ignition switch wont turn how to remove and question - JeepForum.com
post #1 of 8 Old 01-28-2010, 05:06 PM Thread Starter
bcameron1974
my 2000 automatic 4..0 cherokee is having problems with the key not turning. It started few weeks ago. At first would be random and got worst. I bought some graphite really didnt help. Almost got stuck at work today i tried turning and eventually got it to tun my tappin with hammer and turning same time. I now have the key turned and left key in so i can drive it..where the battery isnt running. Im having problems finding the new switch. and how do u remove the switch..do u have to remove the steering wheel or is it the platsic cover i remove behind the wheels...any tips and lenghts details...and would you say tha is a bad switch or possibly something else?
my build thread.
1990 YJ 4.2 nuttered-mc2150-team rush-4 inch RC-1.5''-Shackles-1 1/2''-15x10 American Racing Atlas Wheels-33x15x12.50 Goodyear A/T-Hella Offroad Winshield Lights-Black Met/Gold Paint -Custom Gold Decals
bcameron1974 is offline
post #2 of 8 Old 01-29-2010, 03:05 AM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
The ignition cylinder is removable. Take it out, clean it with some throttle body cleaner and then lubricate it with some gun oil. See if that solves your problem. Don't try to clean and lubricate the cylinder while it is still installed, you will just make a huge mess.
Directly under the ignition key cylinder is a hole is the plastic trim, turn the key to the ACC position or the Run position. Insert a small Phillips screw driver or a punch and press upward gently. There is a small button you are trying to push and when the key is in the right spot and the button is pushed, the lock cylinder and the key will pull out of the steering column. (If you have trouble, you can remove some screws and the bottom plastic trim can be removed. The button will be easier to see and activate). Remove the key and clean/lube the cylinder. Put the key back in and slide the cylinder back in place.
CJ7-Tim is offline
post #3 of 8 Old 01-29-2010, 03:56 AM Thread Starter
bcameron1974
thanks I will try that..is there anything else it could be? Like ive heard that it could be something with a transmission lock or a ignitin switch in stead of cylynder..im assuming its the cylnder tho th ways its acting but never know...its basically getting stuck in the off position and im leaving the key in it and not turned quite all the wy to lock to keep it where it will turn again...it actually took alot of searching and glad u helped clear it up how to remove...so glad i dont have to take wheel off..with a air bag.
my build thread.
post #4 of 8 Old 01-29-2010, 04:36 PM
CJ7-Tim
CJ7-Tim's Avatar
Yes there are other possibilities, but clean the cylinder first, that should cure the problem.
CJ7-Tim is offline
post #5 of 8 Old 01-29-2010, 08:47 PM Thread Starter
bcameron1974
i put the key in the ignition then put a screwdriver in th hole below the ignition..it took awhile to get just right but the ignition popped out but only half way..i couldnt pull the rest of it out...i luckily was able to pop it back after few tries..should that thing slide easily out once it gives..
its also a hard part to find..i talked to chrysler they said ignition cylyder 120 i think and they also got the tumblers if cyclynde was good still...i just dont know what to do..
my build thread.
post #6 of 8 Old 01-29-2010, 11:05 PM
CJ7-Tim
CJ7-Tim's Avatar
It should slide right out. You can try a little bit of WD-40 or spray lubricant.
I have put junkyard locks and keys in two different Cherokees. I think I paid like $40 for a complete set of locks with two keys. A locksmith can re-key a used ignition cylinder for much less than the dealership charges.
CJ7-Tim is offline
post #7 of 8 Old 01-30-2010, 02:48 PM Thread Starter
bcameron1974
i tried again its like its catching on something...did u take plastic shroud off around column...i just noticed 2 screws around the plastic and i turned them for 20 minutes and didnt loosen...
my build thread.
post #8 of 8 Old 01-30-2010, 04:02 PM
CJ7-Tim
CJ7-Tim's Avatar
On a 2000 you shouldn't have to remove the plastic. If you want to, get a flash light and light up the 3 Phillips screws, they are way at the bottom of those holes. If you don't have the screw driver at the correct angle and cantered in the holes it doesn't fit into the screws and you can twist all day long and get nothing done.
CJ7-Tim is offline
Key wont turn in the ignition cylinder fitbmxseries1 XJ Cherokee Technical Forum 15 01-14-2010 08:41 PM
Key wont turn in ignition, cannot get cylinder out Tommyboy75861 XJ Cherokee Technical Forum 3 12-07-2008 06:47 PM
Key wont turn in ignition tangofox007 XJ Cherokee Technical Forum 9 08-30-2007 02:57 PM
HELP!!! Ignition wont turn BlacknRedGT XJ Cherokee Technical Forum 19 03-12-2007 02:00 PM
ignition key wont switch to acc cocoloco XJ Cherokee Technical Forum 2 10-05-2006 11:56 AM
