Jeep dying while driving. - JeepForum.com
post #1 of 10 Old 05-15-2013, 02:48 PM Thread Starter
cucster01
So the other day I drove about 2.5 hours highway with no problems from Co. Springs to Keystone but as soon as I got into town my jeep just died on me. It has been doing this ever since then, I can start it up just fine and don't have any power issues as all the guages and stereo are still working but when I start driving it just dies on me, power still on. 2001 jeep cherokee sport. Please help, any thought would be useful.
cucster01 is offline
post #2 of 10 Old 05-15-2013, 03:34 PM
grainofsalt
Check your crankshaft position sensor Also called CKP.
grainofsalt is offline
post #3 of 10 Old 05-15-2013, 04:42 PM Thread Starter
cucster01
I've read and heard a lot about how this could be the problem but I have no problem starting and i've got no guage reading issues and from what i've read those would be happening. I am new to diagnosing issues however so I could be wrong. I'm actually curious if it could be my coolant temp sensor?
post #4 of 10 Old 05-15-2013, 04:46 PM Thread Starter
cucster01
I actually went for a test drive just today and just a mile or so out and it died on the way but I then Unplugged the Coolant Temp Sensor for the drive back and had no issues. thoughts?
post #5 of 10 Old 05-15-2013, 04:55 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
The Coolant Temperature Sensor will not cause stalling. The crankshaft position sensor should be your first suspect. The O2 sensors should be your second suspect.
CJ7-Tim is offline
post #6 of 10 Old 05-15-2013, 05:41 PM
tjwalker
It's the crank sensor!
tjwalker's Avatar
I agree that the crankshaft position sensor is absolutely the primary suspect. I've seen many with the exact same symptom as you describe.
Testing can be done, but with the way it fails for you, will probably not be of any value. You do NOT have to have any gauge issues to have a faulty crank sensor. Some do, but maybe only a third of them or so.
If you do buy a crank sensor, do yourself a big favor and buy a Mopar unit from Jeep. Aftermarket crank sensors are very "hit and miss" with a whole heck of a lot of miss. I will not install nor will I recommend anything but a Mopar crank sensor. Why take the chance for the most important sensor on your engine?
Search and you will find many threads of people that have suffered with aftermarket crank sensors. Don't be that guy.
99 Cherokee, 4.0 AW4, NP242
Past Jeeps: 49 Willys, 81 Scrambler, 88 Comanche
Without "data", all you have is an opinion!
tjwalker is offline
post #7 of 10 Old 05-15-2013, 06:14 PM Thread Starter
cucster01
I don't disagree with your advice however i've read that a faulty temp sensor can cause the engine to run rich which could cause stalling and that it could read that the engine was overheating when it wasn't causing it to die. thoughts?
post #8 of 10 Old 05-15-2013, 06:29 PM
CJ7-Tim
CJ7-Tim's Avatar
I think you probably need a genuine Jeep CPS. I have owned 5 1997-01 XJ Cherokee, and 4 of them needed a new CPS. One needed a new Coolant Temp Sensor, and other than running funny, it never stalled until the CPS failed.
CJ7-Tim is offline
post #9 of 10 Old 05-16-2013, 01:54 PM Thread Starter
cucster01
So I'm gonna replace the CPS next, the coolant temp sensor helped a lil' at first seemed good but it's back to it's old problems now. Hopefully the CPS fixes my issues.
post #10 of 10 Old 05-16-2013, 03:10 PM
79chiefs
1988 XJ Cherokee
Try ASD relay, it is cheaper if it is bad and takes 2 seconds to test. Switch it with another relay and if the problem goes away it was the relay.
99WJ Laredo I6-A 2wd
88XJ-Building on a budget.
95 E34 540i-DD
79chiefs is offline
