injector swap - JeepForum.com
post #1 of 2 Old 08-18-2006, 09:12 AM Thread Starter
boring96xj
injector swap
So I`m swapping a 99 intake manifold into the 96 on the weekend.
Which injectors should i go with 96 or 99 ?
And yes I already have a new set of o rings to swap in
boring96xj is offline
post #2 of 2 Old 08-18-2006, 09:35 AM
LEAD_NOT_FOLLOW
LEAD_NOT_FOLLOW's Avatar
1989 XJ Cherokee
It dosn't matter. They both are the same psi and basicly the same flow rate (ccm).
1996-1999 53030778 Grey 49psi 23.2lb/hr
1999-2006 04854181 Blue Tip 49psi 22.5lb/hr
LEAD_NOT_FOLLOW is offline
injector o-rings jeepcomanche88 MJ Comanche Technical Forum 4 10-08-2007 01:00 PM
TPS or bad injector paintedshrub XJ Cherokee Technical Forum 17 09-18-2007 08:04 PM
Injector? Steamer98 XJ Cherokee Technical Forum 22 06-10-2007 05:41 PM
Which injector is #3? Tronner XJ Cherokee Technical Forum 8 08-01-2006 04:38 PM
2.5 tbi injector i need a bit of help saaca MJ Comanche Technical Forum 3 04-24-2006 09:39 PM
