Instrument cluster removal help, please - JeepForum.com
post #1 of 6 Old 09-26-2009, 01:18 PM Thread Starter
sw19
I have to replace a bulb in the instrument cluster on my 99 Cherokee Limited. The repair manual says there's 4 screws but, the diagram shows only 2 on the bottom.
Anybody know the easiest way to replace a bulb? It's amazing how someone can design something so it takes an hour just to replace a dashboard light.
What happened to the days where you just stuck your hand up under the dash and popped out the bulb?
sw19 is offline
post #2 of 6 Old 09-26-2009, 02:19 PM
dagr8tim
dagr8tim's Avatar
1997 XJ Cherokee
Pop the trim around the radio & climate control. Remove the kick panel trim under the dash on the driver side. Remove the trim bezel that goes around the cluster. A trick is to release the head light knob. Reach up under the dash and between the head light switch and steering wheel is a button on the head light switch. Depress the button, and pull on the head light knob. It should pop out.
At that point, the 4 screws are obvious.
This is the bracket that the cluster attaches too with the headlight switch still attached. The 4 metal screw holes are the screws for the cluster.
This is the back side of the headlight switch to show the release button for the headlight switch.
Hope this helps. Removing the cluster is less than 10 minutes, once you get familiar with how it comes apart.
Jeeping - The art of getting dirty & going broke while slowly heading nowhere, and taking all day to do it.
97 XJ SE - The War Wagon
98 TJ - Mall Crawler/Light Trail Rig
dagr8tim is offline
post #3 of 6 Old 09-26-2009, 04:45 PM Thread Starter
sw19
dagr8tim, thanks for the photos. It's still a long way to go to replace a bulb. But if that's what's got to be done...
sw19 is offline
post #4 of 6 Old 09-26-2009, 05:05 PM
firehawk
firehawk's Avatar
Just a little FYI. Here's what I did after I removed the instrument panel for the same reason a couple of weeks ago. Take a Dremel tool, or a round file and open up the hole for the headlight switch. It dosen't take much, and you will not have to fight the knob not fitting thru the hole anymore.
Why in the hell would Jeep not design the stupid hole so it would fit over the knob.
2000 Cherokee Sport
Patriot Blue
4.0L / AW4 / NP 242, blah, blah, blah...
A lot of parts that cost a lot of money
xjTalk.com
firehawk is offline
post #5 of 6 Old 09-29-2009, 03:46 PM Thread Starter
sw19
So now that you've showed me how to remove everything...
Before I do, does anybody know what bulb is used? It's to the left of the tach (upper left). I bought a #74. I want to have the correct bulb before I start.
sw19 is offline
post #6 of 6 Old 09-29-2009, 04:31 PM
firehawk
firehawk's Avatar
I have never seen that type of bulb anywhere. I'm not saying it isn't available somewhere though. It is a bulb with a plastic base that you turn and remove. It has a blue plastic/rubber cover over the bulb to give you the blue/green light. BTW, all the bulbs in the instrument cluster are the same. If I remember right there are 4 bulbs.
I went to a pic a part locally and removed the instrument cluster in an XJ there and took every bulb. They didn't even bother to charge me anything for them.
2000 Cherokee Sport
Patriot Blue
xjTalk.com
firehawk is offline
Instrument Cluster Bezel removal aceshighxxx XJ Cherokee Technical Forum 6 01-31-2008 08:21 PM
instrument cluster from 96.. will it fit my 90? hockey10588 XJ Cherokee Technical Forum 1 07-03-2006 01:21 AM
Instrument cluster (again) mbood82 XJ Cherokee Technical Forum 7 02-18-2004 06:43 PM
Instrument cluster Cowthief XJ Cherokee Technical Forum 6 05-31-2003 09:03 PM
