Installed HID lights on my 98 Cherokee need help - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ Cherokee Technical Forum > Installed HID lights on my 98 Cherokee need help
Ruffstuff 10 year saleBDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRough Country Lift Kits and Parts!
Unread 11-19-2015, 05:32 PM   #1
rinkerx
my old headlight went bad so I decided on getting a HID conversion kit, the kit came ready to hook up to the old plugs.
I plugged everything in and it started humming under the steering wheel (resistor) so I unplugged the resistor and they worked for a while now my left turn signal wont work, my dome light won't come on when I open the door, and the lights seem very dim?
Any idea on how I could fix this? does the pull out headlight switch have a certain amount it came handle?
rinkerx is offline   Reply With Quote Quick reply to this message
Unread 11-19-2015, 05:41 PM   #2
FairlanePhil
If you didn't add a relay harness you may have fried some stuff
The switch is finicky and the whole system has an amount it can handle: not enough.
Current: 99XJ 6.5 lift-Bought 2015
Sold: Patriot Blue 00 XJ.
'sploded: 01 stock-0331 head victim
FairlanePhil is offline   Reply With Quote Quick reply to this message
Unread 11-19-2015, 05:47 PM   #3
rinkerx
Alright, I did blow a fuse.. I haven't messed with it since.. any good diagrams on building a relay?
Unread 11-19-2015, 06:41 PM   #4
BlkCherry92XJ
1992 XJ Cherokee
They have a couple of decent pre-built relay harness' on ebay. I picked one up the other day for around $30 with set of HID's. Have not installed it yet, but it looks to be good quality plus plug and play.
Rusty's Off-Road Products--Harmon 4 Wheel Drive
Built not Bought!--Chrome don't get you home!
If it aint broke...upgrade it!
BlkCherry92XJ is offline   Reply With Quote Quick reply to this message
Unread 11-20-2015, 05:34 PM   #5
wizardPC
You didnt get wiring and HIDs for $30
http://GunsCarsTech.com
If I've never pissed you off, give it time.
wizardPC is online now   Reply With Quote Quick reply to this message
