Instructions on rebuilding a dana 35?
| Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line | GR8TOPS Introduces the Exogate HD Tire Carrier | The Original 3/8" Ruffstuff Diff Cover! |
#1 | |
Anyone know if there is a guide or anything like that on here or the net to help me install 410 gears in my dana 35? any help is appreciated
#2 |
The Guru of Nothing
go to the JY, grab a 8.25 out of a 96+ XJ and regear it while its not under your jeep. You will end up with a much stonger axle and you will save money with the install because it is not under your jeep.
-Kyle
North Bay, CA Jeepers Post Here My Build Thread ~My Write Ups~ It's Not Just a Jeep, It's a Lifestyle
#3 |
Go Jeepin
SEARCH works well, Google does too. -
. http://www.jeepforum.com/forum/showthread.DANA-35-rebuild . http://www.differentials.com/install.html http://www.ringpinion.com/HowTo.aspx You will probably need a new carrier for 4.10's, they won't fit on a carrier for 3.55's
. FOR SALE: Wide Track CJ-7 Dana 44 rear axle. PM me for details A Government big enough to give you everything you want, is a Government big enough to take from you
everything you have. The course of history shows that as a Government grows, Liberty decreases. Last edited by CJ7-Tim; 06-10-2007 at 04:12 PM.. |
#4 |
anyone else have any sites with instructions also. the one posted thats on here doesnt work.
#5 |
http://pirate4x4.com/tech/billavista/Gear_Setup/
but personally, I wouldn't waste my time on a dana 35 |
#6 |
Little Red Menace
I pretty much have the same opinion as the others, but if you are dead set on building your D35, I personally would do it this way:
Buy another D35 to use as your build up mule. Do the gear install and swap it in. If it blows up then you can put your old axle back in. You can find D35's for around $100 sinse no one really wants them. Hell, buy a dirty nasty, high miles one and rebuild it. Get a master install kit and axle bearings and it will be good as new. Geras are tricky business. That's why shops can charge $300-400 an axle. Read, read, and reread the install procedures. Take the stock pinion bearing out and have it milled out enough so it slides onto the new pinion, but is tight. This will help you when you are figuring out the corrcet amount of shim to use.
93 Sport Beer is proof that God loves us and wants us to be happy............Ben Franklin Specs in Profile. http://www.cardomain.com/ride/325707/1 http://www.cardomain.com/ride/2406854/1 |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
