Quantcast Which injector is #3? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > Which injector is #3?
Rough Country Deals at JeepHut.comIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFREE shipping on Rugged Ridge Soft tops @thejeephut.com
Old 07-31-2006, 02:17 PM   #1
Tronner
I have the occasional warm start stumble that apparently has a fix by creating a heat shield sleeve on the #3 injector.
Looking in the engine bay from the front of the vehicle, which injector is the #3 injector?
Tronner is offline   Reply With Quote
Old 07-31-2006, 02:23 PM   #2
TheNerd
That is a factory recall. Take it to the dealer and get her fixed for free.
-2001 XJ Limited, 4.0L, NP231 w/ SYE, AW4, 4.5" Lift, 32" tires, 4.56's
-1987 XJ Pioneer, 4.0L, NP231 w/ SYE, NV3550, 4.5" lift, 4.10's, D44 rear
TheNerd is offline   Reply With Quote
Old 07-31-2006, 05:15 PM   #3
rob92xj
1992 XJ Cherokee
It's not a recall a TSB is what it is and they are only covered under the provisions of the warranty. The number 3 injector is the third one from the front of the engine as the first cylinder is number one and so on.
rob92xj is offline   Reply With Quote
Old 08-01-2006, 10:31 AM   #4
Tronner
So the one closest to the passenger seat? Looking in the engine bay from the front they go - #1 near left, #2 near right, #3 back left, #4 back right?
Old 08-01-2006, 10:44 AM   #5
jrn1023
Which engine/year are you talking about?
jrn1023 is offline   Reply With Quote
Old 08-01-2006, 10:46 AM   #6
AZ Jeff
In line engines count cylinders going from the front towards the back to the flywheel. So, a #3 cylinder is the third one back from the fan.
AZ-Jeff
1992 XJ 2" lift -- RIP
2000 XJ 3" lift -- Australian Ford Big Brakes up front, rock rails, ZJ rear discs (with WORKING parking brake), C4x4 rear bumper/tire carrier, Hella H4 headlights, IPF driving lights, OEM skid plates, OME springs/shocks, JKS LCA's, JKS Sway Bar links.
AZ Jeff is offline   Reply With Quote
Old 08-01-2006, 11:06 AM   #7
balloo93
Little Red Menace
balloo93's Avatar
1993 XJ Cherokee
Just for grins, if you haev a Performance shop around you, look into a small section of header wrap or header insolation and try using that. If it works you'll be a hero! If it doesn't, then at least we will know.
93 Sport
Beer is proof that God loves us and wants us to be happy............Ben Franklin
Specs in Profile.
http://www.cardomain.com/ride/325707/1
http://www.cardomain.com/ride/2406854/1
balloo93 is offline   Reply With Quote
Old 08-01-2006, 05:11 PM   #8
Tronner
Sorry, my ******* post above probably didn't help - it's a 4.0 inline six - 2000 Cherokee.
Old 08-01-2006, 05:38 PM   #9
beavis417
if it's an inline six, all of the injectors are on the left side (driver side) of the engine. the #3 injector, as stated above, is the 3rd one from the front of the engine. example, the injector closest to the radiator hose is #1, the one beside that is #2 and the one beside that is the magical #3!!
[SIZE=3][COLOR=Navy] 1988 jeep cherokee limited, 3" superlift suspension lift, 15x8.5 centerline hellcat wheels, 31x10.50x15 super swamper trxus m/t, $4000.00 stereo system (159.8 db), 160 amp alternator [/COLOR][/SIZE]
[url]http://i40.photobucket.com/albums/e209/beavis417/Copyof1.jpg[/url]
beavis417 is offline   Reply With Quote
Glock Forum
