jeep blows 30 amp fuse under hood when starting - Page 2 - JeepForum.com
post #16 of 20 Old 11-14-2008, 03:53 PM
rfritz
1997 XJ Cherokee
Taters, what was the problem with the computer? I am having the exact problem and I think that is the culprit. Would it just be easier to buy another computer?
Thanks
rfritz is offline
post #17 of 20 Old 05-21-2010, 12:18 PM
drad
help i havv same problem
ihave the same problem,what part did u have to replace in computer?
drad is offline
post #18 of 20 Old 08-06-2012, 04:55 PM
KJR96XJ
Old post but I am now having this problem... What is the culprit???
KJR96XJ is offline
post #19 of 20 Old 07-11-2013, 11:33 AM
Narwhale671
Had the same issue. I am new to Jeeps, being an old Ford guy so I made a dumb mistake. I have just finished working on my XJ doing lots of mods and maintenance. One of the things I did was remove the interior to fix some holes on the floor and bed line it. During this procedure I removed the seat belts, no big deal right? Put everything back together, drove it a week or so, then one day, boom; she shuts down. No spark, no start. I troubleshoot everything, got the familiar CPS, coil, etc. found that the ASD relay 30A fuse is blown. The culprit? There is a plastic bracket behind the transfer case that holds the O2 sensor. It is held to the SEAT BELT bolt with a speed nut! When I removed the seat belts, I inadvertently disconnected this bracket. The O2 sensor wires were draped over the slip yoke and the insulation had worn through causing a short and blowing the fuse. Fixed the wires, put the bracket back in place, replaced the fuse and hit the road.
Narwhale671 is offline
post #20 of 20 Old 11-22-2016, 11:10 PM
jeepja
can you elaborate
jeepja is offline
xj blows fuse need help ausburn15 XJ Cherokee Technical Forum 1 01-08-2009 09:19 PM
xj Engine control fuse blows on start up ecm? noel86 XJ Cherokee Technical Forum 1 12-17-2008 01:33 PM
high RPM blows eng ctrl fuse xjhabitat XJ Cherokee Technical Forum 0 10-07-2007 08:55 PM
1989 Cherokee blows blower fuse 98crewcab XJ Cherokee Technical Forum 1 11-05-2006 01:04 AM
fuse 11 blows when shifting to reverse Vegard XJ Cherokee Technical Forum 5 08-20-2006 11:50 AM
