iPod needs a home - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > iPod needs a home
Amsteel Blue Synthetic Winch line Free ShippingRing & Pinion's, Lockers, 4340 Axles, Install Kits, BaRaceline/Allied Wheels on Sale NOW !
Unread 11-14-2008, 12:41 AM   #1
VR6NH
iPod needs a home
Well I recently added an auxiliary line to the back of my head unit so I can play and charge my iPod, however, I cannot find a good home for the cable or ipod. Right now it runs along the driver-side of the center console and stops about halfway leaving me with the cup holders and under the ebrake to store the ipod which is annoying. I refuse to go with the glove box as its to far a reach while driving to scan the ipod for desired tunes.
Any remedies for the problem?.. good mounting/storage spots?
dubaudigruppe.com
VR6NH is offline   Reply With Quote
Unread 11-14-2008, 12:44 AM   #2
Mr_Clickerson
1994 XJ Cherokee
Tried velcroing my Zune to the clock area to the right of the wheel and the left of the comfort controls... You know- that useless panel on your dash... That is of course, if you have an older style XJ. If it's the new style, then I have no clue.
Originally Posted by Lamb of God
Whoever appeals to the law against his fellow man is either a fool or a coward; whoever cannot take care of himself without that law is both. For wounded man shall say to his assailant, "if I live, I will kill you- if I die, you are forgiven;" such as the rule of honor.
Mr_Clickerson is offline   Reply With Quote
Unread 11-14-2008, 06:45 AM   #3
bmyohn
Youngin'
bmyohn's Avatar
maybe u could run it to the glove box or something and have it in there. or even run it to the center console. my mom's infiniti has the Ipod in there (but you can navigate the ipod on the touch screen)
you could even run to sit on the glass face of the dash,
just some ideas
2011 Dodge Ram 1500 Big Horn 4x4
5.7L V8 Hemi
"The Tow Rig"
2001 Jeep Cherokee Sport
4.6L Golen Engine Stroker
6.5" TnT Customs Longarm Kitl Ford HP D60 l 6.5" Rock Krawler Coils l TnT Customs HD Trac Barl Omix Ada HD SYE l 1" UBEsl CV Driveshaft l39.5" IROKsl 17x9" Pro Comp 98sl High Clearance Shock Mounts [COLOR="red"] l Hidden Hitch l AJs Custom Front Bumper l SONY Xplod stereo l Alpine Speakers l TnT Frame StiffenerZ l 22" RE SS Brake Lines l 1.5" TnT Customs Boomerang Shackles l Sterling 10.25 *FULL WIDTHS* l JKS Mini Skids and Sway Bar Brackets l 7/8" Heim Joint High Steer
bmyohn is offline   Reply With Quote
Unread 11-14-2008, 06:53 AM   #4
96cherokeeclass
It's not the best picture but you can kinda see behind the steering wheel where I have my ipod holder mounted. It's screwed in to that area just under where most people have a clock (mine dosen't). I like it there, you can see the display easily and it's right there for borwsing.
The mount was cheap on ebay.
- 07 WK - CRD
96cherokeeclass is offline   Reply With Quote
Unread 11-14-2008, 07:11 AM   #5
FitchVA
Jeeper 4 Life
FitchVA's Avatar
yellow dashed line is where my cables run...
i don't smoke so it's a good place to hide the cable ends. and you can also see my wooden wedge velcroed to the center console...
hooked up using the headphone jack...
and hooked up via usb...
'98 xj sport (trail toy) | specs
'98 xj classic (dd'er) | specs
'89 mj tinker toy | specs
My XJ Page | My Gallery
FitchVA is offline   Reply With Quote
Unread 11-14-2008, 08:13 AM   #6
eflores
1989 XJ Cherokee
that is super clean man
AEKDB
Leaky sunroofed XJ member #1
The United States of America July 4, 1776 - November 4, 2008 RIP
eflores is offline   Reply With Quote
Unread 11-14-2008, 11:08 AM   #7
okcjeeper
I mounted the mount in my center console. I just used velcro to secure it. I then drilled a hole in the center console insert to run the wires under the center floor console to the cigarette adapter I spliced in behind the dash console. This provides the power. I then simply used a cassette adapter in the radio. I actually removed the faceplate of the radio and inserted the cassette and then place the faceplate over it. This makes it look as if there is no cassette in the player and hides the wire running to the power adapter.
I have used this setup for about 3 years and it works great. The Ipod is still easy to control in the center console and it also remains hidden.
Pics...
[IMG][/IMG]
[IMG][/IMG]
"Work Hard... those on welfare depend on you"
RC 3" Series II Lift/4wd/NP242/Firestone Destination AT's/Surco Rack/Hella's/CB/3' Firestik/Factory Overhead Console Installed
okcjeeper is offline   Reply With Quote
Unread 11-14-2008, 01:44 PM   #8
funinmud
i use a cassette adapter and just keep in in one of my cup holders or between my legs or on my leg up i have wedged it between my sun visor and headliner too.
-James
98 XJ on 32's and 2-3" lift, locked, armored, and ready to rock.
funinmud is offline   Reply With Quote
Unread 11-15-2008, 01:26 AM   #9
98CherokeeLTD
1992 XJ Cherokee
i would try and do something with the armrest. specifically making some kind of mount for the underside of the armrest lid. I know with my 92 the underside of lid is recessed and I'm pretty sure that my 98 my wife had was too.
the wires could be run under the console and then ran to the lid from there.
Originally Posted by -XJguy- View Post
Damn pesky trees always jumping out into the middle of the road without looking.
98CherokeeLTD is offline   Reply With Quote
Unread 11-15-2008, 08:05 PM   #10
Jeeptrek
Put the ipod in the cup holder screw the passenger
Jeeptrek is offline   Reply With Quote
