Jeep Build - JeepForum.com
post #1 of 3 Old 10-24-2007, 06:32 PM Thread Starter
Tlong80
Jeep Build
Hey my names tyler and well im picking up a jeep soon and i need some help
im looking to build a fun rig that i can also use as a daily driver
I was thinking XJ 4.5" SUPER-FLEX KIT W/ADD from RE and going with some 31'' on black steel wheels
is there anything that i will need or should be aware of?
Tlong80 is offline
post #2 of 3 Old 10-24-2007, 08:19 PM
That1guy
That1guy's Avatar
2007 WK
A 3.5 lift is fine for 31"s. You also need to watch your drive shaft angles. You will need a transfercase drop to help with vibes. You might not need it, but a slip yoke eliminator is better. The 3.5 kit will help lessen the angles. I'm guessing the ADD part means add-a-leaf. You would be better off with the spring kit. The add-a-leaf kits tend to sag quickly and not ride very well. RE Is a very good kit. Make sure you have recovery points front and rear. Happy jeepin.
I'm forever grateful to Speedycat and RnEmOvr for their generosity
That1guy is offline
post #3 of 3 Old 10-24-2007, 08:26 PM
balloo93
Little Red Menace
balloo93's Avatar
1993 XJ Cherokee
As mentioned, save your cash and get full packs and not the AAL. You will thank yourself later. Also as mentioned, the 3.5" kit is MORE than enough for 31's. It will probably actually net you closer to 4-4.25" once settled.
An adjustable trac bar would be a great idea.
Recovery points and Skid plates should be high on your list as well. Especially the recovery points. Seriously, recovery points!
93 Sport
Beer is proof that God loves us and wants us to be happy............Ben Franklin
Specs in Profile.
balloo93 is offline
my jeep build great-white XJ Cherokee Technical Forum 19 07-24-2009 10:52 PM
new jeep build great-white XJ Cherokee Technical Forum 4 07-24-2009 01:24 PM
Help with my 1st Jeep build! BeLIEve XJ Cherokee Technical Forum 7 11-14-2008 10:15 PM
my jeep build jetwrench XJ Cherokee Technical Forum 9 03-12-2008 01:01 PM
First Jeep Build Tlong80 MJ Comanche Technical Forum 3 10-24-2007 06:30 PM
