Injector size in an XJ - JeepForum.com
post #1 of 9 Old 02-10-2007, 05:20 PM Thread Starter
cbassillo
cbassillo's Avatar
My Jeep doesn't really have engine work done to it, except I just purchased a 68mm throttle body and custom intake for it. It's a 99 XJ with a 4.0L, stock internals, stock header, stock exhaust up to a 3" hi-flow cat, 2.5" pipe and a 2.5" Flowmaster 40 Delta series with a 2.5" tail. I just have a snorkle, I don't know how much of a difference that makes as far as forced air goes.
I'll probably be getting a header soon and potentially a cam, but that won't be for a while.
However, I do have 24lb. Ford racing injectors, four-hole type, and I heard they'll fit in my Cherokee. Are they okay size-wise with what I've got in my XJ? They were originally for my boyfriend's 91 Mustang LX 5.0, and said to fit a 87-93 5.0 fox body.
I just want to try to get the best out of my engine that I can now that I'm pretty much finished with my suspension and such.
Female owned, built & beaten.
Charlee
"Nancy" '99 XJ: 10" lift, 37x14" Iroks - D44 front & rear, Safari Snorkle, ETC. ETC.
cbassillo is offline
post #2 of 9 Old 02-10-2007, 05:58 PM
alexrule123
alexrule123's Avatar
if i remember correctly the 99's have 23lb injectors stock
2001 Cherokee Limited:
2005 Pontiac GTO 6.0L (DD)
alexrule123 is offline
post #3 of 9 Old 02-10-2007, 06:52 PM
law.74
I know earlier model 4.0s all run 19 lb. injectors. I can't imagine later models would require much different.
On a side note. I replaced 100K mile stock injectors in an old '90 with some low mile 19 lb. injectors from a ford 5.0. I did this based on supposed gains due to a better fuel spray pattern. I noticed zero improvement. They are a good cheap replacement due to all these 5.0 guys swapping for 24+ lb. injectors, but unless you "need" to replace your current ones I'd not mess with them.
Unless you stroke it 24 lb. is overkill. On the other hand do it for our edumucational benefit.
law.74 is offline
post #4 of 9 Old 02-10-2007, 06:55 PM
LEAD_NOT_FOLLOW
LEAD_NOT_FOLLOW's Avatar
1989 XJ Cherokee
The following is a list of the injectors used on the 4.0L since 1987 along with their rated static flow:
Model Year Part Number Color Fuel Pressure Static Flow
1987-1990 53003956 Black 39psi 18.6lb/hr
1991-1993 33007127 Brown 39psi 21.0lb/hr
1994-1995 53030343 Tan 39psi 21.0lb/hr
1996-1999 53030778 Grey 49psi 23.2lb/hr
1999-2006 04854181 Blue Tip 49psi 22.5lb/hr
The injector flow rate varies as the square root of the pressure drop across the injector. The stock '91-'95 4.0 injectors are rated at 22lb/hr @ 43psi fuel pressure, so at 39psi they flow ( sq. rt.(39/43) x 22.0 = 21.0 ).
For stock/modified 4.0 engines or stroker build-ups the following injectors can be installed. The flow rates are:
Ford Motorsport 19.0lb/hr @ 39psi (Part no. FMS-M9593-C302)
Ford Motorsport 24.0lb/hr @ 39psi (Part no. FMS-M9593-A302)
Ford Motorsport 30.0lb/hr @ 39psi (Part no. FMS-M9593-B302)
Chevy LT1 24.0lb/hr @ 43.5psi (Part no. 17124248)
Chevy LT4 28.0lb/hr @ 43.5psi (Part no. 17124251)
Accel 19.2lb/hr @ 44.1psi (ACC-150119)
Accel 21.1lb/hr @ 44.1psi (ACC-150121)
Accel 24.4lb/hr @ 44.1psi (ACC-150124)
Accel 25.6lb/hr @ 44.1psi (ACC-150126)
Accel 29.4lb/hr @ 44.1psi (ACC-150130)
The '95 Jeep 5.2 ZJ/Dodge 5.9 injectors (Part no. 53030262) are rated to flow 24.6lb/hr at 39psi.
The selection of injector size will depend on the estimated horsepower output, brake specific fuel consumption BSFC (assume 0.5), no. of cylinders, and the injector duty cycle (assume 80% or 0.8). The formula is: Injector size (lb/hr) = (horsepower x 0.5)/(no.of cylinders x 0.8)
LEAD_NOT_FOLLOW is offline
post #5 of 9 Old 07-27-2013, 02:42 PM
Jeeper_YJ
So, my '97 Cherokee had 23.2# injectors stock, and I put a 703 Neon injector in and I went down to a 22?
'97 Cherokee, 99+ intake, 62mm TB, 703 injectors (new), k&n intake, Hypertech III, 180* stat (1/8" drilled hole), 2.5" manifold 2 tail pipe (Hooker Maxflow & hi flow cat), Perf header, 4.5" zone lift, 32" GY Dura Trac, Rear head rests. Comp cam "231" & Perf head (LS1 BIG valves 2.02/1.62). 3 row alum radiator.
Jeeper_YJ is offline
post #6 of 9 Old 07-27-2013, 10:46 PM
rugsucka
Better spray pattern
rugsucka is offline
post #7 of 9 Old 07-27-2013, 11:30 PM
Jeeper_YJ
Right. Nothing to gain going to 24lb?
post #8 of 9 Old 07-28-2013, 11:54 PM
SKIN
2006 XK Commander
Where did you get the throttle body and intake?
SKIN is offline
post #9 of 9 Old 07-28-2013, 11:59 PM
Jeeper_YJ
Intake on CF
Throttle body on internet. Honestly? I did the upgrades piece by piece. I noticed no difference until I did it all. I only noticed more torque. Not really anything in the horse power (highway).
TPS or bad injector paintedshrub XJ Cherokee Technical Forum 17 09-18-2007 09:04 PM
Injector? Steamer98 XJ Cherokee Technical Forum 22 06-10-2007 06:41 PM
Which injector is #3? Tronner XJ Cherokee Technical Forum 8 08-01-2006 05:38 PM
2.5 tbi injector i need a bit of help saaca MJ Comanche Technical Forum 3 04-24-2006 10:39 PM
Injector Replacement Help Plz XJ in LA XJ Cherokee Technical Forum 15 12-20-2002 01:02 AM
