Quantcast January Cherokees of the Month - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > January Cherokees of the Month
Old 01-01-2005, 12:28 AM   #1
EricsXJ
The Post man
EricsXJ's Avatar
Congratulations to our Cherokee of the Month winners for January 2005!
lbsnowryder - Stocker Class (click here to see the voting)
JEEPZZ - Modified Class (click here to see the voting)
Winner of the Stocker Class
lbsnowryder
88 XJ Lerado "Trail Rated"
4.0 L AW4 Trans
3.55 gearing w/ Command Trac
Upcountry package tow hooks and skids
2" Budget Boost
30" Open country M/T's
Optima red top
chrome brush guard
shaved emblems
Harbor Freight off-road lights
15x8 AR 767's
Thule snowboard rack
white gauges
Straps and Hi-lift on board
Winner of the Modified Class
JEEPZZ
...1997 Jeep Cherokee "Renegade"
Under Hood:
...4.0L
...GDI 3 core radiator
...165 amp alternator
...'99+ high flow intake manifold
...K&N air cleaner
...Optima red top battery
...compact GM retractable reel light
...ARB air compressor
Drivetrain:
...AW4 trans
...NP242 w/Currie flanged SYE
...Tom Woods driveshafts w/Spicer 1310's, clearanced CV and U-bolt converted yokes
Rear Axle:
...Dana 44 from 87XJ w/Spicer 4.88's
...Detroit EZ locker
...Ford Motorsports Disc conversion w/intergrated e-brake
...relocated/raised shock mounts
Front Axle:
...D30HP w/Superior 4.88's
...ARB locker
...custom 1/4' plate LCA mounts
...Currie HD UCA mounts with Johnny Joints
...cut and rotated knuckles
...custom OTA track bar mount
...Spicer 760 joints
Steering:
...custom built high steer crossover conversion
...3/4 ton Dodge TRE's
...dual Skyjacker steering stabilizers on custom mounts
...long throw 'reduced drop' pitman arm from SJ Wagoneer
Suspension, Front:
...Skyjacker Rock Ready subframe & custom length control arms
...8" Skyjacker coils
...JKS Adjustable coil-over spacers
...JKS QDII swaybar disconnects on relocated mounts
...Trailmaster swaybar relocation brackets
...custom clearanced subframe cross support (driveline)
...custom adjustable track bar frame mount w/90* rotated joint
...Teraflex/Currie modular Johnny Joints mounted in LCA's
...Currie Johhny Joints in UCA's & track bar
...Skyjacker extended braided stainless brake lines on extended mounts
...Skyjacker Soft-Ride shocks w/modified 'eye' mounts
...upper shock eye conversion & lower BPE's
...custom center mounted adjustable limiting strap (prevents axle unloading)
Suspension, Rear:
...Skyjacker 6" leaf pack w/AAL
...custom front and rear relocated (dropped) leaf spring mounts
...custom "twister/folding shackles" (like revolvers but without the unloading)
...custom built extended travel upper shock mounts (eliminates shock hoop)
Tires & Wheels:
...15"x10" Eagle polished aluminum 063's w/-46mm offset & 3-9/16" backspacing, 5x4.5
...35x12.50 Goodyear MTR's
...full size matching spare tire and wheel
...McGard locks
Bumpers, Front:
...pre97 ARB bumper
...3-ton clevis recovery brackets w/custom backing plates and Warn D-rings
...Warn roller fairlead
Bumpers, Rear:
...pre97 Kaymar dual pivot carriers w/over-center cam latches & built in class 3 receiver
...modified swingout tire carrier (raised & angled for 35" tire)
...modified swing out locking gerry can carrier (raised & clearanced)
...Rover style secondary lighting
...custom CB ant mount
Rack & rails:
...full length ARB roof rack w/mesh floor and additional spare tire mounting bracket
...Highlift 4xRac-Loc mount w/Daystar handle isolater
...treadplated custom rock rails (twin bar design) w/full length pinch seam & angular frame mounts
Lighting:
...European market XJ remote headlight leveling system
...Sylvania Xenarc X6054 HID headlights w/modified optics
...Piaa Pro90XT's w/crystal ion fogs on custom bumper mounts
...Piaa 959 driving projectors on fairlead mount
...Piaa light locks
Misc exterior:
...Bushwacker cutout pocket flares
...Reflexxion cowl hood
...Orvis XJ rear liftgate spoiler with clear lens LED brakelight
...Orvis XJ hood vents (same as 5.9)
...custom 1/4 panel molding trim
...OEM Stone White paint added to bumpers, flares, rails, rack, grill, spoiler, mirrors & moldings.
