Issue with my headlights - JeepForum.com
post #1 of 9 Old 01-29-2013, 10:11 PM Thread Starter
gutiaqp
1997 XJ Cherokee
Hello there
I have a 1997 Cherokee XJ
I bought:
- Rampage 5089927 Halogen Conversion Headlight Kit and
- Putco 230004HW Premium Automotive Lighting Wiring H4 100W Heavy Duty Harness and Relay
I followed this guide:
http://www.jeepforum.com/forum/f11/r...me-you-954057/
When i pull the switch to the first position all works fine, tear lights and tail lights will turn on,
Issue comes here:
When i pull the switch to the second position the low beams will turn on, however when i switch to High beams and back to low the high beams seem to stay on, it seems that i have 3 kind of lights, low, high and something in between, i know sound weird but that is what i am experience.
The only way to go back to low beam is to turn off complete the lights and turn it back on.
Thank you for any input
I did not do the part for modifying the feature for the lights staying on after shutting off the switch with your HD harnesses,
gutiaqp is offline
post #2 of 9 Old 01-30-2013, 06:16 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
If you have stock fog lights on a 97+ and upgrade your harness to one that uses the factory wiring to trigger some new relays, your fog lights will have and/or cause issues unless you make some additional modifications to address the problem. It doesn't matter if you use a plug and play harness like the eautoworks/Putco or if you split your harness open and completely strip out all the extra factory wiring. The factory fog circuit will cause your new lighting system to not work properly.
If you do nothing, your headlights might work as mentioned above. Low beams will be fine, but after you turn on your high beams, they will not turn off again until you completely turn off your headlights. Big issue here is that when you switch back to low beams, both the high beam and low beam filament will be remain powered causing your bulbs to endure 115W worth of heat output instead of the 55W or 60W that they are designed for. From what I've read this can cause them to overheat and burn out within minutes.
So what is happening? If you look at the driver's side headlight plug (and you have factory fogs) you will notice there are two red wires coming out of one of the terminals. One is a small 18g Red wire which sadly is the stock high beam wire. The other is an even smaller 20g Red wire which ties into Fog Lamp Relay #1 in the PDC. Please keep in mind that Fog Lamp Relay #1 is NOT used to provide battery power to the fog lights the way we commonly use them with aftermarket lighting. It is located before the switch and simply cuts power to the Fog Light Switch unless the Headlight Switch and Beam Selector Switch are in the proper positions. It does this as law dictates that you can't run your high beams and fogs at the same time. Some states with safety inspection programs may fail your vehicle if the lights don't operate this way.
When your Headlight Switch is off, the relay coil receives no power and therefore won't allow your fog lights to come on. When your Headlight Switch is turned on, one side of the relay's coil receives 12V which causes the relay to activate and send power through to your Fog Light Switch. When you turn your high beams on, 12V is sent out to your headlight socket via the Beam Selector Switch, and then is sent back to the other side of the relay coil via the skinny Red wire on that shared terminal. This brings both sides of the relay coil to 12V, thus causing it to deactivate and turn off the Fog Light Switch. The factory designed it so that the relay is off with both sides at 0V, on with one side at 12V, and then off again with both sides at 12V. While it makes perfect sense now, this is the part that was confusing me.
So what's the problem then? Well, it turns out that even when the high beams are off, there is still approximately 5V on that skinny Red trigger wire for some reason. While this is obviously not a problem in the factory configuration, it becomes a problem when you are using the high beam wire (which is directly tied into the skinny Red wire) to trigger your aftermarket high beam relay. A typical automotive relay requires approximately 8V to activate and needs to drop to somewhere below 1-5V to deactivate. When you first turn on your lights there is no problem because the phantom 5V is not enough to activate your new high beam relay. When you turn your high beams on, your new relay gets 12V and kicks on. When you go to turn off your high beams, the phantom 5V keeps the new relay from deactivating and voilà, your high beams are stuck on...
