Jeep cut out, turns but wont start, no gauges work but dash lights do, 4.0 XJ 1997 - JeepForum.com
 1Likes
post #1 of 29 Old 05-29-2012, 02:24 PM Thread Starter
LOIIIIIIIOJ
FIXED WAS CPS PLEASE READ ON FOR POSTS THAT HELPED IDENTIFY AND FIX THE PROBLEM
Hi,
4.0 XJ Cherokee Limited 1997
Drove 4 miles -ok. started it an hour later and it cut out 30secs later, i restarted it and drove 4 miles. Then it cut out and hasn't started since.
Battery was strong
Starter turns
All usual electrics work except the gauges on the dash - no batt, no fuel, no temp, no pressure. dash lights work fine and the security icon appears ok.
OK JUST CHECKED NO CHECK ENGINE LIGHT AND NO MPG DISPLAY
Ive had a quick look at all the visable fuses and they look ok'ish
what do i need to check and in what order??
the weird thing is the no dash gauges too?
Any help very much appreciated
Thanks
alsjeephead likes this.
LOIIIIIIIOJ is offline
post #2 of 29 Old 05-29-2012, 02:51 PM
BUSA
Cam sensor dealer only after market one wont work
BUSA is offline
post #3 of 29 Old 05-29-2012, 03:21 PM Thread Starter
LOIIIIIIIOJ
Would that cause the CEL light not to light up?
Thanks
post #4 of 29 Old 05-29-2012, 03:25 PM
BUSA
Mine didnt come on either driven dwn the expressway no power to nothn
BUSA is offline
post #5 of 29 Old 05-29-2012, 03:27 PM
BUSA
Sometimes there is no signs of ck engine light make sure you buy the sensor from the dealer
BUSA is offline
post #6 of 29 Old 05-29-2012, 06:19 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
The CPS is the most coomon cause of the symptoms you describe. Some simple testing and diagnsotics will include or exclude the CPS.
If you need a new CPS, buy a genuine Jeep CPS.
The most likely cause of it cranks and cranks but won't start up is the Crankshaft Position Sensor (CPS) located on the transmission bell housing. Often this part is also referred to as the CranKshaft Position Sensor (CKP) CPS/CKP failure is very common. The CPS/CKP can stop working with no warning or symptoms and the engine will not run or the engine may randomly stall for no apparent reason.
Typical Symptoms –
- Starter cranks and cranks but engine won't start up and run.
- Fuel gauge and voltage gauge may not work or display properly.
- You sometimes will have No Bus on the odometer after 30-60 seconds.
- A failed CPS/CKP may or may not throw a CEL trouble code.
- No spark at the spark plugs.
- Fuel pump should run and prime for 3-5 seconds.
Begin with basic trouble shooting of the start and charge systems. Remove, clean, and firmly reconnect all the wires and cables to the battery, starter, and alternator. Look for corroded or damaged cables or connectors and replace as needed. Do the same for the grounding wires from the starter to engine block, and from the battery and engine to the Jeep's frame/body. You must remove, scrape, and clean until shiny, the cable/wire ends, and whatever they bolt to. Jeeps do not tolerate low voltage, bad connections, or poor grounds and the ECM/ECU may behave oddly until you remedy this.
Exchange the fuel pump relay and the ASD relay with one of the other similar ones in the PDC to eliminate the relays as the cause of the no-start. Check the ASD relay fuse.
Confirm that the fuel pump to runs for 3-5 seconds when you turn the ignition key to ON.
Eliminate the NSS as a cause of no start. Wiggle the shift lever at the same time you try to start. Put the transmission in Neutral and do the same. Do the reverse lights come on when the shifter is in Reverse?
Inspect the wires and wire connectors at the O2 sensors on the exhausts pipe. A short circuit from melted insulation or from broken O2 sensor wires can blow a fuse and the ECU/ECM will loose communication. Don’t get tunnel vision and assume the sensor is bad (unless it tests bad with a meter). Damaged wiring or a dirty connector can inhibit the signal from making it to the computer. Inspect/test/clean/repair wiring or connectors as necessary.
