installing new rear shackles - JeepForum.com
post #1 of 2 Old 09-17-2008, 03:37 PM Thread Starter
tahoevicxj
1991 XJ Cherokee
Is there a nut to the top bolt on the stock shackles? cause i can't see it or how do you get to it. The bolt are really stuck probably haven't been moved since they where installed. what do i use to loosen them up?
91' xj with upcountry package
1.75" coil spacer. 2" shackles
front sits at 3.5" taller than stock and rear 1.5"
1.25 wheel spacers spidertrax
tires 245 75 16 rubi moabs
snow tires 235
K&N intake, flowmaster delta 50, and other small mods
tahoevicxj is offline
post #2 of 2 Old 09-17-2008, 03:56 PM
mecompco
www.midcoastjeep.com
mecompco's Avatar
1994 XJ Cherokee
The nut is "captive", i.e. it is welded to the unibody. There is a small access hole behind the bumper, if you want to get in there and hit it with some PB Blaster (very good idea). If (when) you break it off, you can enlarge the hole to weld a new nut in, like this:
'94 Cherokee Country
Engine: 4.0 HO, Sealed canister filter, 3 core CSF steel radiator, CatCo cat, Dynomax Turbo Flow muffler.
Electronics: Remote start/locks, Pioneer DEH-P7800MP w/XM, Polk Audio speakers, Garmin Nuvi 660 GPS, Cobra 148 GTL P&T w/Wilson 1000.
Suspension: Old Man Emu 3" lift+OME AAL, JKS adjustable trackbar, QDs, LCAs UCAs, A.C.O.S., DPG Offroad adjustable bumpstop plate, Daystar poly bumpstops.
Steering: Currie HD steering, C-ROK steering box reinforcement, OME stabilizer.
Armor/Recovery: T&T Custom belly skid, Mopar gas tank skid, JKS LCA mini skids, Rock Lizard Super Skink Sliders, Mopar 2" receiver, ARB Bull Bar/Ramsey REP 8.5 winch.
Drive train: D30 front axle w/Superior Chromo D30 axles & outter seals, D/S 4.56 R&P, ARB locker, Ruff Stuff cover. Ford 8.8 rear axle w/Superior Super 88 kit, Ford Motor Sports 4.56 R&P, ARB locker, SOLID cover, Russell stainless lines. Front and rear Tom Woods HD drive shafts, 242 x-fer case w/Tom Woods SYE.
Tires/Wheels: 33x10.5x15 BFG Mud Terrains on Alcoas.
Misc: Garvin Wilderness rack, Safari Snorkel, Redline Tuning hood lifts.
Awaiting installation: Autometer A pillar gauge pod, oil, water, & tranny temp guages, PIAA driving lights, Goferit tie-rod flip bushing, '95 Brake booster and M/C, M.O.R.E. Motor mounts, TnT Custom 1.5" Shackle.
Stroker Project: HO Block, '99 intake manifold, bored TB, 1" TB spacer, Dynomax Blackjack Header, Permacool electric fan.
mecompco is offline
Any tricks to installing lift shackles? Kevin108 XJ Cherokee Technical Forum 7 01-15-2010 11:01 PM
installing rough country shackles tomorrow kboyts XJ Cherokee Technical Forum 1 07-06-2009 04:50 PM
do I need to modify my exhaust when installing longer shackles? rosader XJ Cherokee Technical Forum 11 11-28-2006 12:51 PM
Installing Lift Shackles! MendoXJ XJ Cherokee Technical Forum 3 07-17-2003 05:46 AM