So how do we fix this? There are a few common suggestions:
1. Don't use your high beams, new lights are bright enough anyways
2. If you have to use your high beams, turn your headlights off briefly to get them turn off (PITA)
3. Pull various fuses (lose your fog lights)
4. Pull the fog lamp relay (again, lose your fog lights)
5. Modify the fog lamp relay (fog lights work, but won't cut out when your high beams are on?)
6. Install a jumper in place of the fog light relay (fog lights work, but switch is always hot?)
The right way to do it... Cut the 20g Red Fog Lamp Relay #1 ground/trigger wire at the back of the driver's side headlight plug. Extend this wire using your preferred method so that it is long enough to reach your new aftermarket high beam relay. Splice it into the 87 pin (output) of your new high beam relay. If you have two 87's (which is ideal), either one is OK. Do not however use 87a if your relay has it!
Your high beams will now turn off when they're supposed to, your fog lights will turn on/off when they're supposed to, and your low beams will continue to work as they're supposed to.
CJ7-Tim is offline
post #3 of 9 Old 01-31-2013, 11:22 AM
jeepkid03
Winning
jeepkid03's Avatar
The problem is the Putco Harness. Its a cheap made in China harness with cheap relays. I did the same mod on two Jeeps and both had problems with the harness shortly after. One harness I pulled apart and it was VERY corroded for a jeep that spends 98% of its time on the highway and being only a year old. The other harness was in a friend's XJ and his lights would randomly dim in and out, or the relays would stick and his highbeams wouldn't turn off.
I have the ARB harness in mine which is pricey, but I think your best bet would be to build your own.
-Josh
My 0331 Head Swap How-To Thread:
Build Thread:
jeepkid03 is offline
post #4 of 9 Old 01-31-2013, 05:50 PM
CJ7-Tim
CJ7-Tim's Avatar
I have Putco headlight harnesses in both my XJ's. One is about 4-5 years old and the other is 1 year old. The Putco harness works fine for what you pay for them. If there are issues simply grab some Honda relays from the junkyard and replace the cheap Chinese junk.
CJ7-Tim is offline
post #5 of 9 Old 02-01-2013, 08:18 PM Thread Starter
gutiaqp
1997 XJ Cherokee
Thank you very much for all the information! This was indeed my problem, will take a look once start getting warm here (warm for me measn around 40, lol) , right now is on single digits so is freaking cold to work outside or even inside my garage with a heater.
Cheers!
gutiaqp is offline
post #6 of 9 Old 02-11-2013, 09:30 AM Thread Starter
gutiaqp
1997 XJ Cherokee
Hello CJ7-Tim
Maybe you can help me figure it out this
As you mention
"The right way to do it... Cut the 20g Red Fog Lamp Relay #1 ground/trigger wire at the back of the driver's side headlight plug. Extend this wire using your preferred method so that it is long enough to reach your new aftermarket high beam relay. Splice it into the 87 pin (output) of your new high beam relay. If you have two 87's (which is ideal), either one is OK. Do not however use 87a if your relay has it!"
I found all cables no problem with that, the issue is with the Putco relay, i do not have a wire diagram for this relay and is not on the sides like the factory one, i found this but does not tell me with pin is the 87
Here is the data sheet
https://www.dropbox.com/s/j9tcgk2vgs...0datasheet.pdf
I also read thta this relay Ratings are 4 pin (30, 85, 86, 87 terminals) but not sure which one is 87
Is there any way to find out with an electronics multimeter?
Here are some pictures of the relay (The first 3 are Putco the other one is the factory fog light relay)
Thank you again
gutiaqp is offline
post #7 of 9 Old 09-17-2013, 12:18 AM
Scoopafly
Anyone figure this out?
Originally Posted by gutiaqp View Post
Hello CJ7-Tim
Thank you again
Scoopafly is offline
post #8 of 9 Old 09-17-2013, 12:58 AM
JWELK
85 and 86 operate the coil that operates the relay. One of these will be ground, the other will go high when activated. 30 is the feed for the device, this will be either hot all the time or when the key is on, 87 goes to the device which. 30 and 87 are interchangeable, as are 85 and 86.
Regards,
Jim W
ps CJ7 Tim that is an excellent write up.
JWELK is offline
post #9 of 9 Old 09-17-2013, 12:06 PM
Scoopafly
How would you modify the fog lamp relay to turn on the fogs when ever you wanted?
headlights problem , rampage