If the CPS/CKP is failed sometimes the OBD-II trouble code reader cannot make a connection to the ECU/computer or cannot read Check Engine Light/MIL codes because the CPS/CKP has failed. Disconnect the code reader, disconnect the CPS/CKP wire connector, and reconnect the code reader. If the code reader establishes contact with the ECU and scans, your CPS/CKP is failed and needs to be replaced.
Crank Position Sensors can have intermittent “thermal failure”. This means that the CPS/CKP fails when the engine gets hot, but works again (and will test as “good”) when it cools back down.
Diagnostic steps to confirm the CPS is the cause of your no-start
1) You should be able to verify a bad cps, by unplugging it, and turning the ignition key to on. If the voltage gauge and/or the fuel gauge now display correctly and/or the No-Bus is gone, replace the CPS.
2) If the CEL does not come on when the key is turned to the RUN position... then the CPS/CKP is bad.
3) Unplugging and reconnecting the CPS sensor where it connect to the main harness near the back of the intake manifold usually resets the ECU and if the jeep fires right up after doing this you can bet that the CPS is faulty and needs to be replaced.
The 2000 and 2001 will have the CPS in the same location on the bell housing, but the wire connector is near the Transfer Case, not as shown in the diagram below. Simply follow the wire from the sensor to the connector.
CPS Testing
Crankshaft Position Sensor Connector (CPS/CKP)
TESTING PROCEDURE 1991 – 2001 4.0L H.O. engines
1. Near the rear of intake manifold, disconnect sensor pigtail harness connector from main wiring harness.
2. Place an ohmmeter across terminals B and C (See Image). Ohmmeter should be set to 1K-to-1OK scale for this test.
3. The meter reading should be open (infinite resistance). Replace sensor if a low resistance is indicated.
TESTING PROCECURE for 1987 – 1990 4.0 L engines
Test # 1 - Get a volt/ohm meter and set it to read 0 - 500 ohms. Unplug the CPS and measure across the CPS connector's A & B leads. Your meter should show a CPS resistance of between 125 – 275 Ohms. . If the CPS is out of that range by much, replace it.
Test # 2 - You'll need a helper for this one. Set the volt/ohm meter to read 0 - 5 AC volts or the closest AC Volts scale your meter has to this range. Measure across the CPS leads for voltage generated as your helper cranks the engine. (The engine can't fire up without the CPS connected but watch for moving parts just the same!) The meter should show .5 - .8 VAC when cranking. (That's between 1/2 and 1 volt AC.) If it's below .5vac, replace it.
CJ7-Tim is offline
post #7 of 29 Old 05-30-2012, 01:35 AM Thread Starter
LOIIIIIIIOJ
Genius Tim
Thanks for the super detailed answer
Ill start working on these this week.
Whats the NSS? - my reverse light have been intermittant for year and the shifter has always had abit of play in it in reverse and neutral? whats this cause and could it affect my symtoms
- will post back on here once ive started to go through your suggestions and ill post my findings
Thanks again
post #8 of 29 Old 05-30-2012, 06:06 AM
laybackman
Bikini Bridge Inspector
laybackman's Avatar
2010 JK Wrangler
Me again. Those diagrams I posted in the YJ forum to answer your question were wrong! Those were for a TJ not an XJ! Sorry
Do you know what was good about the good old days? I wasn't good, And I wasn't old!
