Jeep Cherokee XJ Engine Swap - JeepForum.com
post #1 of 5 Old 09-21-2012, 05:50 PM Thread Starter
hardy
I have a 1998 XJ with a 4.0 and am looking for a replacement engine. I found a 1998 Wrangler TJ 4.0 engine. Will it work for my XJ?
I think I need a pre 99 engine but am not sure which models and years will work. Someone told me the Grand Cherokee engines will not work for my XJ????
Any information is appreciated. I sure want to find a way to keep my Cherokee on the road!!!
hardy is offline
post #2 of 5 Old 09-21-2012, 05:55 PM Thread Starter
hardy
BTW...I failed to mention the Cherokee has the 4.0 engine
hardy is offline
post #3 of 5 Old 09-21-2012, 05:58 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Any 1990 -2001 XJ Cherokee or 1993-1998 ZJ Grand Cherokee 4.0 L engine block will interchange. Remove and re-use as needed: intake/exhaust manifolds, cylinder head, flywheel/flex plate, engine sensors, distributor or distributor-less coil rail ignition.
Also, 1997-1999 4.0L TJ Wrangler blocks fit in XJ’s, so you are good
2000+ Wrangler and any WJ Grand Cherokee 4.0L will not fit in an XJ without some significant modifications.
CJ7-Tim is offline
post #4 of 5 Old 09-21-2012, 06:18 PM Thread Starter
hardy
Thanks!!!
I may have been told wrong. Another mechanic told me the transmission mounting was different on the Grand Cherokees.
I can use all the external parts from my Cherokee for the swap. I just want to make sure all the block mounting will work for mine.
I was also told the 99 up XJ did not use a distributor and would not be able to use it on mine.
hardy is offline
post #5 of 5 Old 09-21-2012, 07:46 PM
CJ7-Tim
CJ7-Tim's Avatar
2000-01 XJ's use a distributor-less coil rail ignition with cam sensor in the distributor hole. All you do is pull out the sensor and stick in a distributor in the correct orientation.
CJ7-Tim is offline
engine block interchange , engine swap , tj engine block
Aw4-ax-15 swap completed.Trouble getting rid of Engine Light. 98 Jeep Cherokee jlimit1 XJ Cherokee Technical Forum 6 12-10-2011 01:25 AM
2000 Jeep Cherokee engine swap Blazer05 XJ Cherokee Technical Forum 1 04-03-2011 12:26 AM
2000 Jeep Cherokee engine swap Blazer05 XJ Cherokee Technical Forum 0 04-02-2011 10:37 PM
Engine Swap Question 95 Grand Cherokee to 90 Cherokee twmart XJ Cherokee Technical Forum 3 08-04-2010 04:17 PM
2000 Jeep Cherokee Engine Swap Questions.. Temperfied XJ Cherokee Technical Forum 4 01-26-2009 04:33 PM
