Installed adj uppers n lowers now steering probs, bumpsteer? Caster? - Page 2 - JeepForum.com
post #16 of 21 Old 07-02-2010, 05:19 PM
wil badger
Unless you have an alignment machine your not going to be able to get the caster on. You can't just slap an angle find on something to set it. If you have it set then you can use an angle finder on the front of the housing or any other flat regular surface to get a bearing and make changes from there.
The stock settings are between 5~7 positive caster
wil badger is offline
post #17 of 21 Old 07-02-2010, 05:22 PM Thread Starter
Sleeeper
I do aligments at my shop,lol But no time with the schedule to get it done anytime soon so i want to get it close at home. I thought you go below stock settings with a lift like mine?
2004 WJ Laredo,4" IRO ADJ fronts
A Arm spacer, DT shocks, JK wheels 285/70/17 STT Pro
Sleeeper is offline
post #18 of 21 Old 07-02-2010, 05:25 PM
wil badger
If you want to try and get it close you can take a straight edge and try to get it inline as much as possible with the center of the upper and lower ball joints. Then place your angle finder on that.
post #19 of 21 Old 07-02-2010, 05:28 PM Thread Starter
Sleeeper
Hmm. i have no way of getting my finder inbetween them...
Sleeeper is offline
post #20 of 21 Old 07-02-2010, 05:28 PM
wil badger
Lift has nothing to do with the amount of caster the front end needs to operate properly. The only reason you would drop it a bit less would be to help with the pinion angle.
post #21 of 21 Old 07-02-2010, 05:32 PM
wil badger
Place a straight edge against the inner C. measure from the side of the straight edge to the center of both ball joints. You might have to add a shim to the top or bottom to get the measurement even top and bottom. Once you do then you have something to measure off of.
caster , bumpsteer , control arm , adjustable
New steering box installed and I have questions Amadeus3 XJ Cherokee Technical Forum 5 05-20-2009 02:35 PM
Any probs with shims installed? nrpalmer32 XJ Cherokee Technical Forum 3 02-06-2009 09:18 AM
new power steering probs? 96fleXJ XJ Cherokee Technical Forum 1 12-25-2008 09:33 PM
caster: adj. uppers or lowers? joshbish XJ Cherokee Technical Forum 2 04-11-2005 10:02 PM
Power Steering Probs Scrub XJ Cherokee Technical Forum 2 02-23-2005 11:22 AM
