
post #17 of 18 Old 03-26-2013, 06:03 PM Thread Starter
Dennis88
1988 XJ Cherokee
Ok well that parts right then
Just found somthing out.. While spraying tb cleaner into Tb while motor was running the idle got way better... Also I could rev the motor by hand while spraying. If I stopped spraying idle got worse and no throttle response. I assume bad injectors or regulator. Pump is good I know for a fact.
Any input on this new info would be appreciated
Dennis88 is offline
post #18 of 18 Old 03-31-2013, 06:02 PM Thread Starter
Dennis88
1988 XJ Cherokee
Update. I'm stumped. I re did injectors. Swapped dizzy out. Fuel pressure reads 39psi. Swapped out tps and iac. New plugs new wires. What the hell. Rough idle. Idk if its missing or not.i have no throttle. If I give it gas it pops in intake and stumbles and sputters. Sounds like it has a aggressive cam. Grounds are good
Help please
Dennis88 is offline