...billet grill inserts
...chrome badging/lettering from '01 XJ Limited
...Renegade badges from KJ
...clear front signals, ARB lenses & side markers
...heated mirrors from XJ Limited
Interior mods:
...XJ Limited wood trim dash and wood trim door panels w/map pockets
...XJ Limited power leather seats w/seat heaters from 99 Limited
...interior color changed from OEM mist gray & agate to custom satin black
...headliner with integrated speaker mounts from '01 XJ
...European XJ 4 switch dash panel w/front and rear fog light switches
...white face gauge dials
...overhead console w/keyless entry system added from XJ Limited
...JL Audio, Vantage sub box
...Sony in dash disc burner, disc changer, amp & sub
...OEM Infiniti tweeter panels from 98 XJ Limited
...complete interior Dynamat sound dampner installation
...security system w/remote start
...security window tint
Accesories:
...Highlift jack w/off road base plate & jack cover/protector
...ARB/Kaymar highlift jack bumper adaptor bracket
...ARB tire inflation kit
...Cobra 75WX all-in-handset remote CB
...Firestik antenna
...Yakima roof rack cargo netting
...Raingler cargo area barrier net
...recovery strap/kit
...basic trail tools/parts
...first aid kit
...fire extinguisher
More detailed pics @ Jeepzz pics
Here are the rules for entering the Cherokee of the Month for anyone that is interested in participating next month.
Here are the previous months:
January 2004 Rufies97XJ / LOCKED UP
February 2004 thephantum / MSHarnett
March 2004 EnderUSAF / Jason, aka: Jeepin.com
April 2004 XJ99 / james harmon
May 2004 XJ-Ken / Bear549
June 2004 Walton99 / creekxj
July 2004 ugmoe2000 / EnderUSAF
August 2004 lbsnowryder (MJ) / redjeepguy
September 2004 DMacabre / GottaBeJeep
October 2004 hondastomper / EricsXJ
November 2004 local_racer_boy / Xjeepness
December 2004 Lagooz00xj / Sterling90XJ (aka: SilverstoneXJ)
EricsXJ is offline   Reply With Quote
Old 01-01-2005, 01:41 AM   #2
MSHarnett
Broke Bogger
MSHarnett's Avatar
1997 XJ Cherokee
Congrats guys. I've always had a thing for that all white rig. Its like the opposite of mine, all black Lookin good
Matt
97 XJ - Black Sport, 4.0L AW4, D30 and 8.25
6" Skyjacker/RE, 33x13.5 Swamper LTB
Cracked Frame, good for steering!!!
MY XJ PICS
MSHarnett is offline   Reply With Quote
Old 01-01-2005, 09:39 AM   #3
orangez
if the all white one were mine, the ONLY thing I would do to it would be to paint the little thinl bars on the grill black. it just seems to be a LITTLE too much white. I think that would set off the wider bars a lot better. other than that its freakin awesome. thats why i voted for it.
orangez is offline   Reply With Quote
Old 01-01-2005, 02:42 PM   #4
3fifty
lbsnowryder Where did you get your brush guard? What brand is it?
Congrats to both of you.
'00 TJ - Some stuff.
My Pictures from Iraq. * Stagger4x4.com
3fifty is offline   Reply With Quote
Old 01-01-2005, 06:39 PM   #5
lbsnowryder
One notch above Redneck!!
lbsnowryder's Avatar
3fifty, thanks first of all and happy new year. I had a little to much fun last night and now i am paying for it today.
