Jeep cherokee problem with tcase or drveshaft - JeepForum.com
post #1 of 4 Old 03-11-2013, 08:48 PM Thread Starter
Logan5
When i am in 4wd there is a whisling and grinding noise so i took my driveshaft off and it doesnt make the noise but when im going about 60 and let off it makes a small grinding noise below and sounds like the chain slipping. Any ideas?
Logan5 is offline
post #2 of 4 Old 03-12-2013, 05:31 AM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Inspect the drive shaft u-joints.
A loose chain will make a rubbing noise. A really loose chain will make a popping noise under heavy loads.
CJ7-Tim is offline
post #3 of 4 Old 03-12-2013, 07:01 PM Thread Starter
Logan5
I just replaced all the ujoints on it and the cv ball within the last 2 months and they still seem new so im guessing something to do with the tcase then
Logan5 is offline
post #4 of 4 Old 03-13-2013, 03:14 AM
sAe23
1995 XJ Cherokee
Is this a 231 or a 242 T-case? (Fill out your profile or provide this kind of info every time you post)
Is it making this noise on the street or in the dirt?
And was the 60mph test done with or with out the rear drive shaft and what mode was the T-case in?
sAe23 is offline
cherokee , jeep , xj
