Ignition Problems - JeepForum.com
post #1 of 5 Old 04-20-2010, 06:00 PM Thread Starter
XJ_AJK
1992 XJ Cherokee
Ignition Problems
1992 XJ Limited 4.0 HO
I was driving down the road one day when my jeep shut off. I pulled over and it would just crank all day and not start. It turns out I had no power at the "run" position on my ignition switch, now I have no power at the switch, when I turn the key nothing happens no accesories or anything. Brand new Ignition switch didnt fix it. It is in the wiring I beleive.
I need to rewire the ignition switch completly bypassing the underdash harness, is it possible? The haynes manual doesnt have the right wire diagrams. Please help!!
XJ_AJK is offline
post #2 of 5 Old 04-21-2010, 02:42 PM Thread Starter
XJ_AJK
1992 XJ Cherokee
But the wiring seems fine could it be a possibility that my ecu isnt sending power to the ignition switch? I dont want to rewire it if I dont have to.
XJ_AJK is offline
post #3 of 5 Old 04-21-2010, 03:47 PM
Carl48
If you have no power at the switch, check the fuses in the power distribution center under the hood.
Yes, it is possible to rewire things to bypass the ignition switch...guys have installed pushbutton starters and guarded ignition switches but don't even think of attempting it without a factory service manual and a good knowledge of auto electric. If you fail to provide proper circuit protection you could end up burning up your Jeep.
Carl48 is offline
post #4 of 5 Old 04-22-2010, 03:57 PM Thread Starter
XJ_AJK
1992 XJ Cherokee
Well I replaced the fusebox/underdash harness. All the relays and fuses are good. Why dont I get power to the ignition?? Please help me I am about to go crazy and burn it down!!!
XJ_AJK is offline
post #5 of 5 Old 04-23-2010, 02:15 PM
Carl48
Battery 12v hot is provided via a 60 amp fuse in the power distribution center under the hood to the ignition switch on a red 12awg wire. Output from the ignition switch in the "run" position is on 12awg dark blue wire. The "run" output provides power to the ASD relay coil, fuel pump relay coil, and the PCM (computer) pin 9.
Carl48 is offline
4.0 , cherokee , ignition switch , no start , wiring diagram
Ignition problems? piro133a XJ Cherokee Technical Forum 1 03-04-2010 02:17 PM
89 Comanche...ignition problems really confused 892wheel MJ Comanche Technical Forum 3 12-26-2009 07:47 AM
Ignition cylinder problems?? :( SilverSpy0 XJ Cherokee Technical Forum 1 02-03-2008 06:57 PM
Ignition Switch Problems rwallan XJ Cherokee Technical Forum 1 08-12-2007 05:11 PM
Ignition switch problems DEPartsnPieces XJ Cherokee Technical Forum 4 09-04-2006 10:28 AM
