Installing a Zone 4.5in lift - JeepForum.com
post #1 of 12 Old 08-15-2013, 08:02 AM Thread Starter
patrickomalley
I was curious on how hard it is to instal a lift from my garage. I have a few friends with some car knowledge, and so tools and whatnot wouldn't be much of an issue. Just don't know how long it takes and if paying the installation price would be worth it.
The lift kit is $500 and the place is charging $500 to install.
patrickomalley is offline
post #2 of 12 Old 08-15-2013, 01:55 PM
zjloyal123
What kind of jeep? I have a 95 zj and I went to a place to see about a 4.5 inch lift kit and they quoted me 1350 for the kit and installation
zjloyal123 is offline
post #3 of 12 Old 08-15-2013, 03:34 PM
Holder350
1995 XJ Cherokee
Your biggest issue will be the rear shock bolts and the front leaf spring bolts.
I would do some research on those points before you get into it so you'll know what problems to expect.
Sent from my phone
95' XJ Country - Stock Skids - D30/D35 Limited Slip - 3" Lift - 31x10.50R15 - 4.0 HO - AX15 - NP231
98' XJ Classic - D30/C8.25 - 4.5" RC Lift - 33x12.50R15 - 4.0 HO - AW4 - NP231
Originally Posted by Azzy View Post
You can tell the character of a person in how they treat someone who can do nothing for them.
Holder350 is offline
post #4 of 12 Old 08-15-2013, 04:10 PM
graytm4
1997 XJ Cherokee
It's fairly straight forward job. You will need coil spring compressors, but you can rent those from any auto store.
graytm4 is offline
post #5 of 12 Old 08-15-2013, 06:56 PM Thread Starter
patrickomalley
Its a 2001 XJ, and alright, if anyone knows of a decent video tutorial on installing really any lift kit on a XJ, it would be appreciated if you posted it. I don't wanna spend the extra 500-600 bucks on installation.
post #6 of 12 Old 08-15-2013, 08:11 PM
Jonathanjr1
Rear http://youtu.be/7KUa-6rdSQs
Front http://youtu.be/WRFiHGqxJ9sSome helpful tools are impact,pentrating oil, prybar if you dont have coil compressors,tortch. Start spraying those bolts now if they are rusty.
Jonathanjr1 is offline
post #7 of 12 Old 08-16-2013, 06:38 AM Thread Starter
patrickomalley
The URL for the front is messed up I think, but thanks.
post #8 of 12 Old 08-16-2013, 09:11 AM
jserna
1987 YJ Wrangler
Start soaking all the nuts and bolts that are going to be removed according to your instructions. Spray them down a couple of times per day if you can with a penetrating oil (other then WD-40), PB Blaster has always worked well for me. Give it a few days to soak before you start working.
jserna is offline
post #9 of 12 Old 08-23-2013, 12:48 PM Thread Starter
patrickomalley
After getting into the job, I broke all 4 shock bolts, and am struggling very hard with getting the shackle bolts out. Punched out the shock bolts and ran new ones in so that is no big deal. Just can't seem to get the shackle bolts to thread out. I guess they are stuck in the bushing. I don't want to cut through the shackle though.
post #10 of 12 Old 08-23-2013, 04:45 PM
NYTrailrider
1988 MJ Comanche
I did it on my MJ by myself and it took like 3 days with work, and 5 total to button everything up. I cit each side of the shackle bolts right off, the rest I soaked for 2 weeks straight.
didn't you get new shackles with the kit? Cut the old ones right off.
Here's mine if it helps.
http://www.jeepforum.com/forum/f22/8...pable-1504994/
88 Comanche AX15/NP231 swap. Zone 4.5" lift Future-Dana 44s, lockers, 36" tires, 4BT swap
NYTrailrider is offline
post #11 of 12 Old 08-24-2013, 07:20 AM
rugsucka
Upper shackle bolts and front leaf bolts rust welding to the bushing is very common. Search for common repair threads, but essentially many end up cutting the bolt with a sawzall or grinder and backing the stub out of the inner weldnut.
I got lucky with my upper shackle bolt.
Apply antiseize liberally as you reassemble.
rugsucka is offline
post #12 of 12 Old 08-24-2013, 08:50 AM
psychoteen101
Sawzall and a torch are almost a necessity here. I had to cut the shackle bolts as well as the leaf spring bolts on mine. Its not too difficult, just takes a while.
1996 Jeep Cherokee- Project-- Rusty's 8in long arm, SYE kit, Teraflex driveshaft, Cragar soft 8's 15x10 with 33x12.5 Firestone Destination MT's, Eaton Tru Trac in the front
psychoteen101 is offline
