Injector Swap Writeup for the 4.0L - Page 9 - JeepForum.com
post #121 of 188 Old 05-08-2013, 06:39 PM
nysm1
Now that I wouldn't be able to help with that, but it shouldn't differ to much... Just search on the forums more, something HAS to be here
nysm1 is offline
post #122 of 188 Old 05-08-2013, 07:33 PM
billybooster2
1983 CJ8
There are only 4 thongs inportant;
1. Disconnect battery
2. Relieve fuel pressure at rail. Looks like a tire valve. Press it in and fuel spurts for a second.
3. Remove fuel lines from rail. There are two. One in. One out.
4.unscrew rail from manifold.
5. Rock rail with attached injectors out of manifold
6. Remove injectors. Follow previous procedures regarding caseline, silicone or other lubricant
7 reverse, reattach.
billybooster2 is offline
post #123 of 188 Old 05-08-2013, 08:01 PM
Jeepuzzled
1989 MJ Comanche
My concern is the fuel regulator that is attached to the front end of the rail. Do I pull it off the rail, or leave it in place connected to the rail and instead disconnect all the other tubes connected to it.
Jeepuzzled is offline
post #124 of 188 Old 05-08-2013, 08:45 PM
billybooster2
1983 CJ8
Leave it on. It only does something when pump is on.
post #125 of 188 Old 05-09-2013, 01:55 PM Thread Starter
dukie564
dukie564's Avatar
1995 XJ Cherokee
you do not have to remove the pressure regulator, just pull off the vacuum line. For the fuel lines squeeze the white tabs in and pull on the hose to remove them from the rail. If the injectors are rebuilt they should already have new orings on them. Rest of the procedure is the same.
1995 XJ Cherokee Sport
4.5" Homebrew Lift, 4.0L HO I-6, AX-15, NP231, D30(Open)/C8.25(Locked)
33x12.5 Mickey Thompson Baja MTZ Tires, 309,000 mi and runnin' strong
dukie564 is offline
post #126 of 188 Old 05-10-2013, 01:54 AM
Jeepuzzled
1989 MJ Comanche
Thanks for your reply. The 89 Comanche is a little bit different than the 95 Sport. I left the regulator on the rail, but I had to disconnect the fuel lines at the rear of the rail ( fuel input), and at the (front) regulator as well ( fuel return). The fuel lines use a 'quick connect' technology that requires replacing the clip, O rings ( 2) and spacer whenever you pull a fuel line apart. There is supposedly a Quick Connect repair kit that has the parts and plug tool for reinstallation, but just try locating one of those kits! That kit has a disposable plug that acts as a mounting tool to reinstall the O rings, spacer and clip on each fuel line connection. I tracked down the separate clips and O rings ( made by Dorman and available on Amazon), but nada on the installation plug.
UPDATE: Morris 4x4 supposedly has this kit. Their Part # 83502745 fuel line repair kit 5/16' fuel line $8.99 . I have ordered a couple of them and will give a future update on how well they work. It does come with the installation mounting tool.
UPDATEII: I received the kits and they worked like a charm to connect my fuel lines in less than 5 minutes. Plus, I now have the two plastic mounting tools to use for O-rings, spacers, and clips if I ever need to disconnect fuel lines in the future. Thanks for your help, folks!
post #127 of 188 Old 06-30-2013, 01:33 PM
hocgreen
Originally Posted by jakecarder View Post
Subscribed page saved. great write uo. used it today to diagnose cylinder one missfire. switched injectors between one and two
I've been looking EVERYWHERE! Can you (or anyone) tell me which injector is injector #1? That injector is bad and I need to swap her out quickly. I am planning on doing this when I have the scratch to drop but right now spit and glue.
Anyone?
hocgreen is offline
post #128 of 188 Old 06-30-2013, 03:00 PM
billybooster2
1983 CJ8
Anyone?
#1 is front of engine
post #129 of 188 Old 09-03-2013, 10:20 AM
Terry777
1997 XJ Cherokee
Spark plug gap
Hey, nice thread thanks for all the detail.
I already posted this question in the engine section but everyone is going to see it so worth a shot here, will a spark plug gap other than the specified plug gap in the Haynes manual (0.035 SAE or 0.89 MM) give any better combustion with the new misting gas?
Terry777 is offline
post #130 of 188 Old 09-03-2013, 06:37 PM
billybooster2
1983 CJ8
I doubt it!
Stick to 35
post #131 of 188 Old 12-01-2013, 09:24 AM
TJ Frank
Subscribed page saved. great write up
1998 TJ 4L - 5.5" long arm - 35"BF mud and a bunch of other mods
2004 WJ 4.7L (wife) stock
2011 JK daily driver stock,... was told by the wife -> no mods allowed... end of the story
TJ Frank is offline
post #132 of 188 Old 12-01-2013, 09:36 AM
brokeagin
In my opinion you will need to upgrade the ignition system in order to increase plug gap...
1998 Wrangler Sahara in a constant state of repair or modification...
brokeagin is offline
post #133 of 188 Old 12-02-2013, 09:14 AM
Mattmax
injector swap writeup for 4.0 L-Jeepforum.com
Have been replacing the injectors on my 87 4.0 L Cherokee, and chipped the bases off some of the electrical connectors. Do I need new connectors if the old are electrically intact?
Mattmax is offline
post #134 of 188 Old 12-02-2013, 09:48 AM
Mattmax
great writeup!
Have been replacing the injectors on my 87 4.0 L Cherokee-Laredo, and chipped the bases off some of the electrical connectors. Do I need new connectors if the original are electrically intact?
Mattmax is offline
post #135 of 188 Old 12-02-2013, 01:01 PM Thread Starter
dukie564
dukie564's Avatar
1995 XJ Cherokee
what do you mean by "bases" of the connectors?
If they stay connected and have good terminal contact, i don't see the need to replace them
dukie564 is offline
D30 differential cover swap writeup TheRifleman XJ Cherokee Technical Forum 50 01-05-2012 07:47 PM
89 injector swap evilbill XJ Cherokee Technical Forum 2 10-21-2010 05:46 AM
injector swap. XJ98beast XJ Cherokee Technical Forum 0 03-01-2010 08:03 AM
injector swap boring96xj XJ Cherokee Technical Forum 1 08-18-2006 09:35 AM
Auto swap to Manual Writeup? Jeepin_XJ_101 XJ Cherokee Technical Forum 3 01-15-2006 02:35 PM
