Intake air temperature signal out of range - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > Intake air temperature signal out of range
RuffStuff Memorial Day Sale!Poison Spyder to donate 10% of Memorial Day W/E Sales to RNEW JK All Terrain Bumper and X-Style Stryker Stinger - 20
Unread 05-06-2003, 08:21 PM   #1
RockinXJ
RockinXJ's Avatar
Ok, so I'm driving down the road and the check engine light comes on. I get home and run the check of trouble codes to see what codes come up. I get a 12 and a 23. 12 means the battery has recently been disconnected, which it has, and 23 gives me the title of this post, Intake air temperature signal out of range. What does this mean? Has a sensor gone bad on me?
Thanks for the help.
http://www.dfw-tx4wd.org
If you light a fire for a man you'll keep him warm for a day, but if you light a man on fire, you'll keep him warm for the rest of his life!
I ♥ Transitive Pictograph Verbalizations
RockinXJ is offline   Reply With Quote
Unread 05-06-2003, 09:09 PM   #2
Dacaur
2008 MK Patriot
well that, or mabye you were driving over a volcano?
Dacaur
99 WJ Laredo
2.5" Budget boost, 265/75/16 tires, K&N air filter
www.dacaur.com/jeep.html
Past Jeeps:
1992 YJ 4.0, 5 speed 6", lift 33's
1992 XJ 4.0, auto, 3" lift, 31's
1999 XJ 4.0, auto, 3" lift, 31's
1985 XJ 2.5, 5 speed, no lift, 255/70/15's
Dacaur is offline   Reply With Quote
Unread 05-06-2003, 10:49 PM   #3
RockinXJ
RockinXJ's Avatar
Well, if that were the case, then I think my tires might have melted.
Unread 05-07-2003, 01:41 AM   #4
balloo93
Little Red Menace
balloo93's Avatar
1993 XJ Cherokee
My 93 is a much simpler ECU, but in other applications I would suggest cleaning the MAF meter. But I honestly don't even know if the XJ's have one.
I would start by checking the air filter. If that's clean, work your way to the TB and look for leaks. I really on't know if the MAP would trip that code, but it might be worth checking the vacuum connection on the MAP and the connector to the MAP sensor on the intake.
That's all I can think of right now.
93 Sport
Beer is proof that God loves us and wants us to be happy............Ben Franklin
Specs in Profile.
http://www.cardomain.com/ride/325707/1
http://www.cardomain.com/ride/2406854/1
balloo93 is offline   Reply With Quote
Unread 05-07-2003, 10:11 PM   #5
ChrisinVA
The intake temp sensor is probably kaput. As a mod, some people relocate the sucker from the intake plenum to the airbox. This fools the computer into thinking the air is cooler, so it richens the mixture a tad for more power.
I'll get around to doing that one of these days...
94 XJ, 4.0/AW4/8.25/242. 145k miles, bought it in march of '02. Rusty's towhook on front, Hidden Hitch out back with shackle. Rebuilt AW4 in January, '03. Kumho MT's on AR767.
ChrisinVA is offline   Reply With Quote
