Ignition Coil - JeepForum.com
post #1 of 6 Old 07-01-2013, 08:18 PM Thread Starter
BassMasterCHS
1993 XJ Cherokee
Ignition Coil
I need to figure out what grounds attached to the coil bracket, as I had to relocate the coil due to the fact the 88 block I'm using doesn't have a place for the bracket.
3 Inch lift, 30" BFG AT's, Walmart lights up front.
BassMasterCHS is offline
post #2 of 6 Old 07-02-2013, 04:07 PM Thread Starter
BassMasterCHS
1993 XJ Cherokee
Bump
post #3 of 6 Old 07-02-2013, 05:44 PM
Saudade
1988 XJ Cherokee
?? The coil does not attach to the block on an 88.
Saudade is offline
post #4 of 6 Old 07-02-2013, 05:50 PM Thread Starter
BassMasterCHS
1993 XJ Cherokee
That's correct, which is why I'm having to relocate it somewhere in my 93..
post #5 of 6 Old 07-02-2013, 06:03 PM
Saudade
1988 XJ Cherokee
Ah. I get it now. You're putting a 88 block into your 93.
I looked in my FSM and don't see a specific ground on the coil. One wire goes to the Dist, the other 2 to the PCM.
On my 88, the coil sits on top of the ignition module mounted on the pass inner fender.
Saudade is offline
post #6 of 6 Old 07-02-2013, 06:24 PM Thread Starter
BassMasterCHS
1993 XJ Cherokee
Awesome! Thank you!
