Ignition Switch Problem, BIG!! - Page 2 - JeepForum.com
post #16 of 18 Old 02-24-2012, 09:02 AM
412Moose
1989 XJ Cherokee
How did you come out superwhite?
My key was not turning too far, so I don't think we had the same problem - BUT, my problem was resolved by replacing the starter motor.
412Moose is offline
post #17 of 18 Old 06-12-2015, 12:44 AM
austinsiphone
My is doing the same thing! i replaced and get a brand new ignition switch but it was doing the same thing. everything starts up, the battery fine and starter great i just hate going under my jeep and hot wire to start my jeep. do you think its my key cylinder or do you think its something else?
austinsiphone is offline
post #18 of 18 Old 03-20-2017, 08:52 PM
neto_09
Hi, I have a problem with my jeep too, I turn the key to start it and do nothing, no crank but my panel and accesories all work perfect. Also, when a turn the key to start the the engine there's a clicking noise coming from the relay behind the glove compartment. I tried to jump start the starter, it gives crank and makes like if the engine would turn on but it won't, even if I pull the accelerator cable. I been reading some posts here and I'm thinking that the ignition switch went bad, but I have a doubt, would the jeep start normally by jumping starting the starter? Or not. That takes me to another problem besides the ignition switch, I'm thinking that my fuel pump is bad too. Plase any input would be appreciated. Thanks.
Want to see someones's real face? Give them power.
neto_09 is offline
Think this is a ignition switch problem. 96yeepster XJ Cherokee Technical Forum 8 11-28-2007 04:09 PM
ignition switch problem imthehink XJ Cherokee Technical Forum 2 08-31-2006 05:29 PM
Ignition switch problem Bob Marshall MJ Comanche Technical Forum 4 12-08-2005 02:24 PM
Ignition Switch Problem? jeep1 XJ Cherokee Technical Forum 4 12-01-2005 12:43 PM
ignition switch problem TARHEELHAL1942 XJ Cherokee Technical Forum 1 01-11-2003 11:04 AM
