Jeep Backfires from Air Intake and has a complete lack of power - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > Jeep Backfires from Air Intake and has a complete lack of power
Bds fox ipf 2.0 racing series shocks now available at rockSpartan Lockers FREE SHIPPING Excellent PricesRough Country Jeep Suspension Deals at Rockridge 4WD!
Unread 10-10-2007, 09:17 PM   #1
se7vn
2004 KJ Liberty
Here's what happens, at 75% throttle, the engine bucks and backfires like there's no gas unless I push the pedal down, the engine surges with full power, anything before 75% throttle, it feels like a bad cat, 5th gear is completely useless because i'm lacking so much power, it even backfires from the intake while idling, but only at high RPM's. Idles at 300 Rpms then once every 2 minutes, the engine steps up and idles at 700 rpms which is where it should idle for about 5 secs then goes back to 300 rpms.......
Here's what I've changed:
Fuel Filter
Fuel Pressure Regulator
Fuel Pump
2 Fuel injectors that were leaking
Full Tune up, Cap, Rotor, Plugs, Plug Wires, even a new ignition coil
Map Sensor
IAC Valve
O2 Sensor
Timing Chain
Coolant Temperature Sensor
Tried Blocking off the EGR to see if that changed it, it didn't change it at all
Tested TPS, voltage goes smooth all through throttle when I go very very slowly
5.0V input, .81 output at idle
Cleaned TB
Checked EGR Solenoid, fine
Catalytic Converter
Harmonic Balancer
Muffler Unhooked and no change in idle<-----------Edit
Crankshaft Position Sensor <--------------------Edit
Tested Compression : I got 1)=150 psi
2)=140 psi
3)=160 psi
4)=155 psi
5)=150 psi
6)=150 psi
did i forget to check anything else...............................??????
Any ideas what it could be?
My guess right now is a vaccum leak I fail to trace down...........
[COLOR="Gray"]2004 Jeep Liberty Sport 3.7L V6[/COLOR]
[COLOR="White"]1989 Jeep Cherokee Laredo 4.0 I6 - 147,520 Miles[/COLOR]
se7vn is offline   Reply With Quote
Unread 10-10-2007, 09:25 PM   #2
lifted92xj
1992 XJ Cherokee
did you check the cat or replace it? it could also be the muffler. plus check your oil level i've heard if theres too much oil it can destroy your cat..but thas just what i've heard. it would be loud as hell but i'd try unbolting the cat so its just the manifold and run it like that and see if it still does it (meaning in your driveway) and if it stops you know its the exhaust
big lift, sick tires, awsome accessories, alot of custom work.
my jeep won the war, your honda mows my lawn
lifted92xj is offline   Reply With Quote
Unread 10-10-2007, 09:38 PM   #3
se7vn
2004 KJ Liberty
if it were clogged, wouldnt it idle and run like crap all the time? if that were it, then why would it idle up to 700 rpms on cue every time?
Unread 10-10-2007, 09:45 PM   #4
lifted92xj
1992 XJ Cherokee
sry didnt read that last part there.. the change in idle sounds like a o2 sensor to me, do you have 2 of them? and only changed 1, or just 1
Unread 10-10-2007, 09:49 PM   #5
se7vn
2004 KJ Liberty
lol, sorry, I know, I wrote a book above, lol, but I'm just getting completely stumped by this, it's been a year now.....I changed the one on the downpipe from the exhaust manifold, I read somewhere that the one further back in the exhaust doesn't really make that much of a difference.......
Unread 10-10-2007, 09:51 PM   #6
cox_xj
1997 XJ Cherokee
timing is off, very very off
if it backfires though the intake its 98% most likely timing related
cox_xj is offline   Reply With Quote
Unread 10-10-2007, 09:51 PM   #7
lifted92xj
1992 XJ Cherokee
well it seems like youve done everything short of a motor swap, i'd try that one too, thats the only other thing i can think of
Unread 10-10-2007, 09:52 PM   #8
Slowride63
XJ Cherokee
I've dealt with several plugged converters over the years, and not one gave any indication of a problem untill the engine was under load. Have you tried disconnecting the exhaust and running it? If not that would be my suggestion, as it will either identify or rule out the muffler and/or cat as the problem.
88 Cherokee. 4.5". 33's
90 Cherokee. 2" BB . 31's
97 Grand Cherokee. Stock for now
[COLOR="Red"]Red Jeep Club #364[/COLOR]
[COLOR="White"]Low Output 4 Cylinder Jeep Club #101[/COLOR]
Slowride63 is offline   Reply With Quote
Unread 10-10-2007, 09:57 PM   #9
se7vn
2004 KJ Liberty
I unplugged the muffler two weeks ago and it still ran the same, I didn't try the cat lately though, I'm also thinking it may be ECU related, maybe it's bad? Dunno how, but I do know my timing is off somehow, hence the timing chain replacement, it could also be something stupid like the knock sensor or something, with the renix engine and all these damn sensors it could be a $10 sensor that advances or retards timing......
Unread 10-10-2007, 10:14 PM   #10
se7vn
2004 KJ Liberty
Anyone else have any ideas?
Unread 10-10-2007, 10:16 PM   #11
cox_xj
1997 XJ Cherokee
have you put a timing light on it? to see how off the timing is?
Unread 10-10-2007, 10:18 PM   #12
se7vn
2004 KJ Liberty
I have one, just have to figure out how to use it LOL, probably do that tomorrow after work....
Unread 10-10-2007, 10:20 PM   #13
cox_xj
1997 XJ Cherokee
normally has 2 clips one positive one ground, then a lil clamp that goes on the number 1 plug wire
some have dials to change the timing of the light, some just flash, point at crank pully and see which dash mark its lining up with
Unread 10-10-2007, 10:42 PM   #14
se7vn
2004 KJ Liberty
should I put some kind of paint mark on the Harmonic Balancer or just point it anywhere? I have the one that just flashes
Unread 10-10-2007, 10:52 PM   #15
pgdyk
1988 XJ Cherokee
Put paint on the timing pointer and 0* TDC
88 XJ 194K 4x4
84 Dodge Ramcharger 4x4
pgdyk is offline   Reply With Quote