Senators and Congressman should wear uniforms like NASCAR drivers so we could identify their corporate sponsors....
laybackman is offline
post #9 of 29 Old 05-30-2012, 07:35 AM
dukie564
1995 XJ Cherokee
Originally Posted by LOIIIIIIIOJ View Post
Whats the NSS? - my reverse light have been intermittant for year and the shifter has always had abit of play in it in reverse and neutral? whats this cause and could it affect my symptoms again
this will answer all your questions and tell you how to clean/repair it without replacing it, which is good because they cost ~$300 new
http://bc4x4.com/tech/2010/jeep-neut...ty-switch-nss/
1995 XJ Cherokee Sport
4.5" Homebrew Lift, 4.0L HO I-6, AX-15, NP231, D30(Open)/C8.25(Locked)
33x12.5 Mickey Thompson Baja MTZ Tires, 309,000 mi and runnin' strong
dukie564 is offline
post #10 of 29 Old 05-30-2012, 09:38 AM
CJ7-Tim
CJ7-Tim's Avatar
http://www.boyandjeep.com/tech-articles/aw4-neutral-start-switch-rebuild
CJ7-Tim is offline
post #11 of 29 Old 05-30-2012, 01:43 PM Thread Starter
LOIIIIIIIOJ
UPDATE
I have unplugged the CPS and the guages have come back to life and the check engine light appears for a few seconds (when ignition is in ON position).
replugging it and it goes back to no guages and no start
There is infinate resistence between ground and live and zero between signal and ground - not sure which is b and c?
based on the above, do you recommend i buy a cps
is mine 1-56027866AC ??
how would i know? - vin says its a 97
also dealership cps are hard to get in uk. is there a reason why i need to get a dealer one - do after market ones only last a year etc?
ive been offered a mopar sensor - but this has two bolt holes only - all the others ive seen on ebay etc (aftermarket) have a third hole a little bit in. if i bought the mopar two holed one - will it not fit etc? - i can send pics if you need more info
Thanks
post #12 of 29 Old 05-30-2012, 03:59 PM
CCKen
CCKen's Avatar
The Chrysler part number for the 1997 & 1998 XJ Crankshaft Position Sensor is 56027866AB. 1999 has the AC suffix. There is no 1- in front of the basic part number.
Edit: If you look at the illustration Tim put in his post you'll see that there are only two mounting holes in the CPS.
Get the Mopar part wih the above part number.
Cheers
CCKen is offline
post #13 of 29 Old 05-30-2012, 04:07 PM
laybackman
laybackman's Avatar
2010 JK Wrangler
Cheers
Doesn't the suffix AB denote a standard transmission and the AC suffix denote the automatic tranny?
http://www.amazon.com/56027866AC-Che.../dp/B004WBGRSW
ANd
http://www.jeep4x4center.com/cranksh...6027866ac.html
post #14 of 29 Old 05-30-2012, 04:14 PM
CJ7-Tim
CJ7-Tim's Avatar
1997 4.0L = 56027866 The two letter suffix can be ignored.
Genuine Jeep sensors have the best quality and performance. Numerous Forum threads tell of continuing unexplained problems with cheap sensors that are cured by installing genuine Jeep sensors.
CJ7-Tim is offline
post #15 of 29 Old 05-30-2012, 08:32 PM
CCKen
CCKen's Avatar
No, the parts catalog only addresses 4.0 and 2.5 engines and does not address automatic or standard transmission utilization for the CPS. I believe the suffux letters are the part revision level. The 2000 & 2001 went up to AE.
Often (but not always) when I go to the dealership to buy a part I give them the part number for my '99 and they say it has been superseded by a later part number, i.e., a 2000 or 2001 part number.
If you told the dealer you wanted a part number 56027866AB CPS they would probably sell you a 56027866AE CPS....maybe.
CCKen is offline
97 XJ Turns over but wont start?! jen97xj XJ Cherokee Technical Forum 9 07-10-2009 10:12 AM
turns over but wont start pajeep XJ Cherokee Technical Forum 0 04-07-2009 08:26 PM
All Lights Turn on but jeep wont start himheartogram1 XJ Cherokee Technical Forum 4 07-13-2008 09:42 AM
HELP JEEP turns over but wont start AFTER WASHING ENGINE twisted_ed XJ Cherokee Technical Forum 8 04-14-2005 12:30 PM
Turns Over But Wont Start!!! superdave796 XJ Cherokee Technical Forum 9 03-19-2005 01:53 PM
