Injector Swap Writeup for the 4.0L - Page 4 - JeepForum.com
post #46 of 189 Old 02-16-2012, 12:01 PM Thread Starter
dukie564
1995 XJ Cherokee
Originally Posted by wsar10 View Post
so whats the diff. between 703's and 784's ?
the connector style
do I need ? (93 5spd)
703s
what kind of pricing are we talking for this mod ??
about $70
Can I rebuild my OE injectors with a 4 hole parts kit ??
no, you cannot take them apart like that
1995 XJ Cherokee Sport
4.5" Homebrew Lift, 4.0L HO I-6, AX-15, NP231, D30(Open)/C8.25(Locked)
33x12.5 Mickey Thompson Baja MTZ Tires, 309,000 mi and runnin' strong
dukie564 is offline
post #47 of 189 Old 02-16-2012, 01:30 PM
wsar10
2003 WJ
thanks for the response......
Are yours still working as originally claimed ??
QUOTE=billzcat1;wsar10 is right on point on this oil thread - as usual. Anyone reading this would be well-served taking his advice.
-03 WJ laredo 4.0 120k a few minor mods
-93 XJ 5spd, 3" zone lift
wsar10 is offline
post #48 of 189 Old 02-16-2012, 01:32 PM Thread Starter
dukie564
1995 XJ Cherokee
yup - they work great!
dukie564 is offline
post #49 of 189 Old 03-31-2012, 01:24 AM
PFCLinscomb
Can you shoot me a link for the ones i need for a 94 YJ Wrangler?
Times you kick yourself in your own ***: When that stupid Private wakes the whole platoon up by running through the bay screaming "Reveille,Reveille,Reveille!!!!!!!!!!!!!!!!!!! !" And your like "Who the hell put that guy on last fire guard" and then you realize.... You did -.-
PFCLinscomb is offline
post #50 of 189 Old 03-31-2012, 11:03 AM
Steev89
Thank you! Awesome write up plan on doing this soon hopefully, your write up should make it about 100% easier since ive never done any work with fuel injectors lol
1999 Jeep XJ : 5" lift, TnT y-link radius arms and belly pan, Rugged Ridge sye, TnT body StiffinerZ. Socket forever stuck inside unibody
Steev89 is offline
post #51 of 189 Old 04-02-2012, 11:18 AM Thread Starter
dukie564
1995 XJ Cherokee
94 YJ will use the same injectors as the 87-98 XJs - the *703 injectors
dukie564 is offline
post #52 of 189 Old 04-03-2012, 09:11 AM
TheIceMan
Are the neons a 4 hole injector also or are they just 1 hole??
Know guns, Know peace..
No guns, No peace..
TheIceMan is offline
post #53 of 189 Old 04-03-2012, 09:18 AM Thread Starter
dukie564
1995 XJ Cherokee
yes 4 hole
dukie564 is offline
post #54 of 189 Old 04-26-2012, 05:59 PM
TheIceMan
Not hard to do, just did mine and a vast improvement in idle and response..
No guns, No peace..
post #55 of 189 Old 08-13-2012, 11:16 PM
jakecarder
Subscribed page saved. great write uo. used it today to diagnose cylinder one missfire. switched injectors between one and two
jakecarder is offline
post #56 of 189 Old 08-14-2012, 08:37 AM Thread Starter
dukie564
1995 XJ Cherokee
nice!
dukie564 is offline
post #57 of 189 Old 08-14-2012, 10:15 AM
AmbuGrl
AmbuGrl's Avatar
I did mine last weekend. It was pretty simple and I have noticed a huge difference with it. At idle, acceleration as well as gas mileage. In the past few weeks my mileage dropped from a leaky (#6) injector. Mine is a 98 and we had clips, I left the fuel rail attached at the hard lines and flipped it around to be able to remove each injector. To remove the injectors and the rail, I found it easiest to stand on the drivers side and pull evenly until each one 'popped' out.
- HM1(SW/AW)Ret USN Dec 23,1992 to Dec 31, 2012
I drive an XJ, and all of my power windows work :)
2000 Pontiac WS6 - DD
DD (Mine) Sold - 98 XJ Moss Green
(His) - 92 YJ December 2013 YJOTM
Sold - 95 ZJ
Sold - 97 XJ Red
Sold - 98 XJ
USN Jeep Club Hull #36
NAXJA #3700
Originally Posted by RacerX View Post
WTF is Clockspring??? my Jeep has digital clock
AmbuGrl is offline
post #58 of 189 Old 08-14-2012, 07:33 PM
robinz
1990 XJ Cherokee
I did mine a couple weeks ago using injectors from a Jeep Liberty 3.7liter V6. I have a 1990 XJ. I used this thread to inspire me to do the job as I have never worked on the fuel rail before. I also did a YouTube video to accompany this thread. http://www.youtube.com/watch?v=Izj6q6o59L4
After everything was all said and done, I would add an asterisk on step #6, disconnecting the fuel lines. In my FSM it states that whenever the fuel line is disconnected, the o-rings should be replaced. I would recommend you have the o-rings on hand PRIOR to starting the job. I had a thread going over here with details on the o-rings;
http://www.naxja.org/forum/showthread.php?t=1086841
robinz is offline
post #59 of 189 Old 09-04-2012, 09:50 AM
breakpoint
My '01 4.0L Grand has been generating cylinder misfire reports for the last year. We've swapped the coil pack, but I've been thinking that it may be bad o-rings on my injectors.
Would cracked rings generate misfire codes?
Thanks.
breakpoint is offline
post #60 of 189 Old 09-04-2012, 09:54 AM Thread Starter
dukie564
1995 XJ Cherokee
bad orings are most likely not the cause of your misfire code.
clogged injectors however might be. It'd be worth taking them out and soaking them in seafoam overnight and clean them up, then re-installing them with new orings.
dukie564 is offline
D30 differential cover swap writeup TheRifleman XJ Cherokee Technical Forum 50 01-05-2012 08:47 PM
89 injector swap evilbill XJ Cherokee Technical Forum 2 10-21-2010 06:46 AM
injector swap. XJ98beast XJ Cherokee Technical Forum 0 03-01-2010 09:03 AM
injector swap boring96xj XJ Cherokee Technical Forum 1 08-18-2006 10:35 AM
Auto swap to Manual Writeup? Jeepin_XJ_101 XJ Cherokee Technical Forum 3 01-15-2006 03:35 PM