I don't even remember where i got that thing. I bought it online for $130 about 6 years ago. I can't remember where from though. I know that doesn't help at all. Sorry
LB
_____________________________________
I own a Jeep, it's red and has big tires
Radical Pictures
lbsnowryder is offline   Reply With Quote
Old 01-02-2005, 08:54 PM   #6
Just Giv'r
yah congrats guys i've always wanted your roof rack there jeepzz but your down in austrialia haha......good work
2000 XJ Sport with Rubicon Express 4.5" lift, 31" BFG AT KO's with stock 15" XJ Sport rims, sky jacker shocks
Just Giv'r is offline   Reply With Quote
Old 01-03-2005, 07:54 PM   #7
JEEPZZ
Thanks for the votes and the comments everyone.
Congrats to you too lbsnowryder!
Originally Posted by Just Giv'r
...jeepzz but your down in austrialia
Nope Utah, but sometimes this place feels like it's in a world of it's own.
My pics are from Moab.
If you decide to come, bring your own beer! ...and me some too.
[FONT=Trebuchet MS][size=1]97XJ RENEGADE
JEEPZZ is offline   Reply With Quote
Old 01-04-2005, 10:47 PM   #8
Just Giv'r
hahaha i feel like a retard sorry about that.....maybe thats where u said your roofrack was from or something
Old 01-05-2005, 06:14 PM   #9
balloo93
Little Red Menace
balloo93's Avatar
1993 XJ Cherokee
Congrats to both of you guys!
3fifty, his gaurd looks like the Thumper Bumper from Smittybuilt.
93 Sport
Beer is proof that God loves us and wants us to be happy............Ben Franklin
Specs in Profile.
http://www.cardomain.com/ride/325707/1
http://www.cardomain.com/ride/2406854/1
balloo93 is offline   Reply With Quote
Old 01-05-2005, 09:24 PM   #10
cw50must
lbsnowryder- what is the back spacing on your rims? Looks good.
cw50must is offline   Reply With Quote
Old 01-05-2005, 09:38 PM   #11
lbsnowryder
It's 4" BS and i would like to comend JEEPZ on his rig too.
I forgot to ask what we won. The wrangler guys give out parking spaces and a new set of M/T's to the winners.
LB
Radical Pictures
Old 01-07-2005, 01:28 PM   #12
XJeepness
JEEPZZ I love ur rig. Looks real nice Very clean looking. Good job
,John
High Centered Offroad
XJeepness is offline   Reply With Quote
Old 01-14-2005, 12:15 PM   #13
XJeepness3434
Nice jeeps
Good job guys!
[COLOR=DarkRed]2000 Cherokee Sport
4.5" Rustys Front Coils with 1 inch spacer, 3.5" RE superflex Leafs with/rusty's 1inch shackle and block, 5.5" total.
33x10.50 BFG MT's
Four Wheel Roof Rack/Wal Mart light mod
Rusty's Stinger w/2 KC's
Rusty's HD Tie Rod
RE Adj. Tack Bar
Rusty's cut out flares
Rusty's Intake/kn air filter[/COLOR]
[COLOR=DarkRed]Obnoxious Stinger Club #2[/COLOR]
XJeepness3434 is offline   Reply With Quote
Old 01-28-2005, 02:53 AM   #14
MadDogXJ
Congrats you crasy Jeepsters
The meaning to life is to live, So Go Live....Offroad :o)
[COLOR=red]******************************************[/COLOR]
[B][U]1998 Cherokee, 2 Door, Black.[/U] [/B]
4.0 L Power Plant, NP231 Transfer Case
32" BFG All Terrain Tires on 15"x7" "Grizzy" Jeep wheels
Helix TB Spacer with K&N Replacement filter.
C4x4 Rear Bumper/Tire Carrier with hitch and towhooks :)
DPG Rock Attack XJ Gas Tank Skid Plates
RE 4.5" lift - With 1" 5/8 Spacer up front, and 1" Spacer and 3/8 shim in back. So over 6" of lift.
MadDogXJ is offline   Reply With Quote
Old 01-30-2005, 10:48 AM   #15
Matt Gertsch
www.lp.org
Matt Gertsch's Avatar
Hey , I have shaved emblems too! Shaved gutters, shaved mirror and a whole lot of pinstriping. Gotta' love those tight manzanita lined trails!
All kidding aside, great rigs guys.
Matt Gertsch is offline   Reply With Quote
Glock Forum
