Interior lights stuck on? - JeepForum.com
post #1 of 14 Old 08-25-2009, 06:58 PM Thread Starter
CallMeColt
Hey everyone,
I am having an issue with all of my interior lights being stuck on. My vehicle is a 1999 XJ. I checked all of the switches on the doors, removed them, and they seems to be ok. I don't have the switch on where the headlights are, haha. I was thinking maybe because of the rear hatch it is not going off, but I do not know where the switch is for that. Anyone else have this problem and fix it? Only way I was able to get it to go off was pull a fuse out but now I have no power locks or gauges. I have left the 4 switches for the doors disconnected from the wires.
CallMeColt is offline
post #2 of 14 Old 08-25-2009, 08:01 PM
Green4dr
Edit: (Just read the post closer i have no clue) try the knob you pull for the headlights. If you turn it all the way in one direction or the other it clicks and the lights either stay on or go off. It happened to me once.
Thanks for serving for the country
Green4dr is offline
post #3 of 14 Old 08-27-2009, 09:42 AM Thread Starter
CallMeColt
I did make sure that was not on, but thanks for the reminder!
post #4 of 14 Old 08-27-2009, 09:46 AM
mikeypmcg
mikeypmcg's Avatar
if you push on the the rear cargo light it is also a switch that controls the interior lights
1998 Jeep Cherokee Sport6.5" Rough Country Lift (yes I like it)33x12.50x15 BFG KM2 Mud Terrains,Woods rear D.S.
Advanced Adapters SYE D30 front Chr. 8.25 rear AX15 Man Trans NP231, C-Rok steering reinforcement
check it out at:
mikeypmcg is offline
post #5 of 14 Old 08-27-2009, 09:49 AM
XJH-007
XJH-007's Avatar
My 92 did this.....it ended up being a door switch.
I had to remove them all and clean them, I also swapped thier placement (driverside to passenger).
Start with the driverside switch since it is used most often, try swapping it with the passenger side.
Scott-Crawlorado Native
I have an addiction.....
*00' XJ_T-n-T Y-Link/6" RE_OME's_33" KM2's
Tera 4:1 / 4:56's_Elec. Locked D44
**84' CJ7 4"BDS 33's
***02 WJ Overland
XJH-007 is offline
post #6 of 14 Old 08-27-2009, 09:51 AM
mikeypmcg
mikeypmcg's Avatar
easy to see if it is the switch in the drivers side door, put the key in the ignition if it beeps with the door closed then it may the switch or the door hinge is not allowing the door to close properly.
check it out at:
post #7 of 14 Old 08-27-2009, 12:24 PM
Sc00ter
X2
My 3yo son is always crawling in the back and pushing this button. Have to go through the entire vehicle and turn off the radio, wipers, heater, etc.... Genetic payback for the SAME crap I did to my dad over 30 years ago!
Sc00ter is offline
post #8 of 14 Old 08-29-2009, 08:19 AM Thread Starter
CallMeColt
The point I am at right now, I have removed all the switches from the doors. It was my understanding that when they are removed, it is the same as them being pressed, like a default. The only switch I fail to find is the one in the hatch. It seems to be build into the latch for the hatch. I also did check the rear light and clicked it a bunch of times, as well as open it up and checked the switch in there. All seems well with it. I got fed up and just removed all of the interior bulbs so that they can not go on at all. No idea what to try next. My best guess is somewhere in the miles of wires, one spot may be fried and is touching a hot wire and that is why they are just always on. Every once in a while all the lights flicker. A few months back, I had the problem with them all staying on, and it just went away. It's got me stumped!
post #9 of 14 Old 08-29-2009, 08:21 AM Thread Starter
CallMeColt
Forgot to include that I also did take the entire latch assembly out of the hatch, and checked it to make sure it is all good. Nothing seemed to be wrong with it, or the wires going to it.
post #10 of 14 Old 08-29-2009, 08:26 AM
jahlborn
2006 WK
That fuse also controls the radio, and locks. Have any problems with those? Does the radio reset? My 92 did that, turned out the ground wire was busted off the radio and was touching somthing else.
Jacob Ahlborn Four Wheelers of Michigan Tech Public Relations 2011-Present
2006 WK Limited 5.7L HEMI
1994 Cherokee 36" Tires, lots of body damage...rolled
1988 Comanche-New Project
jahlborn is offline
post #11 of 14 Old 08-29-2009, 08:30 AM
jahlborn
2006 WK
Also, try pushing the button on the liftgate end ceiling light. That shuts them off.
jahlborn is offline
post #12 of 14 Old 08-29-2009, 08:37 AM Thread Starter
CallMeColt
No, all my other stuff works fine that is on that fuse.
post #13 of 14 Old 08-29-2009, 08:39 AM Thread Starter
CallMeColt
jahlborn, I think that you are talking about this, and I have checked it. I just did not know exactly what it was called. It the the light you can press if you have the rear hatch open that is between the rear speakers on the roof.
post #14 of 14 Old 08-29-2009, 08:45 AM
jahlborn
2006 WK
Oh yeah my bad, totally skipped over that. I don't know what else to do, time to start checking wires. I'd start up by the headlights swith, my guess is those wires are touching, bypassing that switch, or bypassing in one of the doors right up next to the pins.
jahlborn is offline
Brake Pedal triggers interior lights and running lights HELP!! MontyTJ02 XJ Cherokee Technical Forum 7 01-11-2017 02:24 PM
98 Interior lights stuck on!!!!! o_skiii XJ Cherokee Technical Forum 2 05-25-2009 08:33 PM
No interior lights/parking lights....heads work?? GoldenOne XJ Cherokee Technical Forum 0 05-16-2007 12:53 PM
Tail lights, interior lights, brake lights... no work 4x4life XJ Cherokee Technical Forum 11 02-15-2006 10:28 PM
Tail lights and interior lights go out when it rains! Bradley XJ Cherokee Technical Forum 2 03-26-2005 08:08 AM
