Quantcast ignition issue - engine won't shut off - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > ignition issue - engine won't shut off
Mojave Cut & Fold Rear Bumper – Jeep Cherokee XJRUBICON EXPRESS Lift Kits and Accessories Available at BasTruck-Lite's New LED Headlamp Series
Old 09-07-2009, 05:15 PM   #1
Mark Beer
1995 XJ Cherokee
I have the ignition issue in my Jeep. turning it off, the engine would not shut off. I had that problem the day after I bought it (already knew there was an issue as well as an old battery). I had the repair shop replace the ignition system as well as the battery.
so the weekend went by without a hitch, then today, twice I had to get out and pop the hood to unplug the ignition wiring to shut the engine off. I don't want to be doing this every time.
I'm not much of a mechanic but I can change a few things if I know what I'm doing.
any help and advice will be much appreciated.
cheers.
Mark Beer is offline   Reply With Quote
Old 09-08-2009, 12:37 AM   #2
Mark Beer
1995 XJ Cherokee
bumpity bump bump
(one two three four five six... ah, over 10 characters, ok)
Old 09-08-2009, 01:24 AM   #3
MaskedMallard
Did you tell the shop to replace the Ignition System, or did you tell them the problem?
If you told the shop to replace the Ignition System, what did they replace? I'm guessing Cap? Rotor? Wires? Plugs?
Or the Key & Tumbler? I'm guessing either a bad Key/Tumbler or actuator? Its inside the steering column, under the dash, or at least some where in that area if I remember correctly.
I'm thinking you are going to need to get a wiring diagram & trace wires to see if something is not completing / completing a circuit for the Ignition Tumbler.
MaskedMallard is offline   Reply With Quote
Old 09-08-2009, 08:14 AM   #4
XJMuscle98
Try replacing the ASD Relay
1998 Jeep Cherokee 4.0L AW4/NP231 211k+
"Approximately 80 percent of our air pollution stems from hydrocarbons released by vegetation, so let's not go overboard in setting and enforcing tough emission standards from man-made sources."
Ronald Reagan
My goal is to have 20 lights around my XJ.
Currently: 10
XJMuscle98 is offline   Reply With Quote
Glock Forum
