Installed adj uppers n lowers now steering probs, bumpsteer? Caster? - JeepForum.com
post #1 of 21 Old 07-01-2010, 03:01 PM Thread Starter
Sleeeper
Well last night i started my project finnally, TNT adj uppers, RC adj lowers, Teraflex 1 1/4'' coil spacers, RC drop brackets and some brute force. Now when i drive it veers all over the place and i guess has bumpsteer? The wheel does not jerk but it goes left or right when i go ove r a bump in the road as well as goes left or right sometimes when i am on the brakes.
Everything is tight, i have a HD trac bar and drop bracket and the lowers/ upers are newish with good heims and bushings. Now two things....
1. I am not sure what the caster is right now but i put a degree wheel on the bottom of the front driveshaft u-joint and it says 10 degrees i think from what i rememeber.
2. When you look at the coil springs from the wheel well they are tilted towards the back, not straight up and down. The wheels look centered in the wheel well but who knows, they were like that before i did this work and thought this would take care of it. The factory bumpstop is near the rear of the coil,not in the middle.
Any ideas on what to do? I can attempt the alignment at my shop but i have no clue what the caster should be at 5.5-6''. It drives fine down the road at 40-50 mph unless i hit a bump or crest in the road....
2004 WJ Laredo,4" IRO ADJ fronts
A Arm spacer, DT shocks, JK wheels 285/70/17 STT Pro
Sleeeper is offline
post #2 of 21 Old 07-01-2010, 03:19 PM
wil badger
If you can post a front on picture of the axle to see the angle of your trackbar to your draglink would be a big help. You can't measure your caster by using the pinion angle. You can use it for reference if you are working on the front end but that's not were you want to take a measurement to just check it.
wil badger is offline
post #3 of 21 Old 07-01-2010, 03:22 PM Thread Starter
Sleeeper
Well i am pretty sure it is nothe trac bar, i had it on there before this and it drove just fine, i have driven jeeps with a bad tb as well as off center axle and this does not feel like it.
I will try to take pics here tonight
Sleeeper is offline
post #4 of 21 Old 07-01-2010, 06:58 PM Thread Starter
Sleeeper
It looks just like this kinda bent/ tilted back, but mine is with the wheel on and and on the ground...
Uploaded with ImageShack.us
Seems to me maybe the lowers are not adjusted out far enough? And if i adjust them out more than i think the wheel will not be centered up front in the well? Should i use the 101'' wheel base rule and go from there?
Sleeeper is offline
post #5 of 21 Old 07-01-2010, 07:07 PM
wil badger
If your spring is bending back that far your arms are to short. One of the main causes to bump steer is the track bar and draglink not matching arcs through their movement. You might not have had bumpsteer before or might have but it was minimal. Now that you have added more lift this have changed. So now it might be more pronounced. Your caster could be off but that doesn't really lead to bump steer but death wobble. Think of a shopping cart with a bad front wheel. If the caster isn't correct the wheel will want to wonder.
post #6 of 21 Old 07-01-2010, 07:12 PM Thread Starter
Sleeeper
Makes sense, i guess you could say that the steering is squirelly (spelling) then, not much bumpsteerish. I think this is caster related wouldnt you think with my coil looking like that pic?
I just do not think that if i adj the lowers out that the wheels will sit right in the wheel well?
Sleeeper is offline
post #7 of 21 Old 07-01-2010, 07:12 PM
xjfever
xjfever's Avatar
1995 XJ Cherokee
You need an alignment after the extra lift, but I am with Will on the bumpsteer. The caster can cause wandering too though.
xjfever is offline
post #8 of 21 Old 07-01-2010, 07:14 PM
xjfever
xjfever's Avatar
1995 XJ Cherokee
The lower arms are generally used to put the axle where you need it, and then the uppers are used to set caster/pinion angle. Shortening the uppers will give better caster, and worse pinion angle.
xjfever is offline
post #9 of 21 Old 07-01-2010, 07:34 PM
wil badger
Don't worry some much about having the axle centered or what you think is centered. It doesn't hurt to have it a bit forward. If your spring is bowing back like in the picture above and is starting to touch the upper spring pad/ post then you are clearly to far back. The spring should be coming straight down and be in a parallel line to the pad/post.
Go get an alignment from a reputable place. Most will give you a lifetime alignment anymore. Still wouldn't mind seeing a front on shot of what you have. It would help in determining if it could be bump steer. If your steering wheel is trying to turn as you go over a bump with one side of the vehicle it is most likely bump steer. If you are going down the road and hit a slight bump and the vehicle starts to slightly shake then your caster is off.
post #10 of 21 Old 07-01-2010, 07:40 PM Thread Starter
Sleeeper
I will def try and get you a pic tomorrow. As far as the bumpsteer i am pretty sure it is not, i have had it before on my old xj and this one. I think the caster is screwy.
I am however worried about th coil like you stated. But if i push it forward, when i flex i will be hitting my ARB bull bar and tearing up my tire... BUT i have been wanting to cut the corners off for awhile now for that reason so i guess no better time than now
Sleeeper is offline
post #11 of 21 Old 07-01-2010, 08:55 PM
Dgaunt1
Dgaunt1's Avatar
Do you have a drop pitman arm installed? If you have a trackbar drop bracket, then you must use a drop pitman arm to get the angles of the drag link and trackbar somewhat close. I believe if you have one without the other, you get bumpsteer.
Dgaunt1 is offline
post #12 of 21 Old 07-02-2010, 03:59 PM Thread Starter
Sleeeper
here are some pics. After looking at it today more closely i think i have to adjust my uppers to pull back the caster a lil bit. That should pull the coils back straight i beleive.
Sleeeper is offline
post #13 of 21 Old 07-02-2010, 04:29 PM
xjfever
xjfever's Avatar
1995 XJ Cherokee
I would try shortening the uppers too. Can't really see the pinion angle in those, but you will have to find the sweet spot between caster/pinion angle to where it has no vibes, but steers correctly.
xjfever is offline
post #14 of 21 Old 07-02-2010, 04:33 PM
wil badger
Ya your trackbar to draglink is fine or pretty close, so that can be ruled out for now. Since you are dragging the spring on the back side of the post you have to much negative caster. The picture you posted before is the complete opposite of what you have so really that was no help. You differently need to shorten the uppers. You will want to get an alignment to help wrangle in the correct caster. From there you can find the best balanced between caster and pinion angle.
post #15 of 21 Old 07-02-2010, 04:45 PM Thread Starter
Sleeeper
Ok, well what you guys suggest i set the caster at with 5.5-6'' of lift? Thank you
Sleeeper is offline
caster , bumpsteer , control arm , adjustable
New steering box installed and I have questions Amadeus3 XJ Cherokee Technical Forum 5 05-20-2009 02:35 PM
Any probs with shims installed? nrpalmer32 XJ Cherokee Technical Forum 3 02-06-2009 09:18 AM
new power steering probs? 96fleXJ XJ Cherokee Technical Forum 1 12-25-2008 09:33 PM
caster: adj. uppers or lowers? joshbish XJ Cherokee Technical Forum 2 04-11-2005 10:02 PM
Power Steering Probs Scrub XJ Cherokee Technical Forum 2 02-23-2005 11:22 AM
