Injector Swap Writeup for the 4.0L - Page 2 - JeepForum.com
post #16 of 188 Old 10-11-2011, 05:48 PM
justanotherjpr
Gas mileage lately?
So do you actually hear your thoughts in your head or is it just sort of a dull roar before you smash your face into your keyboard and just submit whatever dumb **** ended up on the page?
justanotherjpr is offline
post #17 of 188 Old 10-11-2011, 07:03 PM
dagr8tim
dagr8tim's Avatar
1997 XJ Cherokee
You used petroleum jelly on the o rings? Generally that's not a wise idea on rubber parts. The same reason you are not supposed to use it with condoms.
Everywhere I've read says to lube them with some 10w30.
Jeeping - The art of getting dirty & going broke while slowly heading nowhere, and taking all day to do it.
97 XJ SE - The War Wagon
98 TJ - Mall Crawler/Light Trail Rig
dagr8tim is offline
post #18 of 188 Old 10-11-2011, 09:25 PM
91wranglerwilly
ok thanks for the help. im not entirerly sure thats the problem. i also havent sold my yj to buy this cherokee. so i was just doing a little perliminary back round work to see what i was getting in to
91wranglerwilly is offline
post #19 of 188 Old 10-12-2011, 04:50 PM Thread Starter
dukie564
dukie564's Avatar
1995 XJ Cherokee
Originally Posted by justanotherjpr View Post
Gas mileage lately?
18.75mpg average with 235/75R15 M/T tires, hacked front facia, and 300# of tools in the back....not too bad for a 248,000 mile Cherokee.
1995 XJ Cherokee Sport
4.5" Homebrew Lift, 4.0L HO I-6, AX-15, NP231, D30(Open)/C8.25(Locked)
33x12.5 Mickey Thompson Baja MTZ Tires, 309,000 mi and runnin' strong
dukie564 is offline
post #20 of 188 Old 10-17-2011, 09:29 PM
jimmy21669
I did this back in May. I was driving back and forth from MD to OH and needed the MPG.
I drive a 94 XJ 4.0 5 spd. with 160K on the clock.
My last trip I averaged 25.75 MPG. I have pics of the trip odometer and gas pump to prove it!
jimmy21669 is offline
post #21 of 188 Old 10-17-2011, 10:05 PM
jxpeej
I think I'm getting 13.8......I might have to try this.
jxpeej is offline
post #22 of 188 Old 11-25-2011, 04:07 PM
akdanny87
Hey guys, I just joined this forum to look for advice on this exact issue....I am quite the novice mechanic but I didnt want to take it to the shop. I am spewing gas from my injectors right now....what is the fire risk with this?
akdanny87 is offline
post #23 of 188 Old 11-25-2011, 04:26 PM Thread Starter
dukie564
dukie564's Avatar
1995 XJ Cherokee
HUGE. Seriously injector o-rings are cheap as hell from your local auto parts store. Fel-Pro ES70599 (also listed as FPES70599).
My writeup shows exactly how to replace them - should take all of about 15 minutes with a basic socket set.
dukie564 is offline
post #24 of 188 Old 12-09-2011, 06:08 PM
goolsbayjeep
does anyone know what neon injectors would work with a 2001 cherokee 4.0L
goolsbayjeep is offline
post #25 of 188 Old 12-09-2011, 09:39 PM
NJXJ91
Thanks man this is perfect. I plan on doing this eventually with these: http://www.precisionautoinjectors.co...2&categoryId=3
NJXJ91 is offline
post #26 of 188 Old 12-09-2011, 11:36 PM
90xjlimited
1990 XJ Cherokee
Gasoline is petroleum based, makes sense to use the jelly. Fuel system o-rings are petro resistant.
I installed the Ford 5.0 injectors on my '90 about a month ago. I averaged 19.7 mpg on a trip from Atlanta to Savannah, about 250 miles. An average mph of 75-80 and my cracked exhaust manifold didn't help the mpg's at all though.
Great write up.
90 XJ-RC 3 in. Series II-31x10.5 Grabber AT2's-Soft 8's-Leigh's 60mm TB-K&N Rusty's tube-5.0 injectors
90xjlimited is offline
post #27 of 188 Old 12-10-2011, 02:12 PM
goolsbayjeep
try these I have heard great things and they are a heck of a lot cheaper
http://www.fiveomotorsport.com/bosch...,-dodge-dakota
they also have 24lb and 27lb injectors
post #28 of 188 Old 12-11-2011, 09:44 AM Thread Starter
dukie564
dukie564's Avatar
1995 XJ Cherokee
784s
Yes those will work
Here's a pretty complete list of options for anyone interested, as well as what is needed to make them work in some cases
dukie564 is offline
post #29 of 188 Old 12-24-2011, 11:53 AM
d50
where do you get new filters, o-rings, and pintle caps for the 703's? and what make year and model do you ask for? i found a set at the junkyard but i dont remember what year the neon was. thanks.
d50 is offline
post #30 of 188 Old 12-24-2011, 02:42 PM Thread Starter
dukie564
dukie564's Avatar
1995 XJ Cherokee
i order my rebuild kits from a guy on bonanza - I think his username is turboparts
[edit: i was right - http://www.bonanza.com/listings/BOSC...-CYL/42334375]
The 703s are usually in 95-97 neons, but it's hit or miss. You need to make sure the number on the side is correct.
This is the engine you're looking for (or at least the one I've found them in)
dukie564 is offline
D30 differential cover swap writeup TheRifleman XJ Cherokee Technical Forum 50 01-05-2012 08:47 PM
89 injector swap evilbill XJ Cherokee Technical Forum 2 10-21-2010 06:46 AM
injector swap. XJ98beast XJ Cherokee Technical Forum 0 03-01-2010 09:03 AM
injector swap boring96xj XJ Cherokee Technical Forum 1 08-18-2006 10:35 AM
Auto swap to Manual Writeup? Jeepin_XJ_101 XJ Cherokee Technical Forum 3 01-15-2006 03:35 PM
