Intermittent brakes to floor - JeepForum.com
post #1 of 3 Old 02-14-2014, 07:15 PM Thread Starter
Jeep3030
Just set my 1998 xj Cherokee up with a plow. After plowing all day the brakes faded to floor , red brake light came on.
Came to a stop , took a deep breath and they were back.
Now it is an intermittent problem.
I replaced the master, bled the system ... Same problem
Air? Brake fluid heating up do to plow? Any other ideas?
Jeep3030 is offline
post #2 of 3 Old 02-15-2014, 02:28 AM
uberxj92
1992 XJ Cherokee
Vacuum leak. Or brake fade due to poor air flow.
http://www.jeepforum.com/forum/f177/92-xj-sadness-2075657/index2.html
uberxj92 is offline
post #3 of 3 Old 02-15-2014, 10:07 AM
psychoteen101
Before you changed the master, was the fluid level low? Check for leaks in the system? And when does the problem tend to occur? at random or after you've been driving for a while?
1996 Jeep Cherokee- Project-- Rusty's 8in long arm, SYE kit, Teraflex driveshaft, Cragar soft 8's 15x10 with 33x12.5 Firestone Destination MT's, Eaton Tru Trac in the front
psychoteen101 is offline
