intakes a plus or not - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > intakes a plus or not
Travelling with Pets?Amsteel Blue Synthetic Winch line Free ShippingSteering and more from Ruffstuff!
Unread 02-07-2006, 06:11 PM   #1
bart1
i was wondering if a better intake for my xj would do me any good without doing a lot more mods. is there a noticable change right after putting on a intake like k&n just for example?and also what is the difference between a suspension lift and a body lift . is one better than the other or what?
bart1 is offline   Reply With Quote
Unread 02-07-2006, 06:42 PM   #2
Vaj
For 99% of cars, an intake is a giant waste of money.
Vaj is offline   Reply With Quote
Unread 02-07-2006, 06:48 PM   #3
mk20rockeye
1992 XJ Cherokee
XJ is unibody.....no bodylift allowed, so my money is on the suspension lift
Your lack of planning does not constitute an emergency on my part
1992 XJ Laredo 4.0L, AW4, NP242, 3.5" RE super ride
Definity Dakota 31x10.50 MT's Cragar soft 8
Marine Corps Jeep club member #9
mk20rockeye is offline   Reply With Quote
Unread 02-07-2006, 06:53 PM   #4
cmotsvt
A body lift uses spacers between the frame and the body.
cmotsvt is offline   Reply With Quote
Unread 02-07-2006, 06:59 PM   #5
Grand Fan 4eva
XJ's aren't easy to put put a body lift on, its all one piece there technically is no "frame" the only benefit to a body lift is clearance for bigger tires, the suspension still has the same amount of flex
TORQUE... An Underrated Anti-Depressant.
'97 XJ ~5" / 33 trxus / RK 3-link / FOA 12" CO's
'00 XJ Stock DD
'68 M715
'98 5.9 Limited
Grand Fan 4eva is offline   Reply With Quote
Unread 02-07-2006, 07:18 PM   #6
BrunoS
to get back on topic:
1) on xj's stick with high-flow cat and performance aftermarket muffler as first mod. why? your stock cat is shot to hell already, and the stock muffler is a real performance killer. dyno-proven gains are 5hp and 7hp.
2) Next up is air filter box mod. drill some extra holes in front/fender side of lower airbox using circle saw, say 2 or 2.5 inch. remove the bug shield/water plate that covers up the hole behind the left front headlight....this restores cold air to the intake air box if stock. be careful going through 3' deep water after this mod. hell, that's deep enough to hurt alot of parts if you go fast enough.
if your wallet is deep, then go with a rusty's or k&n FIPK, it's been shown to help a bit.
3) after this, then consider a 3" lift, and 30" tires. 31"s start to hurt with stock gears, but a stickshift and mod #1 make things this far ok.
4) don't worry about aftermarket intake manifolds unless you are there already, then a 99' or newer has better runners. you might just want to stick with a 1" throttle body spacer to give a little longer intake manifold runner length. I have the template so you can hack one out of a chunk of 1" aluminum and save $30.
after all this, you'll have a 205-210 hp, 260ft-lb at flywheel 4.0 H.O. output, which, beyond that, will require some more bucks and you are almost ready to get a stroker kit to make more power than that.
Newly Painted! Emerald Green '96 XJ 4x4 4.0 HO 5-spd
3" Lift + 31" Tires / D35 TracLok / NP231
Drilled out Stock Airbox / Gauge Cluster Upgrade
Magnaflow Muffler / High-flo Cat / MSD Coil
BrunoS is offline   Reply With Quote
Unread 02-07-2006, 08:55 PM   #7
dynamite44
some will say they feel a difference.
when i was a kid, i'd swear i could jump higher and run faster with a new pair of sneakers.
it may be a mind game, but who knows. it looks/seems more efficient.
2000 XJ silverstone metallic.
[URL=http://www.capitaljeeps.com/jotm.shtml]i won jeep of the month on my local club page![/URL]
[URL=http://community.webshots.com/album/265206206KXtdOH]webshots off road pix[/URL]
[URL=http://members.cardomain.com/outofcontrol]Cardomain[/URL]
[URL=http://capitaljeeps.com/gallery/dynamite44sgallery]my capitaljeeps.com gallery[/URL]
dynamite44 is offline   Reply With Quote
Unread 02-07-2006, 11:02 PM   #8
JBassXJ
I did
I know I did
It is and it is
If you are truely planning on replacing most exhaust parts, then you can do a homebrew intake mod (or go to rusty's website and purchase that) and then later on down the line change out the exhaust manifold and rest of the exhaust. It will definitely help the engine breath. If you're not planning on spending all that cash... then a cone air intake doesn't hurt. If you don't even wish to that, then at least get a k&n drop in filter and do the stock airbox mod that was previously suggested.
hope that helps, have fun!
soon to be enforced in close to all threads....
Originally Posted by Blake
Pics or ban.
JBassXJ is offline   Reply With Quote
Unread 02-08-2006, 04:33 AM   #9
XJdamyankee
aftermarket intake manifolds??? Who makes them?? I've looked around and I can only find them for carb'd XJ's and not Fuel injected.
96 cherkoee SE I-6 AW-4 np231 dana30/chrys 8.25
Doug Thorley Tri-Y header/magnaflow cat/rustys FM50 exhaust
Kumho KL71's 31x10.5x15 mounted on rock crusher 15x8 w/4.5"BS black D-window
OME 2" lift & shocks, RE super-ride control arms
XJdamyankee is offline   Reply With Quote
Unread 02-08-2006, 06:40 AM   #10
dynamite44
somewhere, someone out there put a 99 up (or maybe it was 2000 up) XJ intake mainfold on an older 4.0L engine. they had to shave down the power steering bracket or some metal from the intake mainfold to make it fit there, but that was about it.
