I'm Stumped or stupid - need help with seat swap!! - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ Cherokee Technical Forum > I'm Stumped or stupid - need help with seat swap!!
The Original 3/8" Ruffstuff Diff Cover!Ruffstuff Axle Simple Swap Kit!The Ruffstuff NOT Universal 4 Link Kit!
Unread 06-28-2012, 05:43 PM   #1
74makoLKN
I got WJ seats from the JY today. I'm attempting to do the "easy" install into my 2001 xj i've read about, but it ain't that easy to me. so i'm either stumped or stupid.
I got the XJ driver seat out and seat bracket off. Started taking the Wj bracket off and it seems that when the bracket comes off so does the motor for seat adjust. if this is so, how do you wire the seat recline?
i don't need it to be electric, but all the write ups here and other forums indicate how easy it is but never explain how to make it happen. could someone who has done this help me out. thanks.
in hnd site should have started iwth the passenger side...so stupid on that one for sure.
thanks.
74makoLKN is offline   Reply With Quote Quick reply to this message
Unread 06-28-2012, 06:56 PM   #2
keepishop
1989 XJ Cherokee
You'll have to use the XJ seat frame and wire in an additional toggle for the seat back it seems.
Current: Black 89 limited, dakota bastard pack, zj coils, 1.5" lift, open cooling swap, bronco 2 carrier, rad fan switch
Rest in Pieces: Red 1990 cherokee dana30/8.25 - v8 zj coils & s10 bastard pack 2.5" lift - 31x10.5r15 tires - v8 zj tierod
Originally Posted by talentjeep View Post
Bleed or Quit.
jf irc @ irc.freenode.net #jeepforum
keepishop is offline   Reply With Quote Quick reply to this message
Unread 06-29-2012, 07:10 AM   #3
74makoLKN
okay. i got it figured out. I just needed to step away and come back to it. when switching out the seat sliders 2 of the motors come off with the wj seat slider/frame, but the backrest motor is retained. it is bolted t the seat itself not the slider frame. I've now got both passenger and driver side seats in with the xj manual slider for front to back adjustment.
one more question though. now i need power so the backrest can be adjusted. for the wiring i found (from the FAQ sticky) this thread on NAXJA http://www.naxja.org/forum/showthread.php?t=1042180 but i can't tell which which part of the wiring harness is being used or how to wire the driver side and passenger side together? has anyone found a thread that would help someone with no electrical experience accomplish this? thread with pics would be awesome.
Unread 06-29-2012, 07:44 AM   #4
74makoLKN
found this website to help with wiring http://www.wjjeeps.com/seats/seats.htm#POWER but i'm still confused. the wiring diagram doesn't seem to match what i have on the wj harness.
this is the mess of wiring i have under my wj seats installed in the xj.can some one tell me which of these i am supposed to find my red (power) and black (ground)?
Unread 06-29-2012, 07:45 AM   #5
74makoLKN
try again
Unread 06-29-2012, 08:53 AM   #6
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
The seat tilt motor and/or switch should have 2 or 3 wires, 12 volts positive and one ground. The wires may or not be red or black. Use a 15 amp fuse and connect the positive wire to 12 volts, and the other to ground.
CJ7-Tim is offline   Reply With Quote Quick reply to this message
Unread 06-29-2012, 09:55 AM   #7
74makoLKN
okay...am i understanding correctly that i don't need the entire wiring harness as shown in the picture above, but only the power and ground coming from the seat tilt motor? where is the best place to pull my 12v from? directly from the fuse box? can my power run from fuse box -> to passenger -> directly to driver seat; or does each seat need its own power source/wire from the fuse box?
Unread 06-29-2012, 10:09 AM   #8
74makoLKN
there are two sets of wires coming from the seat tilt motor. anyone know which is power?
Unread 06-29-2012, 01:20 PM   #9
Svenlylethor
Hey man,
I put ZJ seats on my XJ last year. For the wiring, I had a wire go all the way from the battery and into the driver's side where the wires all go through. (I just loosened up the cluster, stuck the wire through, and tightened it back up) You're going to want to put a 15 amp wire on the end of it and hook it up to the red wire from the WJ harness. From there you'll ground the black - I just grounded it somewhere in the middle under the center console.
Are your seats heated? I had to figure that one out on mine and it was pretty dang hard... but then I got it to work with a lot of forum crawling and faith.
As for your rear seats make sure you you pull the wires in the frame out of the way when drilling the bottom seats down. I accidentally drilled through them and screwed the whole thing up. Have you put them in yet?
[]IIIIIII[]
Svenlylethor is offline   Reply With Quote Quick reply to this message
Unread 06-29-2012, 06:27 PM   #10
74makoLKN
got it. thanks.
