Jeep Cylinder Head - JeepForum.com
post #1 of 3 Old 06-23-2013, 08:32 AM Thread Starter
Cannonlbz
Jeep Cylinder Head
Hey, I'm replacing the head gasket in my 2001 Jeep Cherokee that I just bought with 89000 miles. Depending on the condition of the head, I was wondering if any one knew if any companies sell performance heads for the Jeep 4.0L. Tried searching and nothing.
Cannonlbz is offline
post #2 of 3 Old 06-23-2013, 08:59 AM
Newtons3
Newtons3's Avatar
Cleggs Machine, Titan Engine, Patriot Performance, 505 Performance, Hesco.
Newtons3 is offline
post #3 of 3 Old 06-25-2013, 06:28 PM
tjwalker
It's the crank sensor!
tjwalker's Avatar
The head itself fails way more often than the head gasket on the 00-01. How was this diagnosed?
The factory 0331 head has a known casting defect between cylinders 3-4. You do NOT want to put that head back on your engine!
Clearwater Cylinder Head has a good redesigned replacement head if you want to go with stock.
Also know that if your issue is the head and it wasn't caught soon enough, you will most likely have significant bearing wear throughout the engine.
Educate yourself about the 0331 head. Lots of information online about it. Here is one good link. Good luck and keep us updated!
http://www.jeepsunlimited.com/forums...d.php?t=391831
99 Cherokee, 4.0 AW4, NP242
Past Jeeps: 49 Willys, 81 Scrambler, 88 Comanche
Without "data", all you have is an opinion!
tjwalker is offline
