Injector Swap Writeup for the 4.0L - Page 7 - JeepForum.com
post #91 of 189 Old 10-02-2012, 12:59 PM Thread Starter
dukie564
1995 XJ Cherokee
no not worth it. People on here or cherokeeforum sell them for like $80 for 6 rebuilt, cleaned, and tested.
1995 XJ Cherokee Sport
4.5" Homebrew Lift, 4.0L HO I-6, AX-15, NP231, D30(Open)/C8.25(Locked)
33x12.5 Mickey Thompson Baja MTZ Tires, 309,000 mi and runnin' strong
dukie564 is offline
post #92 of 189 Old 10-02-2012, 02:15 PM
AmbuGrl
AmbuGrl's Avatar
Hellz no would I pay what you saw on ebay. I paid $70 shipped for mine.
- HM1(SW/AW)Ret USN Dec 23,1992 to Dec 31, 2012
I drive an XJ, and all of my power windows work :)
2000 Pontiac WS6 - DD
DD (Mine) Sold - 98 XJ Moss Green
(His) - 92 YJ December 2013 YJOTM
Sold - 95 ZJ
Sold - 97 XJ Red
Sold - 98 XJ
USN Jeep Club Hull #36
NAXJA #3700
Originally Posted by RacerX View Post
WTF is Clockspring??? my Jeep has digital clock
AmbuGrl is offline
post #93 of 189 Old 10-02-2012, 09:20 PM
64tbird
Where can you get them cleaned and tested/flow tested?
64tbird is offline
post #94 of 189 Old 10-02-2012, 11:22 PM
GetLifted
I got mine cleaned rebuilt and flow matched for 90 shipped with a warranty from ebay seller injectordyne
GetLifted is offline
post #95 of 189 Old 10-10-2012, 10:04 PM
RedRyderXJ
1994 XJ Cherokee
Got mine for $45 from x91j when he did it on CF
RedRyderXJ is offline
post #96 of 189 Old 11-24-2012, 10:55 AM
Lubetich
1991 XJ Cherokee
Got mine from the jy, $28 for all 6! Is it normal for a little bit of white smoke to come from the injector area at first? Is that the "Running Rich" You speak of?
Lubetich is offline
post #97 of 189 Old 11-24-2012, 02:57 PM
bigbadduck
1987 XJ Cherokee
Really cool write up
bigbadduck is offline
post #98 of 189 Old 02-19-2013, 08:13 AM
jmiera
great write up !!
jmiera is offline
post #99 of 189 Old 02-19-2013, 08:43 AM
robinz
1990 XJ Cherokee
Originally Posted by 64tbird View Post
Did you need resistors to run the 3.7l injectors? And which wire to which wire when you rewired to run them? I got a set from a 02 and they have been soaking in seafoam for months lol. I forgot about them
Sorry about this late response, I was never notified. No resistors required and wire-to-wire does not matter.
1990 XJ 4.0L I6
robinz is offline
post #100 of 189 Old 04-06-2013, 04:22 PM
DunmerBoy
awesome job with this write up! i did it this morning and couldnt have nearly as easily without it
COTM October 2014
DunmerBoy is offline
post #101 of 189 Old 04-08-2013, 12:30 PM Thread Starter
dukie564
1995 XJ Cherokee
Glad I could help!
dukie564 is offline
post #102 of 189 Old 04-14-2013, 05:13 AM
jeep795
looking at a few of the injector sites, not every injector has the flow rates listed and at what pressure. I always hear to use the ford blue tops, or the four hole siemens... Now neon and libby injectors?? Hard to chose. Is there a list, in order of flow rate/pressure showing the injectors that will fit on a 4.0 rail and what modifications might have to fit for optimum performance on both a single rail and double/return.
some of the links don't show what the original intention was any more. Any chance some of those could be updated? And ya know, I'd really like to hear from some of the stroker guys about what injectors they've used and had success with.
jeep795 is offline
post #103 of 189 Old 04-15-2013, 08:51 AM Thread Starter
dukie564
1995 XJ Cherokee
not sure what links are broken - I just checked and all mine look fine. There is no "list" beyond the image I posted on the first page showing application by year.
Anyways here's a few links for reading up and to give more information:
http://www.ausjeepoffroad.com/forum/...ad.php?t=92236
http://www.cherokeeforum.com/f2/more...48/#post173704
http://www.fuelinjector.citymaker.co...low_Rates.html
Converter: http://www.witchhunter.com/injectorcalc1.php
For Reference:
The stock injectors for Renix flow 240cc, HO flow 248cc (up to 95-OBD1) and 234cc (96- up OBDII). However, the Renix and OBDI flow at 39PSI and the later OBDII ('96 onwards) flow at 49PSI.
Injector flow is always measured at 3 Bar, 43.5PSI. This is a reference point and from this you can calculate the flow to your system working pressure.
Injector size (lb/hr) = (horsepower x 0.5)/(no.of cylinders x 0.8 )
So say you have a 250 horse I6...
125/4.8=26 lb/hr injector
So for a 30 lb/hr injector, you would need about a 290 horse motor to utilize them.
Cherokees from 93 on made around 190hp stock= 19.8 lb injectors according to the above formula
The 24lb injectors should be good for some 230hp.
dukie564 is offline
post #104 of 189 Old 04-16-2013, 01:17 AM
Project1
Originally Posted by dukie564 View Post
Step 15 - Time to lube up! Grab your petroleum jelly, and lube up each o-ring, being careful to keep it away from the pintle holes.
Petroleum based lubes may erode the rubber o-rings and harden them, causing cracks or break apart.
silicone is a better bet really.
Project1 is offline
post #105 of 189 Old 04-16-2013, 06:35 AM Thread Starter
dukie564
1995 XJ Cherokee
meh...2 years and zero issues. With the really small amount I used i'm not worried in the least.
dukie564 is offline
D30 differential cover swap writeup TheRifleman XJ Cherokee Technical Forum 50 01-05-2012 07:47 PM
89 injector swap evilbill XJ Cherokee Technical Forum 2 10-21-2010 05:46 AM
injector swap. XJ98beast XJ Cherokee Technical Forum 0 03-01-2010 08:03 AM
injector swap boring96xj XJ Cherokee Technical Forum 1 08-18-2006 09:35 AM
Auto swap to Manual Writeup? Jeepin_XJ_101 XJ Cherokee Technical Forum 3 01-15-2006 02:35 PM
