Ignition disable - JeepForum.com
post #1 of 7 Old 01-23-2014, 12:50 PM Thread Starter
AlC
2001 FSJ Cherokee
Ignition disable
I intend to replace my oil pump and want to crank the motor until I see oil pressure.
Obviously don't want it to fire up until then so any suggestions for a simple way to disable the ignition?
AlC is offline
post #2 of 7 Old 01-23-2014, 01:41 PM
CCKen
CCKen's Avatar
Remove the following fuses from your PDC:
IGN RAIL COIL FUEL INJECTORS and ASD to be sure.
CCKen is offline
post #3 of 7 Old 01-23-2014, 07:55 PM Thread Starter
AlC
2001 FSJ Cherokee
Exactly what I was looking for.......Thank You!
AlC is offline
post #4 of 7 Old 01-23-2014, 09:14 PM
landude
Hey, Ken you have a few in backwards....
landude is offline
post #5 of 7 Old 01-24-2014, 04:30 AM
CCKen
CCKen's Avatar
Explain.
CCKen is offline
post #6 of 7 Old 01-24-2014, 07:51 AM
KF4SQB
1994 XJ Cherokee
Ken, I think he's making a joke. The numbers on some on your fuses are turned a different direction than others.
For the original question: doesn't the 4.0's oil pump drive off of the bottom of the distributor shaft? My brother uses a nifty little trick for Ford and Chevy engines for this very purpose. Remove the drive gear from the shaft of an old distributor, gut the internals out of the distributor, and slide it down into the block, making sure it engages with the oil pump. Then, chuck a drill to the top of the shaft, and run the drill until you see oil pressure, plus an additional 15-20 seconds. You've now primed the entire engine, without turning it over.
4-wheeling: because football, basketball, baseball, and golf only require one ball!
Confidence: The feeling you get just before you fully understand the situation!
KF4SQB is offline
post #7 of 7 Old 01-24-2014, 08:15 AM
CCKen
CCKen's Avatar
I figured as much but was wondering what he meant by "Backwards".
Yes, the oil pump is driven by the distributor drive shaft (pre-2000) and by the Oil Pump Drive/Cam Position Sensor shaft (2000/2001).
I did exactly what your brother did on my '99. Works good.
CCKen is offline
