inner fender: cut & fold pinch seam? - JeepForum.com
post #1 of 8 Old 03-30-2009, 09:45 PM Thread Starter
the303hooligan
Ok, so i trimmed front and rear fenders last week..In the front, there is the pinch seam that runs down the center right above the tire..like a big ole razor blade mohawk!
My question is: Can i make slits between spot welds, fold it over, prime it, some seam sealer, paint it and call it a day?...or do i just hammer the he11 out of it to get it to fold over?..
In the rear, i did the cut and fold method, just want to make sure the front can work the same way without any structural problems...
thanx
Colorado Jeep Club Member #'303'
1998 Jeep Wrangler TJ Sport 4.0 I6, D30 and D44,4.56 G2 Gears,belly,gas & steering skids, 35x12.5 Wrangler MTR Kevlars,4" ProComp Coils,1.25" JKS BL,1"Currie MML,Bilstein 5100's, Chromoly LCA's front and rear, JKS Disco's,K&N intake,PSC BFH front stinger bumper w/winch & d-rings,PSC Rear stinger/carrier w/d-ring,PSC Rocker Knockers,Dynomax Ultraflo welded ss, APN header,PIAA 520 ATP, Bestop top,alpine CDA-105 deck,Tuffy underseat Security box, JL Audio speakers in sound bar and dash, Corbeau front seats, matching Neoprene cover on bench,trimmed flares...and PLENTY more to come..
**Oil Field Trash Makin' Oil Field Ca$h**
the303hooligan is offline
post #2 of 8 Old 03-30-2009, 10:14 PM
nrpalmer32
1987 XJ Cherokee
I've pics of people doing that on here, I plan on doing the same thing. And yeah that pinch seam just looks mean, its sharp.
nrpalmer32 is offline
post #3 of 8 Old 03-31-2009, 01:01 AM
xjpilot
xjpilot's Avatar
I just beat mine into submission and then put some black silicone calk up in it to keep the water out. I think I made maybe 2 or 3 slits in to to help the cause.
my jeep has the confused prerunner syndrome....4.5" in the rear and 2" in the front.
Purple Jeep Club Member # 1
xjpilot is offline
post #4 of 8 Old 03-31-2009, 01:21 AM
dreadhead
I just bashed mine with a hammer too, then just sprayed some paint over it and I've had no problems with it.
xj buggy, tons, 40s, airshocks, 3 linked
dreadhead is offline
post #5 of 8 Old 03-31-2009, 12:46 PM
dcorn
I cut mine between the pinch seams just like the rear fender before I hammered it flat. I figured it would get flatter and out of the way more if I cut it. Cuts are probably around 1.5-2" apart. I then painted the entire front fenderwells with 3M undercoating.
This is a must if you are trimming the fenders and taking out the fender liner. With my setup, I've flexed enough to actually rub all the undercoating off of a 6-8" section of the folded down pinch seam. That would have easily been a flat tire on the trail.
2014 Jeep Grand Cherokee Summit
dcorn is offline
post #6 of 8 Old 03-31-2009, 03:56 PM
xjfever
xjfever's Avatar
1995 XJ Cherokee
I did mine just like dcorn did.
xjfever is offline
post #7 of 8 Old 03-31-2009, 06:26 PM Thread Starter
the303hooligan
Cool...thanx, im aware of the major tire eating issue the seam will cause, just wasnt sure of the better way to deal with it...I ended up using a BFH while i had my jeep on the lift and just hammered it over..was ALOT easier with the correct hammer for the job ..just got done with coat of primer..gonna undercoat later tonite....Thanx again for ur guys feedback
post #8 of 8 Old 04-01-2009, 07:30 AM
dcorn
It sure is. I used a small 2-3 lb sledge for that pinch seam and for the rear fender. It's a good feeling to just beat the hell out of a vehicle with a hammer when I'm used to being so careful with my Mustangs.
dcorn is offline
fender trim - cut and fold on front? redsoxski XJ Cherokee Technical Forum 5 08-08-2008 02:38 PM
cut and fold fender fix iroll919 XJ Cherokee Technical Forum 3 11-08-2007 05:11 AM
cutting the pinch seam for rock rails? aussiewheeler XJ Cherokee Technical Forum 35 05-26-2006 06:45 AM
Rocker panel pinch seam HCA-Bronco XJ Cherokee Technical Forum 5 01-18-2006 03:13 PM
pinch seam on rear fenders silverxj2001 XJ Cherokee Technical Forum 3 05-12-2004 12:19 PM
