Injector Swap Writeup for the 4.0L - Page 8 - JeepForum.com
post #106 of 188 Old 04-17-2013, 10:48 AM
misfit77
I used motor oil...no issues yet.
misfit77 is offline
post #107 of 188 Old 04-20-2013, 03:07 PM
DunmerBoy
I went down from 17 mpg to 14. Haha needless to say I did the reset thing
COTM October 2014
DunmerBoy is offline
post #108 of 188 Old 04-21-2013, 10:47 PM
billybooster2
1983 CJ8
Whilenot quite on topic, my jeep is a brick on wheels
I have 258 block, 4.0 head, yj fuel injection, the 4 hole neon injectors, and a cheap eBay header. I get 20mpg on freeway, average 16-17 on short runs. Thats gps mileage, not bogus speedo stuff!
billybooster2 is offline
post #109 of 188 Old 04-24-2013, 10:59 PM
Simmbad
1976 CJ7
great info, cant wait to do this to my 4.0
Simmbad is offline
post #110 of 188 Old 04-28-2013, 03:12 PM
elcapitano
injector swap, no start.
I just finished doing the injector swap. everything is connected, no leaks. but its not starting. engine is turning over, but either no fuel??? or no fire?? not sure. i checked the pressure valve on the fuel rail and fuel came out. any help would be appreciated, this is my daily driver and have work in the morning :-P
Thanks again in advance.
Sorry, its a 88. used the neon 703 injectors
elcapitano is offline
post #111 of 188 Old 04-28-2013, 03:18 PM
billybooster2
1983 CJ8
Turn on and off with key to cycle pump.
post #112 of 188 Old 04-28-2013, 03:21 PM
elcapitano
i have attempted at least 4 starts. should i try more? or just cycle with out trying to start?
update: just cycled to run 4 times and it started on the 5th. now to let the memory re-learn again. Thank you billy.
post #113 of 188 Old 04-28-2013, 03:38 PM
billybooster2
1983 CJ8
Cycle without
post #114 of 188 Old 04-28-2013, 11:40 PM
billybooster2
1983 CJ8
Make sure all the sensors to the throttle body are connected too
post #115 of 188 Old 05-08-2013, 06:30 PM
Jeepuzzled
1989 MJ Comanche
I have a 1989 Jeep Comanche 4.0L that looks different than your engine pictures. I have Googled replacing the injectors on my model Jeep, but only came up with your tutorial for a 1996 Jeep Cherokee. My fuel rail connections are different than yours, and the injectors seem to be using some sort of clip attachment. Could you please direct me to a modified writeup for my vehicle model?
Jeepuzzled is offline
post #116 of 188 Old 05-08-2013, 07:15 PM
nysm1
Post a picture of it here then we will be able to answer your question...
nysm1 is offline
post #117 of 188 Old 05-08-2013, 07:18 PM
Jeepuzzled
1989 MJ Comanche
Originally Posted by Jeepuzzled View Post
I have a 1989 Jeep Comanche 4.0L that looks different than your engine pictures. I have Googled replacing the injectors on my model Jeep, but only came up with your tutorial for a 1995 Jeep Sport 4.0L. My fuel rail connections are different than yours, and the injectors seem to be using some sort of clip attachment. Could you please direct me to a modified writeup for my vehicle model?
I have attached images of my engine.
89FI1.JPG   89FuelPressureReg.JPG   89FuelRail1.JPG   89FuelRail2.JPG   89RearFuelconnection.JPG
post #118 of 188 Old 05-08-2013, 07:20 PM
Jeepuzzled
1989 MJ Comanche
OK, it's done. If you need additional pics, I can load those as well.
post #119 of 188 Old 05-08-2013, 07:25 PM
billybooster2
1983 CJ8
IF YOU HAVE THE RENIX engine, I believe 89-91, then you can use Lincoln Towncar 90's injectors. The Renix engine uses 19lb/hr 39 psi injectors. The 1990-91 4.6L injectors which are also 19lb an hour but 36 psi and they are 4 hole injectors. OEM part number was 0280150943. Also fit Mustangs from later years. Known as the 710 as well. Some say you need to upgrade your regulator on the rail but that's probably not necessary on a stock engine.
SO, disconnect battery, and then anything electrical near the fuel rail. Relieve pressure at fuel rail with rag and pointy object! detach fuel rail and remove and swap injectors. Go backwards to re-install and cycle key to prime rail and check for leaks at rail and injectors before you turn the engine over.
I believe this is what you want
http://www.rockauto.com/catalog/more...471&cc=1188761
OR this
http://www.rockauto.com/catalog/raframecatalog.php?ck[year_1993]=true&ck[mkt_US]=true&ck[mkt_EU]=true&ck[mkt_CA]=true&ck[mkt_MX]=true&ck[ID]=0&ck[idlist]=0&ck[viewcurrency]=USD&ck[PHP_SESSION_ID]=1gslhpo7vlb6pumrp17ppufq30
There are 3 hole, 4 hole and 6 hole variants.... do they look right to you?
post #120 of 188 Old 05-08-2013, 07:32 PM
Jeepuzzled
1989 MJ Comanche
OR this
Thanks. I already have purchased rebuilt 4 hole injectors. Where I am stumped is the process for removing the fuel lines and injectors from the rail. The process explained for the 1995 Sport is different than my engine that has different fuel lines , and a pressure regulator at the end of the rail. I was hoping someone could walk me through a modified detailed tutorial for my '89 Comanche where it differs from the '95 Sport described in detail here. Do I need to remove the regulator from the rail, and if I have to, do I need to replace it or any or the parts associated with it ( O rings, etc.) while replacing the injectors?
D30 differential cover swap writeup TheRifleman XJ Cherokee Technical Forum 50 01-05-2012 08:47 PM
89 injector swap evilbill XJ Cherokee Technical Forum 2 10-21-2010 06:46 AM
injector swap. XJ98beast XJ Cherokee Technical Forum 0 03-01-2010 09:03 AM
injector swap boring96xj XJ Cherokee Technical Forum 1 08-18-2006 10:35 AM
Auto swap to Manual Writeup? Jeepin_XJ_101 XJ Cherokee Technical Forum 3 01-15-2006 03:35 PM
